C64 SAM (Software Automatic Mouth) as Text2Speech in armbian
guidol
Maybe someone does know the old/historical SAM (Software Automatic Mouth) speech synthesizer for the Commodore 64?
Today I did found the github-page with the source-code and compiled it on my Orange Pi R1 - using armbian :)
For compiling the default SDL-version I had to install the 2 additional packages with apt
- libsdl1.2-dev
- libsdl1.2debian
before SAM did compile on armbian.
I also did try libsdl2-2.0.0 (and -dev), but this didnt worked well while compiling :(
The souce-code could be found at:
https://github.com/s-macke/SAM
Hear here, how this OLD speech synthesizer sounds :)
https://www.youtube.com/watch?v=Rm4ZCGgzeeU
Test him ONLINE:
https://simulationcorner.net/index.php?page=sam
Or read about him in the Wikipedia:
https://en.wikipedia.org/wiki/Software_Automatic_Mouth
Tested SAM again and here some infos for compile and usage ( if you have a "late switching" amplifier on your SBC) :
If you want to use direct output via sdl instead of generating .wav / using aplay the .wav
( libsdl2-2.0-0 libsdl2-dev doenst work with SAM ):
apt install libsdl1.2-dev libsdl1.2debian
wget https://github.com/s-macke/SAM/archive/master.zip -O SAM_original_master.zip
unzip SAM_original_master.zip
cd SAM-master
edit flags in Makefile if you want to use of Non-SDL (and save 30MB download and 300MB on HDD)
make
./sam 'Hello, how do you do?'
./sam -wav sam_ouput.wav 'Hello, how do you do?' && aplay ./sam_output.wav
Creating a empty .wav for activating the amplifier:
./sam -wav /home/guido/SAM-master/sam_empty.wav ''
Shell-Script waiting for audio-amplifier to be ready:
# Non-SDL sam_amp_nonsdl.sh
./sam -wav /tmp/sam_output.wav $1
aplay /home/guido/SAM-master/sam_empty.wav 2> /dev/null
sleep 1
aplay /tmp/sam_output.wav 2> /dev/null
rm /tmp/sam_output.wav
OR
# SDL sam_amp_sdl.sh
sleep 1
./sam $1
Examples:
./sam_amp_nonsdl.sh 'My name is SAM'
./sam_amp_sdl.sh 'My name is SAM'
