NanoPi R1 RTL8152 locks up under load
andersm
Hi,
We've built a network experimentation system using NanoPi R1 modules, but when load testing the system with iperf3, we are seeing the on-board RTL8152 interface enter a state where it does not seem to be responding until the board is power cycled.
The system consists of 32 NanoPi modules connected in a torus, with the 1Gig interface connected to its neighbour's 100Mbit interface. An additional USB Ethernet dongle functions as a control interface. The modules are powered from a Ubiquiti PoE switch, using this type of isolated PoE splitter. Eyeballing the switch UI, power consumption per node seems to hover between 2.3W-3.5W, depending on load. We're using the latest Ubuntu-based image, with kernel 5.4.28.
Under light loads, the system works fine, but when performing load tests, we're seeing the RTL8152 entering some kind of lock-up state. As can be seen from the system logs, first the netdev watchdog triggers, then the kernel tries to reset the USB device, finally reporting that it is unable to enumerate the device. After encountering this problem, if the node is rebooted, the USB device can still not be enumerated, and will remain unresponsive until it is powercycled. The external USB Ethernet dongle stays working through all of this, so it seems that the USB host controller and subsystem works OK. We haven't seen any issues with the 1Gig interface.
Searching the net, I have found reports with similar backtraces, but they seem to be either several years old, or related to the RTL8153 chip, which shares the same driver. In either case, none of them seem to offer any answers as to what's going on, or if there is any fix.
Has anyone else seen this? Any ideas if it's a driver or hardware issue?
Relevant bit from the kernel log:
Spoiler
 10707	[ 1063.202413] ------------[ cut here ]------------
 10708	[ 1063.202481] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:448 dev_watchdog+0x213/0x214
 10709	[ 1063.202500] NETDEV WATCHDOG: bridgeif1 (r8152): transmit queue 0 timed out
 10710	[ 1063.202506] Modules linked in: hsr evdev lima gpu_sched snd_soc_simple_card snd_soc_simple_card_utils zram sun8i_codec_analog sun8i_adda_pr_regmap sun4i_i2s sun4i_gpadc_iio snd_soc_core industrialio snd_pcm_dmaengine snd_pcm r8152 snd_timer snd cdc_ether sun8i_thermal soundcore usbnet sunxi_cedrus(C) v4l2_mem2mem gpio_keys uio_pdrv_genirq uio cpufreq_dt sch_fq_codel usb_f_acm u_serial g_serial libcomposite ip_tables x_tables pwrseq_simple realtek
 10711	[ 1063.202605] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G         C        5.4.28-sunxi #20.02.7
 10712	[ 1063.202610] Hardware name: Allwinner sun8i Family
 10713	[ 1063.202640] [<c010da8d>] (unwind_backtrace) from [<c010a0ad>] (show_stack+0x11/0x14)
 10714	[ 1063.202661] [<c010a0ad>] (show_stack) from [<c0951bef>] (dump_stack+0x6f/0x7c)
 10715	[ 1063.202687] [<c0951bef>] (dump_stack) from [<c011b60b>] (__warn+0xb7/0xb8)
 10716	[ 1063.202702] [<c011b60b>] (__warn) from [<c011b8b7>] (warn_slowpath_fmt+0x5f/0x74)
 10717	[ 1063.202716] [<c011b8b7>] (warn_slowpath_fmt) from [<c0850083>] (dev_watchdog+0x213/0x214)
 10718	[ 1063.202740] [<c0850083>] (dev_watchdog) from [<c017209b>] (call_timer_fn+0x27/0x128)
 10719	[ 1063.202752] [<c017209b>] (call_timer_fn) from [<c0172c15>] (run_timer_softirq+0x3f9/0x418)
 10720	[ 1063.202763] [<c0172c15>] (run_timer_softirq) from [<c01022f7>] (__do_softirq+0xdf/0x288)
 10721	[ 1063.202775] [<c01022f7>] (__do_softirq) from [<c012035f>] (irq_exit+0x7b/0x90)
 10722	[ 1063.202792] [<c012035f>] (irq_exit) from [<c016051f>] (__handle_domain_irq+0x47/0x84)
 10723	[ 1063.202812] [<c016051f>] (__handle_domain_irq) from [<c05e3c4d>] (gic_handle_irq+0x39/0x6c)
 10724	[ 1063.202829] [<c05e3c4d>] (gic_handle_irq) from [<c0101ae5>] (__irq_svc+0x65/0x94)
 10725	[ 1063.202841] Exception stack(0xc0f01f20 to 0xc0f01f68)
 10726	[ 1063.202855] 1f20: 00000000 0050f000 ef69ff34 c0116341 ffffe000 c0f04f68 c0f04fb0 00000001
 10727	[ 1063.202865] 1f40: c0f04f48 00000000 c0ec48f0 c0ff67f6 c0f05028 c0f01f70 c010792f c0107930
 10728	[ 1063.202869] 1f60: 400d0033 ffffffff
 10729	[ 1063.202886] [<c0101ae5>] (__irq_svc) from [<c0107930>] (arch_cpu_idle+0x28/0x2c)
 10730	[ 1063.202900] [<c0107930>] (arch_cpu_idle) from [<c013fa4f>] (do_idle+0x15b/0x1cc)
 10731	[ 1063.202912] [<c013fa4f>] (do_idle) from [<c013fcb9>] (cpu_startup_entry+0x19/0x20)
 10732	[ 1063.202932] [<c013fcb9>] (cpu_startup_entry) from [<c0e00c6d>] (start_kernel+0x3fb/0x40c)
 10733	[ 1063.202948] ---[ end trace 8a7042696d164652 ]---
 10734	[ 1063.202968] r8152 2-1:1.0 bridgeif1: Tx timeout
 10735	[ 1064.777084] r8152 2-1:1.0 bridgeif1: Tx status -2
 10736	[ 1064.780443] r8152 2-1:1.0 bridgeif1: Tx status -2
 10737	[ 1064.783815] r8152 2-1:1.0 bridgeif1: Tx status -2
 10738	[ 1064.787064] r8152 2-1:1.0 bridgeif1: Tx status -2
 10739	[ 1068.322762] r8152 2-1:1.0 bridgeif1: Tx timeout
 10740	[ 1074.211116] r8152 2-1:1.0 bridgeif1: Tx timeout
 10741	[ 1079.075375] r8152 2-1:1.0 bridgeif1: Tx timeout
 10742	[ 1084.195734] r8152 2-1:1.0 bridgeif1: Tx timeout
 10743	[ 1089.315981] r8152 2-1:1.0 bridgeif1: Tx timeout
 10744	[ 1095.204340] r8152 2-1:1.0 bridgeif1: Tx timeout
 10745	[ 1100.324633] r8152 2-1:1.0 bridgeif1: Tx timeout
 10746	[ 1106.212944] r8152 2-1:1.0 bridgeif1: Tx timeout
 10747	[ 1111.077223] r8152 2-1:1.0 bridgeif1: Tx timeout
 10748	[ 1116.197542] r8152 2-1:1.0 bridgeif1: Tx timeout
 10749	[ 1121.317802] r8152 2-1:1.0 bridgeif1: Tx timeout
 10750	[ 1127.206158] r8152 2-1:1.0 bridgeif1: Tx timeout
 10751	[ 1132.326404] r8152 2-1:1.0 bridgeif1: Tx timeout
 10752	[ 1138.214721] r8152 2-1:1.0 bridgeif1: Tx timeout
 10753	[ 1143.078976] r8152 2-1:1.0 bridgeif1: Tx timeout
 10754	[ 1148.199250] r8152 2-1:1.0 bridgeif1: Tx timeout
 10755	[ 1153.319543] r8152 2-1:1.0 bridgeif1: Tx timeout
 10756	[ 1159.207853] r8152 2-1:1.0 bridgeif1: Tx timeout
 10757	[ 1164.328134] r8152 2-1:1.0 bridgeif1: Tx timeout
 10758	[ 1170.216436] r8152 2-1:1.0 bridgeif1: Tx timeout
 10759	[ 1175.080678] r8152 2-1:1.0 bridgeif1: Tx timeout
 10760	[ 1180.201193] r8152 2-1:1.0 bridgeif1: Tx timeout
 10761	[ 1185.321188] r8152 2-1:1.0 bridgeif1: Tx timeout
 10762	[ 1191.209491] r8152 2-1:1.0 bridgeif1: Tx timeout
 10763	[ 1196.329740] r8152 2-1:1.0 bridgeif1: Tx timeout
 10764	[ 1202.218054] r8152 2-1:1.0 bridgeif1: Tx timeout
 10765	[ 1207.082286] r8152 2-1:1.0 bridgeif1: Tx timeout
 10766	[ 1212.202523] r8152 2-1:1.0 bridgeif1: Tx timeout
 10767	[ 1217.322777] r8152 2-1:1.0 bridgeif1: Tx timeout
 10768	[ 1223.211058] r8152 2-1:1.0 bridgeif1: Tx timeout
 10769	[ 1228.331309] r8152 2-1:1.0 bridgeif1: Tx timeout
 10770	[ 1234.219597] r8152 2-1:1.0 bridgeif1: Tx timeout
 10771	[ 1239.083829] r8152 2-1:1.0 bridgeif1: Tx timeout
 10772	[ 1244.204071] r8152 2-1:1.0 bridgeif1: Tx timeout
 10773	[ 1249.324313] r8152 2-1:1.0 bridgeif1: Tx timeout
 10774	[ 1255.212602] r8152 2-1:1.0 bridgeif1: Tx timeout
 10775	[ 1260.332834] r8152 2-1:1.0 bridgeif1: Tx timeout
 10776	[ 1266.221110] r8152 2-1:1.0 bridgeif1: Tx timeout
 10777	[ 1271.085335] r8152 2-1:1.0 bridgeif1: Tx timeout
 10778	[ 1276.205574] r8152 2-1:1.0 bridgeif1: Tx timeout
 10779	[ 1281.325815] r8152 2-1:1.0 bridgeif1: Tx timeout
 10780	[ 1287.214079] r8152 2-1:1.0 bridgeif1: Tx timeout
 10781	[ 1292.334321] r8152 2-1:1.0 bridgeif1: Tx timeout
 10782	[ 1298.222578] r8152 2-1:1.0 bridgeif1: Tx timeout
 10783	[ 1303.086798] r8152 2-1:1.0 bridgeif1: Tx timeout
 10784	[ 1308.207024] r8152 2-1:1.0 bridgeif1: Tx timeout
 10785	[ 1313.327255] r8152 2-1:1.0 bridgeif1: Tx timeout
 10786	[ 1319.215517] r8152 2-1:1.0 bridgeif1: Tx timeout
 10787	[ 1324.335751] r8152 2-1:1.0 bridgeif1: Tx timeout
 10788	[ 1330.224002] r8152 2-1:1.0 bridgeif1: Tx timeout
 10789	[ 1335.088218] r8152 2-1:1.0 bridgeif1: Tx timeout
 10790	[ 1340.208445] r8152 2-1:1.0 bridgeif1: Tx timeout
 10791	[ 1345.328670] r8152 2-1:1.0 bridgeif1: Tx timeout
 10792	[ 1351.216923] r8152 2-1:1.0 bridgeif1: Tx timeout
 10793	[ 1356.337149] r8152 2-1:1.0 bridgeif1: Tx timeout
 10794	[ 1362.225400] r8152 2-1:1.0 bridgeif1: Tx timeout
 10795	[ 1367.089604] r8152 2-1:1.0 bridgeif1: Tx timeout
 10796	[ 1372.209825] r8152 2-1:1.0 bridgeif1: Tx timeout
 10797	[ 1377.330044] r8152 2-1:1.0 bridgeif1: Tx timeout
 10798	[ 1383.218298] r8152 2-1:1.0 bridgeif1: Tx timeout
 10799	[ 1388.338517] r8152 2-1:1.0 bridgeif1: Tx timeout
 10800	[ 1394.226765] r8152 2-1:1.0 bridgeif1: Tx timeout
 10801	[ 1399.090969] r8152 2-1:1.0 bridgeif1: Tx timeout
 10802	[ 1404.211185] r8152 2-1:1.0 bridgeif1: Tx timeout
 10803	[ 1409.331406] r8152 2-1:1.0 bridgeif1: Tx timeout
 10804	[ 1415.219644] r8152 2-1:1.0 bridgeif1: Tx timeout
 10805	[ 1420.339862] r8152 2-1:1.0 bridgeif1: Tx timeout
 10806	[ 1426.228097] r8152 2-1:1.0 bridgeif1: Tx timeout
 10807	[ 1431.092293] r8152 2-1:1.0 bridgeif1: Tx timeout
 10808	[ 1436.212502] r8152 2-1:1.0 bridgeif1: Tx timeout
 10809	[ 1441.332714] r8152 2-1:1.0 bridgeif1: Tx timeout
 10810	[ 1447.220963] r8152 2-1:1.0 bridgeif1: Tx timeout
 10811	[ 1452.341168] r8152 2-1:1.0 bridgeif1: Tx timeout
 10812	[ 1458.229403] r8152 2-1:1.0 bridgeif1: Tx timeout
 10813	[ 1463.093607] r8152 2-1:1.0 bridgeif1: Tx timeout
 10814	[ 1468.213811] r8152 2-1:1.0 bridgeif1: Tx timeout
 10815	[ 1473.334015] r8152 2-1:1.0 bridgeif1: Tx timeout
 10816	[ 1479.222255] r8152 2-1:1.0 bridgeif1: Tx timeout
 10817	[ 1484.342458] r8152 2-1:1.0 bridgeif1: Tx timeout
 10818	[ 1490.230695] r8152 2-1:1.0 bridgeif1: Tx timeout
 10819	[ 1495.094882] r8152 2-1:1.0 bridgeif1: Tx timeout
 10820	[ 1500.215088] r8152 2-1:1.0 bridgeif1: Tx timeout
 10821	[ 1505.335292] r8152 2-1:1.0 bridgeif1: Tx timeout
 10822	[ 1511.223529] r8152 2-1:1.0 bridgeif1: Tx timeout
 10823	[ 1516.343733] r8152 2-1:1.0 bridgeif1: Tx timeout
 10824	[ 1522.231964] r8152 2-1:1.0 bridgeif1: Tx timeout
 10825	[ 1527.096153] r8152 2-1:1.0 bridgeif1: Tx timeout
 10826	[ 1532.216355] r8152 2-1:1.0 bridgeif1: Tx timeout
 10827	[ 1537.336553] r8152 2-1:1.0 bridgeif1: Tx timeout
 10828	[ 1543.224791] r8152 2-1:1.0 bridgeif1: Tx timeout
 10829	[ 1548.344992] r8152 2-1:1.0 bridgeif1: Tx timeout
 10830	[ 1554.233216] r8152 2-1:1.0 bridgeif1: Tx timeout
 10831	[ 1559.097401] r8152 2-1:1.0 bridgeif1: Tx timeout
 10832	[ 1564.217596] r8152 2-1:1.0 bridgeif1: Tx timeout
 10833	[ 1569.337793] r8152 2-1:1.0 bridgeif1: Tx timeout
 10834	[ 1575.226025] r8152 2-1:1.0 bridgeif1: Tx timeout
 10835	[ 1580.154332] usb 2-1: reset high-speed USB device number 2 using ehci-platform
 10836	[ 1580.346228] r8152 2-1:1.0 bridgeif1: Tx timeout
 10837	[ 1586.234452] r8152 2-1:1.0 bridgeif1: Tx timeout
 10838	[ 1590.794665] usb 2-1: device not accepting address 2, error -110
 10839	[ 1590.926658] usb 2-1: reset high-speed USB device number 2 using ehci-platform
 10840	[ 1591.098639] r8152 2-1:1.0 bridgeif1: Tx timeout
 10841	[ 1591.350662] usb 2-1: device not accepting address 2, error -71
 10842	[ 1591.690677] usb 2-1: reset high-speed USB device number 2 using ehci-platform
 10843	[ 1596.218831] r8152 2-1:1.0 bridgeif1: Tx timeout
 10844	[ 1596.858874] usb 2-1: device descriptor read/64, error -110
 10845	[ 1601.339028] r8152 2-1:1.0 bridgeif1: Tx timeout
 10846	[ 1607.227257] r8152 2-1:1.0 bridgeif1: Tx timeout
 10847	[ 1612.347466] r8152 2-1:1.0 bridgeif1: Tx timeout
 10848	[ 1612.479473] usb 2-1: device descriptor read/64, error -110
 10849	[ 1612.719486] usb 2-1: reset high-speed USB device number 2 using ehci-platform
 10850	[ 1613.067489] usb 2-1: device descriptor read/64, error -71
 10851	[ 1618.235679] r8152 2-1:1.0 bridgeif1: Tx timeout
 10852	[ 1623.099860] r8152 2-1:1.0 bridgeif1: Tx timeout
 10853	[ 1628.220058] r8152 2-1:1.0 bridgeif1: Tx timeout
 10854	[ 1628.604091] usb 2-1: device descriptor read/64, error -110
 10855	[ 1628.716148] r8152 2-1:1.0 bridgeif1: Get ether addr fail
 10856	[ 1628.721491] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled
 10857	[ 1628.728148] usb 2-1: USB disconnect, device number 2
 10858	[ 1628.736033] device bridgeif1 left promiscuous mode
 10859	[ 1629.048173] usb 2-1: new high-speed USB device number 3 using ehci-platform
 10860	[ 1639.692512] usb 2-1: device not accepting address 3, error -110
 10861	[ 1639.824514] usb 2-1: new high-speed USB device number 4 using ehci-platform
 10862	[ 1640.248526] usb 2-1: device not accepting address 4, error -71
 10863	[ 1640.254411] usb usb2-port1: attempt power cycle
 10864	[ 1640.904546] usb 2-1: new high-speed USB device number 5 using ehci-platform
 10865	[ 1646.268756] usb 2-1: device descriptor read/64, error -110
 10866	[ 1661.885363] usb 2-1: device descriptor read/64, error -110
 10867	[ 1662.125384] usb 2-1: new high-speed USB device number 6 using ehci-platform
 10868	[ 1662.473360] usb 2-1: device descriptor read/64, error -71
 10869	[ 1678.013953] usb 2-1: device descriptor read/64, error -110
 10870	[ 1678.126003] usb usb2-port1: unable to enumerate USB device
 10871	[ 1678.517957] usb 6-1: new full-speed USB device number 2 using ohci-platform
 10872	[ 1694.202558] usb 6-1: device descriptor read/64, error -110
 10873	[ 1709.819134] usb 6-1: device descriptor read/64, error -110
 10874	[ 1710.119160] usb 6-1: new full-speed USB device number 3 using ohci-platform
 10875	[ 1725.691731] usb 6-1: device descriptor read/64, error -110
 10876	[ 1741.308300] usb 6-1: device descriptor read/64, error -110
 10877	[ 1741.420340] usb usb6-port1: attempt power cycle
 10878	[ 1741.924322] usb 6-1: new full-speed USB device number 4 using ohci-platform
 10879	[ 1752.592714] usb 6-1: device not accepting address 4, error -110
 10880	[ 1752.784726] usb 6-1: new full-speed USB device number 5 using ohci-platform
 10881	[ 1763.601125] usb 6-1: device not accepting address 5, error -110
 10882	[ 1763.607104] usb usb6-port1: unable to enumerate USB device
Full diagnostic dump:
Spoiler
  9737	### Activated 1 lzo zram swap devices with 499 MB each
  9738
  9739	### Activated Armbian ramlog partition with zstd compression
  9740
  9741	Wed Apr  8 12:38:57 EEST 2020 | NanoPi R1 | 20.02.1 | armhf | armv7l | 5.4.28-sunxi
  9742
  9743	### dmesg:
  9744
  9745	[    0.000000] Booting Linux on physical CPU 0x0
  9746	[    0.000000] Linux version 5.4.28-sunxi (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #20.02.7 SMP Sat Mar 28 14:32:15 CET 2020
  9747	[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
  9748	[    0.000000] CPU: div instructions available: patching division code
  9749	[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  9750	[    0.000000] OF: fdt: Machine model: FriendlyElec NanoPi-R1
  9751	[    0.000000] Memory policy: Data cache writealloc
  9752	[    0.000000] cma: Reserved 128 MiB at 0x77c00000
  9753	[    0.000000] On node 0 totalpages: 262144
  9754	[    0.000000]   Normal zone: 1728 pages used for memmap
  9755	[    0.000000]   Normal zone: 0 pages reserved
  9756	[    0.000000]   Normal zone: 196608 pages, LIFO batch:63
  9757	[    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
  9758	[    0.000000] psci: probing for conduit method from DT.
  9759	[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
  9760	[    0.000000] percpu: Embedded 20 pages/cpu s49868 r8192 d23860 u81920
  9761	[    0.000000] pcpu-alloc: s49868 r8192 d23860 u81920 alloc=20*4096
  9762	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  9763	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260416
  9764	[    0.000000] Kernel command line: root=UUID=ad129a81-43b8-45fb-8d5e-cb23d637385b rootwait rootfstype=ext4 console=ttyS1,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=44b42d1a-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
  9765	[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
  9766	[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
  9767	[    0.000000] allocated 1048576 bytes of page_ext
  9768	[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  9769	[    0.000000] Memory: 881824K/1048576K available (9216K kernel code, 1053K rwdata, 2880K rodata, 1024K init, 316K bss, 35680K reserved, 131072K cma-reserved, 131060K highmem)
  9770	[    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2b/0x3ac with crng_init=0
  9771	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  9772	[    0.000000] ftrace: allocating 41301 entries in 81 pages
  9773	[    0.000000] rcu: Hierarchical RCU implementation.
  9774	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  9775	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  9776	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  9777	[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
  9778	[    0.000000] GIC: Using split EOI/Deactivate mode
  9779	[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  9780	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  9781	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  9782	[    0.000011] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  9783	[    0.000028] Switching to timer-based delay loop, resolution 41ns
  9784	[    0.000392] Console: colour dummy device 80x30
  9785	[    0.000481] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  9786	[    0.000501] pid_max: default: 32768 minimum: 301
  9787	[    0.000895] LSM: Security Framework initializing
  9788	[    0.001057] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  9789	[    0.001080] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  9790	[    0.001222] *** VALIDATE tmpfs ***
  9791	[    0.002383] *** VALIDATE proc ***
  9792	[    0.002899] *** VALIDATE cgroup1 ***
  9793	[    0.002914] *** VALIDATE cgroup2 ***
  9794	[    0.003018] CPU: Testing write buffer coherency: ok
  9795	[    0.003692] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
  9796	[    0.004746] Setting up static identity map for 0x40100000 - 0x40100054
  9797	[    0.004956] rcu: Hierarchical SRCU implementation.
  9798	[    0.005931] smp: Bringing up secondary CPUs ...
  9799	[    0.017149] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
  9800	[    0.028590] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
  9801	[    0.039894] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
  9802	[    0.040074] smp: Brought up 1 node, 4 CPUs
  9803	[    0.040089] SMP: Total of 4 processors activated (192.00 BogoMIPS).
  9804	[    0.040096] CPU: All CPU(s) started in HYP mode.
  9805	[    0.040101] CPU: Virtualization extensions available.
  9806	[    0.041511] devtmpfs: initialized
  9807	[    0.054314] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
  9808	[    0.054759] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  9809	[    0.054791] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  9810	[    0.064019] xor: measuring software checksum speed
  9811	[    0.103995]    arm4regs  :   598.000 MB/sec
  9812	[    0.144105]    8regs     :   416.000 MB/sec
  9813	[    0.184231]    32regs    :   393.000 MB/sec
  9814	[    0.224358]    neon      :   605.000 MB/sec
  9815	[    0.224367] xor: using function: neon (605.000 MB/sec)
  9816	[    0.224481] pinctrl core: initialized pinctrl subsystem
  9817	[    0.226223] NET: Registered protocol family 16
  9818	[    0.229445] DMA: preallocated 256 KiB pool for atomic coherent allocations
  9819	[    0.230499] audit: initializing netlink subsys (disabled)
  9820	[    0.230815] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
  9821	[    0.231911] cpuidle: using governor ladder
  9822	[    0.231971] cpuidle: using governor menu
  9823	[    0.233069] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
  9824	[    0.233078] hw-breakpoint: maximum watchpoint size is 8 bytes.
  9825	[    0.357147] raid6: neonx8   gen()   337 MB/s
  9826	[    0.425193] raid6: neonx8   xor()   280 MB/s
  9827	[    0.493410] raid6: neonx4   gen()   346 MB/s
  9828	[    0.561497] raid6: neonx4   xor()   292 MB/s
  9829	[    0.629852] raid6: neonx2   gen()   316 MB/s
  9830	[    0.697852] raid6: neonx2   xor()   278 MB/s
  9831	[    0.766015] raid6: neonx1   gen()   235 MB/s
  9832	[    0.834268] raid6: neonx1   xor()   222 MB/s
  9833	[    0.902682] raid6: int32x8  gen()   127 MB/s
  9834	[    0.970676] raid6: int32x8  xor()    83 MB/s
  9835	[    1.038762] raid6: int32x4  gen()   135 MB/s
  9836	[    1.107006] raid6: int32x4  xor()    93 MB/s
  9837	[    1.175400] raid6: int32x2  gen()   122 MB/s
  9838	[    1.243404] raid6: int32x2  xor()    98 MB/s
  9839	[    1.311892] raid6: int32x1  gen()    95 MB/s
  9840	[    1.379650] raid6: int32x1  xor()    83 MB/s
  9841	[    1.379658] raid6: using algorithm neonx4 gen() 346 MB/s
  9842	[    1.379664] raid6: .... xor() 292 MB/s, rmw enabled
  9843	[    1.379672] raid6: using neon recovery algorithm
  9844	[    1.382191] iommu: Default domain type: Translated
  9845	[    1.382847] SCSI subsystem initialized
  9846	[    1.383202] libata version 3.00 loaded.
  9847	[    1.383716] usbcore: registered new interface driver usbfs
  9848	[    1.383800] usbcore: registered new interface driver hub
  9849	[    1.383946] usbcore: registered new device driver usb
  9850	[    1.384335] mc: Linux media interface: v0.10
  9851	[    1.384407] videodev: Linux video capture interface: v2.00
  9852	[    1.384628] pps_core: LinuxPPS API ver. 1 registered
  9853	[    1.384635] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  9854	[    1.384667] PTP clock support registered
  9855	[    1.387725] clocksource: Switched to clocksource arch_sys_counter
  9856	[    3.133124] *** VALIDATE bpf ***
  9857	[    3.133582] VFS: Disk quotas dquot_6.6.0
  9858	[    3.133713] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
  9859	[    3.133885] *** VALIDATE ramfs ***
  9860	[    3.148726] thermal_sys: Registered thermal governor 'fair_share'
  9861	[    3.148737] thermal_sys: Registered thermal governor 'bang_bang'
  9862	[    3.148748] thermal_sys: Registered thermal governor 'step_wise'
  9863	[    3.148756] thermal_sys: Registered thermal governor 'power_allocator'
  9864	[    3.149628] NET: Registered protocol family 2
  9865	[    3.150862] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
  9866	[    3.150920] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
  9867	[    3.151061] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
  9868	[    3.151294] TCP: Hash tables configured (established 8192 bind 8192)
  9869	[    3.151495] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
  9870	[    3.151586] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
  9871	[    3.152082] NET: Registered protocol family 1
  9872	[    3.153007] RPC: Registered named UNIX socket transport module.
  9873	[    3.153014] RPC: Registered udp transport module.
  9874	[    3.153021] RPC: Registered tcp transport module.
  9875	[    3.153027] RPC: Registered tcp NFSv4.1 backchannel transport module.
  9876	[    3.153486] Trying to unpack rootfs image as initramfs...
  9877	[    4.200819] Freeing initrd memory: 8472K
  9878	[    4.203262] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
  9879	[    4.205582] Initialise system trusted keyrings
  9880	[    4.205976] workingset: timestamp_bits=14 max_order=18 bucket_order=4
  9881	[    4.219268] zbud: loaded
  9882	[    4.223855] NFS: Registering the id_resolver key type
  9883	[    4.223901] Key type id_resolver registered
  9884	[    4.223908] Key type id_legacy registered
  9885	[    4.223930] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  9886	[    4.223939] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  9887	[    4.226607] JFS: nTxBlock = 7979, nTxLock = 63835
  9888	[    4.240999] SGI XFS with ACLs, security attributes, realtime, no debug enabled
  9889	[    4.334388] Key type asymmetric registered
  9890	[    4.334405] Asymmetric key parser 'x509' registered
  9891	[    4.334535] bounce: pool size: 64 pages
  9892	[    4.334639] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  9893	[    4.334994] io scheduler mq-deadline registered
  9894	[    4.335004] io scheduler kyber registered
  9895	[    4.335126] io scheduler bfq registered
  9896	[    4.346772] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
  9897	[    4.349827] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
  9898	[    4.361882] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  9899	[    4.366244] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
  9900	[    4.387224] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a U6_16550A
  9901	[    4.388078] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  9902	[    4.408922] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 43, base_baud = 1500000) is a U6_16550A
  9903	[    4.409022] printk: console [ttyS1] enabled
  9904	[    4.421298] brd: module loaded
  9905	[    4.433186] loop: module loaded
  9906	[    4.436322] libphy: Fixed MDIO Bus: probed
  9907	[    4.437616] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  9908	[    4.437933] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  9909	[    4.437948] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  9910	[    4.438144] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  9911	[    4.440164] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  9912	[    4.440173] ehci-platform: EHCI generic platform driver
  9913	[    4.440474] ehci-platform 1c1a000.usb: EHCI Host Controller
  9914	[    4.440524] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  9915	[    4.441076] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  9916	[    4.455717] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  9917	[    4.456238] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  9918	[    4.456255] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9919	[    4.456268] usb usb1: Product: EHCI Host Controller
  9920	[    4.456281] usb usb1: Manufacturer: Linux 5.4.28-sunxi ehci_hcd
  9921	[    4.456292] usb usb1: SerialNumber: 1c1a000.usb
  9922	[    4.457313] hub 1-0:1.0: USB hub found
  9923	[    4.457411] hub 1-0:1.0: 1 port detected
  9924	[    4.458427] ehci-platform 1c1b000.usb: EHCI Host Controller
  9925	[    4.458469] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
  9926	[    4.458779] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  9927	[    4.471715] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  9928	[    4.472183] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  9929	[    4.472199] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9930	[    4.472212] usb usb2: Product: EHCI Host Controller
  9931	[    4.472224] usb usb2: Manufacturer: Linux 5.4.28-sunxi ehci_hcd
  9932	[    4.472236] usb usb2: SerialNumber: 1c1b000.usb
  9933	[    4.473114] hub 2-0:1.0: USB hub found
  9934	[    4.473213] hub 2-0:1.0: 1 port detected
  9935	[    4.474210] ehci-platform 1c1c000.usb: EHCI Host Controller
  9936	[    4.474251] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
  9937	[    4.474533] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
  9938	[    4.487715] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
  9939	[    4.488134] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  9940	[    4.488151] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9941	[    4.488163] usb usb3: Product: EHCI Host Controller
  9942	[    4.488175] usb usb3: Manufacturer: Linux 5.4.28-sunxi ehci_hcd
  9943	[    4.488187] usb usb3: SerialNumber: 1c1c000.usb
  9944	[    4.489091] hub 3-0:1.0: USB hub found
  9945	[    4.489178] hub 3-0:1.0: 1 port detected
  9946	[    4.490072] ehci-platform 1c1d000.usb: EHCI Host Controller
  9947	[    4.490113] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 4
  9948	[    4.490409] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000
  9949	[    4.503716] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
  9950	[    4.504153] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  9951	[    4.504169] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9952	[    4.504182] usb usb4: Product: EHCI Host Controller
  9953	[    4.504194] usb usb4: Manufacturer: Linux 5.4.28-sunxi ehci_hcd
  9954	[    4.504205] usb usb4: SerialNumber: 1c1d000.usb
  9955	[    4.505064] hub 4-0:1.0: USB hub found
  9956	[    4.505163] hub 4-0:1.0: 1 port detected
  9957	[    4.506054] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  9958	[    4.506090] ohci-platform: OHCI generic platform driver
  9959	[    4.506432] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  9960	[    4.506473] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 5
  9961	[    4.506750] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  9962	[    4.568141] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  9963	[    4.568157] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9964	[    4.568170] usb usb5: Product: Generic Platform OHCI controller
  9965	[    4.568182] usb usb5: Manufacturer: Linux 5.4.28-sunxi ohci_hcd
  9966	[    4.568194] usb usb5: SerialNumber: 1c1a400.usb
  9967	[    4.569090] hub 5-0:1.0: USB hub found
  9968	[    4.569176] hub 5-0:1.0: 1 port detected
  9969	[    4.570083] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  9970	[    4.570122] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
  9971	[    4.570354] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  9972	[    4.632147] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  9973	[    4.632164] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9974	[    4.632177] usb usb6: Product: Generic Platform OHCI controller
  9975	[    4.632190] usb usb6: Manufacturer: Linux 5.4.28-sunxi ohci_hcd
  9976	[    4.632201] usb usb6: SerialNumber: 1c1b400.usb
  9977	[    4.633144] hub 6-0:1.0: USB hub found
  9978	[    4.633236] hub 6-0:1.0: 1 port detected
  9979	[    4.634144] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
  9980	[    4.634186] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
  9981	[    4.634425] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
  9982	[    4.696133] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  9983	[    4.696150] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9984	[    4.696163] usb usb7: Product: Generic Platform OHCI controller
  9985	[    4.696175] usb usb7: Manufacturer: Linux 5.4.28-sunxi ohci_hcd
  9986	[    4.696187] usb usb7: SerialNumber: 1c1c400.usb
  9987	[    4.697067] hub 7-0:1.0: USB hub found
  9988	[    4.697153] hub 7-0:1.0: 1 port detected
  9989	[    4.698090] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
  9990	[    4.698131] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
  9991	[    4.698360] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400
  9992	[    4.760145] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  9993	[    4.760163] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9994	[    4.760176] usb usb8: Product: Generic Platform OHCI controller
  9995	[    4.760188] usb usb8: Manufacturer: Linux 5.4.28-sunxi ohci_hcd
  9996	[    4.760199] usb usb8: SerialNumber: 1c1d400.usb
  9997	[    4.761089] hub 8-0:1.0: USB hub found
  9998	[    4.761187] hub 8-0:1.0: 1 port detected
  9999	[    4.763119] usbcore: registered new interface driver usb-storage
 10000	[    4.763790] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
 10001	[    4.767475] sun6i-rtc 1f00000.rtc: registered as rtc0
 10002	[    4.767490] sun6i-rtc 1f00000.rtc: RTC enabled
 10003	[    4.768068] i2c /dev entries driver
 10004	[    4.771889] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
 10005	[    4.773046] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
 10006	[    4.774277] sunxi-mmc 1c0f000.mmc: Got CD GPIO
 10007	[    4.799846] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
 10008	[    4.801990] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
 10009	[    4.811751] usb 2-1: new high-speed USB device number 2 using ehci-platform
 10010	[    4.828512] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
 10011	[    4.829436] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
 10012	[    4.831112] ledtrig-cpu: registered to indicate activity on CPUs
 10013	[    4.831247] hidraw: raw HID events driver (C) Jiri Kosina
 10014	[    4.831544] usbcore: registered new interface driver usbhid
 10015	[    4.831551] usbhid: USB HID core driver
 10016	[    4.835038] Initializing XFRM netlink socket
 10017	[    4.836219] NET: Registered protocol family 10
 10018	[    4.839796] usb 4-1: new high-speed USB device number 2 using ehci-platform
 10019	[    4.845736] usb 2-1: New USB device found, idVendor=0bda, idProduct=8152, bcdDevice=20.00
 10020	[    4.845756] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
 10021	[    4.845770] usb 2-1: Product: USB 10/100 LAN
 10022	[    4.845782] usb 2-1: Manufacturer: Realtek
 10023	[    4.845794] usb 2-1: SerialNumber: 000000000000
 10024	[    4.869877] usb 4-1: New USB device found, idVendor=2357, idProduct=0602, bcdDevice=20.00
 10025	[    4.869900] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
 10026	[    4.869913] usb 4-1: Product: USB 10/100 LAN
 10027	[    4.869926] usb 4-1: Manufacturer: TP-LINK
 10028	[    4.869938] usb 4-1: SerialNumber: D03745448C04
 10029	[    4.890478] Segment Routing with IPv6
 10030	[    4.890663] NET: Registered protocol family 17
 10031	[    4.890718] NET: Registered protocol family 15
 10032	[    4.890835] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
 10033	[    4.891211] 8021q: 802.1Q VLAN Support v1.8
 10034	[    4.891332] Key type dns_resolver registered
 10035	[    4.892274] Registering SWP/SWPB emulation handler
 10036	[    4.892794] registered taskstats version 1
 10037	[    4.892802] Loading compiled-in X.509 certificates
 10038	[    4.892978] zswap: loaded using pool lzo/zbud
 10039	[    4.893515] Key type ._fscrypt registered
 10040	[    4.893524] Key type .fscrypt registered
 10041	[    4.898880] Btrfs loaded, crc32c=crc32c-generic
 10042	[    4.924602] Key type encrypted registered
 10043	[    4.945499] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
 10044	[    4.948059] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
 10045	[    4.948077] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
 10046	[    4.948263] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
 10047	[    4.948468] dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator
 10048	[    4.975850] mmc1: new DDR MMC card at address 0001
 10049	[    4.977351] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
 10050	[    4.978143] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
 10051	[    4.978927] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
 10052	[    4.982195]  mmcblk1: p1 p2 p3
 10053	[    5.056129] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 50006 (expect 58000)
 10054	[    5.056179] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
 10055	[    5.056192] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
 10056	[    5.056204] dwmac-sun8i 1c30000.ethernet: COE Type 2
 10057	[    5.056215] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
 10058	[    5.056228] dwmac-sun8i 1c30000.ethernet: Normal descriptors
 10059	[    5.056239] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
 10060	[    5.056569] libphy: stmmac: probed
 10061	[    5.057951] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
 10062	[    5.058150] libphy: mdio_mux: probed
 10063	[    5.058190] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
 10064	[    5.058207] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
 10065	[    5.066973] ac200: Unknown symbol ac200_reg_mod (err -2)
 10066	[    5.067021] ac200: Unknown symbol ac200_reg_write (err -2)
 10067	[    5.068950] libphy: mdio_mux: probed
 10068	[    5.068997] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
 10069	[    5.084751] mmc0: host does not support reading read-only switch, assuming write-enable
 10070	[    5.086961] mmc0: new high speed SDHC card at address 0001
 10071	[    5.090416] mmcblk0: mmc0:0001 0008G 7.54 GiB
 10072	[    5.094310]  mmcblk0: p1
 10073	[    5.095273] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:10 UTC (10)
 10074	[    5.095609] of_cfs_init
 10075	[    5.095907] of_cfs_init: OK
 10076	[    5.103917] Freeing unused kernel memory: 1024K
 10077	[    5.124178] Run /init as init process
 10078	[    5.942561] random: fast init done
 10079	[    5.990978] dwmac-sun8i 1c30000.ethernet bridgeif0: renamed from eth0
 10080	[    6.029161] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
 10081	[    6.059137] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
 10082	[    6.086065] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
 10083	[    6.087740] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
 10084	[    6.089392] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
 10085	[    6.092396] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
 10086	[    6.096055] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
 10087	[    6.208707] mmc2: new high speed SDIO card at address 0001
 10088	[    6.875339] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 10089	[    7.726185] systemd[1]: System time before build time, advancing clock.
 10090	[    7.788801] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 10091	[    7.789668] systemd[1]: Detected architecture arm.
 10092	[    7.853242] systemd[1]: Set hostname to <N17.local>.
 10093	[    8.688486] random: systemd: uninitialized urandom read (16 bytes read)
 10094	[    8.688642] systemd[1]: Reached target Remote File Systems.
 10095	[    8.699992] random: systemd: uninitialized urandom read (16 bytes read)
 10096	[    8.700105] systemd[1]: Reached target Swap.
 10097	[    8.711983] random: systemd: uninitialized urandom read (16 bytes read)
 10098	[    8.712446] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
 10099	[    8.733922] systemd[1]: Created slice System Slice.
 10100	[    8.749635] systemd[1]: Created slice system-serial\x2dgetty.slice.
 10101	[    8.760541] systemd[1]: Listening on fsck to fsckd communication Socket.
 10102	[    8.772547] systemd[1]: Listening on Journal Socket (/dev/log).
 10103	[    9.047228] g_serial gadget: Gadget Serial v2.4
 10104	[    9.047251] g_serial gadget: g_serial ready
 10105	[    9.180913] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 10106	[    9.668554] systemd-journald[299]: Received request to flush runtime journal from PID 1
 10107	[   10.260184] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
 10108	[   10.260220] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000)
 10109	[   10.260392] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
 10110	[   10.260408] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000)
 10111	[   10.260622] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
 10112	[   10.260639] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000)
 10113	[   10.260926] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator
 10114	[   10.260950] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000)
 10115	[   10.331033] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
 10116	[   10.488093] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
 10117	[   10.500889] cedrus 1c0e000.video-codec: Device registered as /dev/video0
 10118	[   10.579370] cdc_ether 4-1:2.0 eth0: register 'cdc_ether' at usb-1c1d000.usb-1, CDC Ethernet Device, d0:37:45:44:8c:04
 10119	[   10.579628] usbcore: registered new interface driver cdc_ether
 10120	[   10.594947] usbcore: registered new interface driver r8152
 10121	[   10.708356] zram: Added device: zram0
 10122	[   10.709699] zram: Added device: zram1
 10123	[   10.710554] zram: Added device: zram2
 10124	[   10.731857] usb 2-1: reset high-speed USB device number 2 using ehci-platform
 10125	[   10.764074] lima 1c40000.gpu: IRQ ppmmu2 not found
 10126	[   10.769039] lima 1c40000.gpu: IRQ ppmmu3 not found
 10127	[   10.773943] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
 10128	[   10.774066] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
 10129	[   10.774127] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
 10130	[   10.774169] lima 1c40000.gpu: IRQ pp2 not found
 10131	[   10.778808] lima 1c40000.gpu: IRQ pp3 not found
 10132	[   10.783468] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
 10133	[   10.791363] r8152 2-1:1.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
 10134	[   10.800592] r8152 2-1:1.0 (unnamed net_device) (uninitialized): Random ether addr 6e:15:02:38:93:e7
 10135	[   10.831179] lima 1c40000.gpu: bus rate = 200000000
 10136	[   10.831199] lima 1c40000.gpu: mod rate = 384000000
 10137	[   10.835320] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 0
 10138	[   10.837711] r8152 2-1:1.0 eth1: v1.10.11
 10139	[   10.847392] zram1: detected capacity change from 0 to 523464704
 10140	[   11.159465] cdc_ether 4-1:2.0 ethext: renamed from eth0
 10141	[   11.266422] r8152 2-1:1.0 bridgeif1: renamed from eth1
 10142	[   11.563092] dwmac-sun8i 1c30000.ethernet bridgeif0: PHY [0.2:07] driver [RTL8211E Gigabit Ethernet]
 10143	[   11.564715] dwmac-sun8i 1c30000.ethernet bridgeif0: No Safety Features support found
 10144	[   11.564734] dwmac-sun8i 1c30000.ethernet bridgeif0: No MAC Management Counters available
 10145	[   11.564747] dwmac-sun8i 1c30000.ethernet bridgeif0: PTP not supported by HW
 10146	[   11.564766] dwmac-sun8i 1c30000.ethernet bridgeif0: configuring for phy/rgmii link mode
 10147	[   11.971902] Adding 511192k swap on /dev/zram1.  Priority:5 extents:1 across:511192k SSFS
 10148	[   12.150488] zram0: detected capacity change from 0 to 52428800
 10149	[   12.266235] device bridgeif0 entered promiscuous mode
 10150	[   12.291896] device bridgeif1 entered promiscuous mode
 10151	[   12.446651] br0: Slave A (bridgeif0) is not up; please bring it up to get a fully working HSR network
 10152	[   12.446976] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
 10153	[   12.496994] random: crng init done
 10154	[   12.497016] random: 7 urandom warning(s) missed due to ratelimiting
 10155	[   12.670378] IPv6: ADDRCONF(NETDEV_CHANGE): bridgeif1: link becomes ready
 10156	[   12.671028] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled
 10157	[   12.673230] r8152 2-1:1.0 bridgeif1: carrier on
 10158	[   12.675782] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled
 10159	[   12.874553] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
 10160	[   12.874606] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 10161	[   14.648321] dwmac-sun8i 1c30000.ethernet bridgeif0: Link is Up - 100Mbps/Full - flow control off
 10162	[   14.648373] IPv6: ADDRCONF(NETDEV_CHANGE): bridgeif0: link becomes ready
 10163
 10164	### armbian-release:
 10165
 10166	# PLEASE DO NOT EDIT THIS FILE
 10167	BOARD=nanopi-r1
 10168	BOARD_NAME="NanoPi R1"
 10169	BOARDFAMILY=sun8i
 10170	BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin
 10171	BUILD_REPOSITORY_COMMIT=3e533c9
 10172	DISTRIBUTION_CODENAME=bionic
 10173	DISTRIBUTION_STATUS=supported
 10174	VERSION=20.02.1
 10175	LINUXFAMILY=sunxi
 10176	BRANCH=current
 10177	ARCH=arm
 10178	IMAGE_TYPE=stable
 10179	BOARD_TYPE=conf
 10180	INITRD_ARCH=arm
 10181	KERNEL_IMAGE_TYPE=Image
 10182
 10183	### boot environment:
 10184
 10185	verbosity=1
 10186	logo=disabled
 10187	console=serial
 10188	disp_mode=1920x1080p60
 10189	overlay_prefix=sun8i-h3
 10190	overlays=usbhost0 usbhost1 uart1
 10191	rootdev=UUID=ad129a81-43b8-45fb-8d5e-cb23d637385b
 10192	rootfstype=ext4
 10193	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 10194
 10195	### lsusb:
 10196
 10197	Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
 10198	Bus 004 Device 002: ID 2357:0602
 10199	Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 10200	Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
 10201	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 10202	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
 10203	Bus 002 Device 002: ID 0bda:8152 Realtek Semiconductor Corp.
 10204	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 10205	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
 10206	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 10207
 10208	### lscpu:
 10209
 10210	Architecture:        armv7l
 10211	Byte Order:          Little Endian
 10212	CPU(s):              4
 10213	On-line CPU(s) list: 0-3
 10214	Thread(s) per core:  1
 10215	Core(s) per socket:  4
 10216	Socket(s):           1
 10217	Vendor ID:           ARM
 10218	Model:               5
 10219	Model name:          Cortex-A7
 10220	Stepping:            r0p5
 10221	CPU max MHz:         1008.0000
 10222	CPU min MHz:         480.0000
 10223	BogoMIPS:            100.80
 10224	Flags:               half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
 10225
 10226	### cpuinfo:
 10227
 10228	processor	: 0
 10229	model name	: ARMv7 Processor rev 5 (v7l)
 10230	BogoMIPS	: 100.80
 10231	Features	: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
 10232	CPU implementer	: 0x41
 10233	CPU architecture: 7
 10234	CPU variant	: 0x0
 10235	CPU part	: 0xc07
 10236	CPU revision	: 5
 10237
 10238	processor	: 1
 10239	model name	: ARMv7 Processor rev 5 (v7l)
 10240	BogoMIPS	: 100.80
 10241	Features	: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
 10242	CPU implementer	: 0x41
 10243	CPU architecture: 7
 10244	CPU variant	: 0x0
 10245	CPU part	: 0xc07
 10246	CPU revision	: 5
 10247
 10248	processor	: 2
 10249	model name	: ARMv7 Processor rev 5 (v7l)
 10250	BogoMIPS	: 100.80
 10251	Features	: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
 10252	CPU implementer	: 0x41
 10253	CPU architecture: 7
 10254	CPU variant	: 0x0
 10255	CPU part	: 0xc07
 10256	CPU revision	: 5
 10257
 10258	processor	: 3
 10259	model name	: ARMv7 Processor rev 5 (v7l)
 10260	BogoMIPS	: 100.80
 10261	Features	: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
 10262	CPU implementer	: 0x41
 10263	CPU architecture: 7
 10264	CPU variant	: 0x0
 10265	CPU part	: 0xc07
 10266	CPU revision	: 5
 10267
 10268	Hardware	: Allwinner sun8i Family
 10269	Revision	: 0000
 10270	Serial		: 02c00181d27f68b2
 10271
 10272	### meminfo:
 10273
 10274	MemTotal:        1022392 kB
 10275	MemFree:          872560 kB
 10276	MemAvailable:     934480 kB
 10277	Buffers:            9840 kB
 10278	Cached:            62304 kB
 10279	SwapCached:            0 kB
 10280	Active:            49064 kB
 10281	Inactive:          43700 kB
 10282	Active(anon):      20888 kB
 10283	Inactive(anon):     2828 kB
 10284	Active(file):      28176 kB
 10285	Inactive(file):    40872 kB
 10286	Unevictable:           0 kB
 10287	Mlocked:               0 kB
 10288	HighTotal:        262132 kB
 10289	HighFree:         162276 kB
 10290	LowTotal:         760260 kB
 10291	LowFree:          710284 kB
 10292	SwapTotal:        511192 kB
 10293	SwapFree:         511192 kB
 10294	Dirty:             15940 kB
 10295	Writeback:          1000 kB
 10296	AnonPages:         20724 kB
 10297	Mapped:            18452 kB
 10298	Shmem:              3032 kB
 10299	KReclaimable:      12044 kB
 10300	Slab:              29992 kB
 10301	SReclaimable:      12044 kB
 10302	SUnreclaim:        17948 kB
 10303	KernelStack:        1128 kB
 10304	PageTables:          896 kB
 10305	NFS_Unstable:          0 kB
 10306	Bounce:                0 kB
 10307	WritebackTmp:          0 kB
 10308	CommitLimit:     1022388 kB
 10309	Committed_AS:     139184 kB
 10310	VmallocTotal:     245760 kB
 10311	VmallocUsed:       14568 kB
 10312	VmallocChunk:          0 kB
 10313	Percpu:              464 kB
 10314	CmaTotal:         131072 kB
 10315	CmaFree:          130720 kB
 10316
 10317	### virtual memory:
 10318
 10319	vm.admin_reserve_kbytes = 8192
 10320	vm.block_dump = 0
 10321	vm.compact_unevictable_allowed = 1
 10322	vm.dirty_background_bytes = 0
 10323	vm.dirty_background_ratio = 10
 10324	vm.dirty_bytes = 0
 10325	vm.dirty_expire_centisecs = 3000
 10326	vm.dirty_ratio = 20
 10327	vm.dirtytime_expire_seconds = 43200
 10328	vm.dirty_writeback_centisecs = 500
 10329	vm.extfrag_threshold = 500
 10330	vm.highmem_is_dirtyable = 0
 10331	vm.laptop_mode = 0
 10332	vm.legacy_va_layout = 0
 10333	vm.lowmem_reserve_ratio = 32	0	0
 10334	vm.max_map_count = 65530
 10335	vm.min_free_kbytes = 3465
 10336	vm.mmap_min_addr = 32768
 10337	vm.mmap_rnd_bits = 8
 10338	vm.oom_dump_tasks = 1
 10339	vm.oom_kill_allocating_task = 0
 10340	vm.overcommit_kbytes = 0
 10341	vm.overcommit_memory = 0
 10342	vm.overcommit_ratio = 50
 10343	vm.page-cluster = 0
 10344	vm.panic_on_oom = 0
 10345	vm.percpu_pagelist_fraction = 0
 10346	vm.stat_interval = 1
 10347	vm.swappiness = 100
 10348	vm.user_reserve_kbytes = 31523
 10349	vm.vfs_cache_pressure = 100
 10350	vm.watermark_boost_factor = 15000
 10351	vm.watermark_scale_factor = 10
 10352
 10353	### ip addr:
 10354
 10355	default via XXX.XXX.1.1 dev ethext
 10356	default dev br0 scope link metric 1005
 10357	XXX.XXX.0.0/16 dev br0 proto kernel scope link src XXX.XXX.9.189
 10358	XXX.XXX.0.0/16 dev ethext scope link metric 1000
 10359	XXX.XXX.1.0/24 dev ethext proto kernel scope link src XXX.XXX.1.60
 10360	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 10361	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 10362	    inet XXX.XXX.0.1/8 scope host lo
 10363	       valid_lft forever preferred_lft forever
 10364	    inet6 ::1/128 scope host
 10365	       valid_lft forever preferred_lft forever
 10366	2: bridgeif0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
 10367	    link/ether 12:81:d2:7f:68:b2 brd ff:ff:ff:ff:ff:ff
 10368	    inet6 fe80::1081:d2ff:fe7f:68b2/64 scope link
 10369	       valid_lft forever preferred_lft forever
 10370	3: ethext: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
 10371	    link/ether d0:37:45:44:8c:04 brd ff:ff:ff:ff:ff:ff
 10372	    inet XXX.XXX.1.60/24 brd XXX.XXX.1.255 scope global ethext
 10373	       valid_lft forever preferred_lft forever
 10374	    inet6 fe80::d237:45ff:fe44:8c04/64 scope link
 10375	       valid_lft forever preferred_lft forever
 10376	4: bridgeif1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
 10377	    link/ether 6e:15:02:38:93:e7 brd ff:ff:ff:ff:ff:ff
 10378	    inet6 fe80::6c15:2ff:fe38:93e7/64 scope link
 10379	       valid_lft forever preferred_lft forever
 10380	5: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1494 qdisc noqueue state UP group default qlen 1000
 10381	    link/ether 12:81:d2:7f:68:b2 brd ff:ff:ff:ff:ff:ff
 10382	    inet XXX.XXX.9.189/16 brd XXX.XXX.255.255 scope link br0:avahi
 10383	       valid_lft forever preferred_lft forever
 10384	    inet6 fe80::1081:d2ff:fe7f:68b2/64 scope link
 10385	       valid_lft forever preferred_lft forever
 10386
 10387	### partitions:
 10388
 10389	major minor  #blocks  name
 10390
 10391	 179        0    7634944 mmcblk1
 10392	 179        1      40960 mmcblk1p1
 10393	 179        2    1221632 mmcblk1p2
 10394	 179        3    6347776 mmcblk1p3
 10395	 179       24    7901184 mmcblk0
 10396	 179       25    7739056 mmcblk0p1
 10397	 254        0      51200 zram0
 10398	 254        1     511196 zram1
 10399
 10400	### df:
 10401
 10402	udev            431M     0  431M   0% /dev
 10403	tmpfs           100M  3.0M   97M   3% /run
 10404	/dev/mmcblk0p1  7.3G  938M  6.3G  13% /
 10405	tmpfs           500M     0  500M   0% /dev/shm
 10406	tmpfs           5.0M     0  5.0M   0% /run/lock
 10407	tmpfs           500M     0  500M   0% /sys/fs/cgroup
 10408	tmpfs           500M  4.0K  500M   1% /tmp
 10409	/dev/zram0       49M   18M   28M  39% /var/log
 10410
 10411	### lsblk:
 10412
 10413	NAME         FSTYPE   SIZE MOUNTPOINT UUID
 10414	mmcblk1               7.3G
 10415	├─mmcblk1p1  vfat      40M            D45E-0C11
 10416	├─mmcblk1p2  ext4     1.2G            ff313567-e9f1-5a5d-9895-3ba130b4a864
 10417	└─mmcblk1p3  ext4     6.1G            269e9152-5cb6-035b-9c34-e1ed87cca310
 10418	mmcblk1boot0            4M
 10419	mmcblk1boot1            4M
 10420	mmcblk0               7.5G
 10421	└─mmcblk0p1  ext4     7.4G /          ad129a81-43b8-45fb-8d5e-cb23d637385b
 10422	zram0                  50M /var/log
 10423
 10424	### zramctl:
 10425
 10426	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 10427	/dev/zram1 lzo         499.2M    4K   76B    4K       4 [SWAP]
 10428	/dev/zram0                50M 13.4M  2.8M  3.2M       4 /var/log
 10429
 10430	### mtab:
 10431
 10432	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 10433	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 10434	/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
 10435
 10436	### mmc1:0001 info:
 10437
 10438	              manfid: 0x000015
 10439	                 cid: 15010038475446345206d2ffc66676f3
 10440	               fwrev: 0x0600000000000000
 10441	                 rca: 0x0001
 10442	                 csd: d02701320f5903fff6dbffef8e40400d
 10443	           life_time: 0x01 0x01
 10444	                 ocr: 0x00200000
 10445	                type: MMC
 10446	enhanced_area_offset: 18446744073709551594
 10447	                date: 07/2019
 10448	               hwrev: 0x0
 10449	                 prv: 0x6
 10450	                 dsr: 0x404
 10451	         ffu_capable: 1
 10452	              serial: 0xd2ffc666
 10453	  raw_rpmb_size_mult: 0x4
 10454	          erase_size: 524288
 10455	        pre_eol_info: 0x01
 10456	         rel_sectors: 0x1
 10457	             cmdq_en: 0
 10458	              uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8GTF4R MODALIAS=mmc:block
 10459	  enhanced_area_size: 4294967274
 10460	               oemid: 0x0100
 10461	                 rev: 0x8
 10462	preferred_erase_size: 4194304
 10463	                name: 8GTF4R
 10464
 10465	### mmc0:0001 info:
 10466
 10467	              manfid: 0x00005d
 10468	                 cid: 5d5342303030384711c503078701389f
 10469	               fwrev: 0x1
 10470	                 rca: 0x0001
 10471	                 csd: 400e00325b5900003c477f800a4000db
 10472	                 ocr: 0x00200000
 10473	                type: SD
 10474	                date: 08/2019
 10475	               hwrev: 0x1
 10476	                 dsr: 0x404
 10477	              serial: 0xc5030787
 10478	          erase_size: 512
 10479	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=0008G MODALIAS=mmc:block
 10480	                 ssr: 0000000003000000040590000105190000000000000000000001000a00ab00ab64640000027e8e6500000000003f0000000019bd0008002e000000641601252a
 10481	                 scr: 02b5800300000000
 10482	               oemid: 0x5342
 10483	preferred_erase_size: 4194304
 10484	                name: 0008G
 10485
 10486	### Boot system health:
 10487
 10488	Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 10489	12:39:02: 1008MHz  0.83  62%  36%  22%   0%   2%   0% 34.4°C  0/4
 10490	12:39:02:  480MHz  0.83   9%   7%   0%   0%   0%   0% 33.3°C  0/4
 10491	12:39:03: 1008MHz  0.84   8%   6%   0%   2%   0%   0% 32.6°C  0/4
 10492	12:39:03: 1008MHz  0.84   6%   4%   0%   2%   0%   0% 32.6°C  0/4
 10493	12:39:03: 1008MHz  0.84   7%   5%   0%   1%   0%   0% 32.2°C  0/4
 10494
 10495	### lsusb:
 10496
 10497	Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
 10498	Bus 004 Device 002: ID 2357:0602
 10499	Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 10500	Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
 10501	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 10502	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
 10503	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 10504	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
 10505	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 10506
 10507	/:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
 10508	/:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
 10509	/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
 10510	/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
 10511	/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
 10512	    |__ Port 1: Dev 2, If 0, Class=Communications, Driver=cdc_ether, 480M
 10513	    |__ Port 1: Dev 2, If 1, Class=CDC Data, Driver=cdc_ether, 480M
 10514	/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
 10515	/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
 10516	/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
 10517
 10518	### Group membership of esmi : esmi tty disk dialout sudo audio video plugdev games users systemd-journal input netdev ssh
 10519
 10520	### Installed packages:
 10521
 10522	ii  armbian-config                      20.02.9                             all          Armbian configuration utility
 10523	ii  armbian-firmware                    20.02.4                             all          Linux firmware
 10524	ii  hostapd                             3:2.7-99~armbian5.86+1              armhf        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
 10525	ii  linux-base                          4.5ubuntu1.1                        all          Linux image base package
 10526	ii  linux-bionic-root-current-nanopi-r1 20.02.1                             armhf        Armbian tweaks for bionic on nanopi-r1 (current branch)
 10527	ii  linux-dtb-current-sunxi             20.02.7                             armhf        Linux DTB, version 5.4.28-sunxi
 10528	ii  linux-image-current-sunxi           20.02.7                             armhf        Linux kernel, version 5.4.28-sunxi
 10529	ii  linux-libc-dev:armhf                4.15.0-91.92                        armhf        Linux Kernel Headers for development
 10530	ii  linux-u-boot-nanopi-r1-current      20.02.1                             armhf        Uboot loader 2019.10
 10531	ii  sunxi-tools                         1.4.2-2~armbian5.86+1               armhf        tools for working with Allwinner (sunxi) ARM processors
 10532
 10533	### Loaded modules:
 10534
 10535	Module                  Size  Used by
 10536	hsr                    28672  0
 10537	evdev                  20480  0
 10538	lima                   36864  0
 10539	gpu_sched              24576  1 lima
 10540	snd_soc_simple_card    16384  0
 10541	snd_soc_simple_card_utils    16384  1 snd_soc_simple_card
 10542	zram                   24576  2
 10543	sun8i_codec_analog     24576  0
 10544	sun8i_adda_pr_regmap    16384  1 sun8i_codec_analog
 10545	sun4i_i2s              24576  0
 10546	sun4i_gpadc_iio        16384  0
 10547	snd_soc_core          118784  4 sun4i_i2s,sun8i_codec_analog,snd_soc_simple_card_utils,snd_soc_simple_card
 10548	industrialio           49152  1 sun4i_gpadc_iio
 10549	snd_pcm_dmaengine      16384  1 snd_soc_core
 10550	snd_pcm                65536  3 sun4i_i2s,snd_pcm_dmaengine,snd_soc_core
 10551	r8152                  53248  0
 10552	snd_timer              24576  1 snd_pcm
 10553	snd                    45056  3 snd_timer,snd_soc_core,snd_pcm
 10554	cdc_ether              16384  0
 10555	sun8i_thermal          16384  0
 10556	soundcore              16384  1 snd
 10557	usbnet                 24576  1 cdc_ether
 10558	sunxi_cedrus           32768  0
 10559	v4l2_mem2mem           20480  1 sunxi_cedrus
 10560	gpio_keys              20480  0
 10561	uio_pdrv_genirq        16384  0
 10562	uio                    16384  1 uio_pdrv_genirq
 10563	cpufreq_dt             16384  0
 10564	sch_fq_codel           20480  3
 10565	usb_f_acm              16384  1
 10566	u_serial               20480  3 usb_f_acm
 10567	g_serial               16384  0
 10568	libcomposite           40960  2 g_serial,usb_f_acm
 10569	ip_tables              24576  0
 10570	x_tables               20480  1 ip_tables
 10571	pwrseq_simple          16384  1
 10572	realtek                16384  1
 10573
 10574	### Current system health:
 10575
 10576	Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 10577	23:03:59: 1008MHz  0.08   0%   0%   0%   0%   0%   0% 32.6°C  0/4
 10578	23:04:00: 1008MHz  0.08   6%   4%   0%   2%   0%   0% 31.6°C  0/4
 10579	23:04:00: 1008MHz  0.08   6%   3%   0%   2%   0%   0% 31.7°C  0/4
 10580	23:04:01: 1008MHz  0.08   6%   5%   0%   1%   0%   0% 31.6°C  0/4
 10581	23:04:01: 1008MHz  0.08   6%   5%   0%   1%   0%   0% 30.6°C  0/4
 10582	23:04:04: 1008MHz  0.08   0%   0%   0%   0%   0%   0% 38.0°C  0/4
 10583	23:04:05: 1008MHz  0.47  77%   1%  75%   0%   0%   0% 34.5°C  0/4
 10584	23:04:05: 1008MHz  0.47   6%   4%   0%   1%   0%   0% 33.4°C  0/4
 10585	23:04:06: 1008MHz  0.47   7%   5%   0%   1%   0%   0% 32.7°C  0/4
 10586	23:04:06: 1008MHz  0.47   6%   4%   0%   1%   0%   0% 32.4°C  0/4
 10587
 10588	### resolv.conf
 10589
 10590	-rw-r--r-- 1 root root 70 Apr  6 22:06 /etc/resolv.conf
 10591	# Generated by NetworkManager
 10592	search N17.local
 10593	nameserver XXX.XXX.1.1
 10594
 10595	### Current sysinfo:
 10596
 10597	Linux 5.4.28-sunxi (N17.local) 	04/11/2020 	_armv7l_	(4 CPU)
 10598
 10599	avg-cpu:  %user   %nice %system %iowait  %steal   %idle
 10600	           0.03    0.00    0.09    0.00    0.00   99.88
 10601
 10602	Device             tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
 10603	ram0              0.00         0.00         0.00          0          0
 10604	ram1              0.00         0.00         0.00          0          0
 10605	ram2              0.00         0.00         0.00          0          0
 10606	ram3              0.00         0.00         0.00          0          0
 10607	mmcblk1           0.00         0.03         0.00      10168          0
 10608	mmcblk1p1         0.00         0.00         0.00        852          0
 10609	mmcblk1p2         0.00         0.01         0.00       3096          0
 10610	mmcblk1p3         0.00         0.02         0.00       4644          0
 10611	mmcblk1boot1      0.00         0.00         0.00        216          0
 10612	mmcblk1boot0      0.00         0.00         0.00        216          0
 10613	mmcblk0           0.01         0.34         0.21     100089      62524
 10614	mmcblk0p1         0.01         0.33         0.21      96965      62524
 10615	zram0             0.03         0.00         0.11        712      32468
 10616	zram1             0.00         0.00         0.00       1196          4
 10617	zram2             0.00         0.00         0.00          0          0
 10618
 10619	procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
 10620	 r  b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
 10621	 0  0            0       818260        11896       111136    0    0     0     0   26   23   0   0 100   0   0
 10622
 10623	              total        used        free      shared  buff/cache   available
 10624	Mem:           998M         79M        799M         10M        120M        886M
 10625	Swap:          499M          0B        499M
 10626
 10627	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 10628	/dev/zram1 lzo         499.2M    4K   76B    4K       4 [SWAP]
 10629	/dev/zram0                50M 17.5M  3.6M  4.1M       4 /var/log
 10630
 10631	 23:04:11 up 3 days, 10:25,  1 user,  load average: 0.44, 0.10, 0.03
 10632
 10633	[    8.688642] systemd[1]: Reached target Remote File Systems.
 10634	[    8.699992] random: systemd: uninitialized urandom read (16 bytes read)
 10635	[    8.700105] systemd[1]: Reached target Swap.
 10636	[    8.711983] random: systemd: uninitialized urandom read (16 bytes read)
 10637	[    8.712446] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
 10638	[    8.733922] systemd[1]: Created slice System Slice.
 10639	[    8.749635] systemd[1]: Created slice system-serial-getty.slice.
 10640	[    8.760541] systemd[1]: Listening on fsck to fsckd communication Socket.
 10641	[    8.772547] systemd[1]: Listening on Journal Socket (/dev/log).
 10642	[    9.047228] g_serial gadget: Gadget Serial v2.4
 10643	[    9.047251] g_serial gadget: g_serial ready
 10644	[    9.180913] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 10645	[    9.668554] systemd-journald[299]: Received request to flush runtime journal from PID 1
 10646	[   10.260184] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
 10647	[   10.260220] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000)
 10648	[   10.260392] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
 10649	[   10.260408] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000)
 10650	[   10.260622] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
 10651	[   10.260639] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000)
 10652	[   10.260926] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator
 10653	[   10.260950] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000)
 10654	[   10.331033] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
 10655	[   10.488093] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
 10656	[   10.500889] cedrus 1c0e000.video-codec: Device registered as /dev/video0
 10657	[   10.579370] cdc_ether 4-1:2.0 eth0: register 'cdc_ether' at usb-1c1d000.usb-1, CDC Ethernet Device, d0:37:45:44:8c:04
 10658	[   10.579628] usbcore: registered new interface driver cdc_ether
 10659	[   10.594947] usbcore: registered new interface driver r8152
 10660	[   10.708356] zram: Added device: zram0
 10661	[   10.709699] zram: Added device: zram1
 10662	[   10.710554] zram: Added device: zram2
 10663	[   10.731857] usb 2-1: reset high-speed USB device number 2 using ehci-platform
 10664	[   10.764074] lima 1c40000.gpu: IRQ ppmmu2 not found
 10665	[   10.769039] lima 1c40000.gpu: IRQ ppmmu3 not found
 10666	[   10.773943] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
 10667	[   10.774066] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
 10668	[   10.774127] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
 10669	[   10.774169] lima 1c40000.gpu: IRQ pp2 not found
 10670	[   10.778808] lima 1c40000.gpu: IRQ pp3 not found
 10671	[   10.783468] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
 10672	[   10.791363] r8152 2-1:1.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
 10673	[   10.800592] r8152 2-1:1.0 (unnamed net_device) (uninitialized): Random ether addr 6e:15:02:38:93:e7
 10674	[   10.831179] lima 1c40000.gpu: bus rate = 200000000
 10675	[   10.831199] lima 1c40000.gpu: mod rate = 384000000
 10676	[   10.835320] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 0
 10677	[   10.837711] r8152 2-1:1.0 eth1: v1.10.11
 10678	[   10.847392] zram1: detected capacity change from 0 to 523464704
 10679	[   11.159465] cdc_ether 4-1:2.0 ethext: renamed from eth0
 10680	[   11.266422] r8152 2-1:1.0 bridgeif1: renamed from eth1
 10681	[   11.563092] dwmac-sun8i 1c30000.ethernet bridgeif0: PHY [0.2:07] driver [RTL8211E Gigabit Ethernet]
 10682	[   11.564715] dwmac-sun8i 1c30000.ethernet bridgeif0: No Safety Features support found
 10683	[   11.564734] dwmac-sun8i 1c30000.ethernet bridgeif0: No MAC Management Counters available
 10684	[   11.564747] dwmac-sun8i 1c30000.ethernet bridgeif0: PTP not supported by HW
 10685	[   11.564766] dwmac-sun8i 1c30000.ethernet bridgeif0: configuring for phy/rgmii link mode
 10686	[   11.971902] Adding 511192k swap on /dev/zram1.  Priority:5 extents:1 across:511192k SSFS
 10687	[   12.150488] zram0: detected capacity change from 0 to 52428800
 10688	[   12.266235] device bridgeif0 entered promiscuous mode
 10689	[   12.291896] device bridgeif1 entered promiscuous mode
 10690	[   12.446651] br0: Slave A (bridgeif0) is not up; please bring it up to get a fully working HSR network
 10691	[   12.446976] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
 10692	[   12.496994] random: crng init done
 10693	[   12.497016] random: 7 urandom warning(s) missed due to ratelimiting
 10694	[   12.670378] IPv6: ADDRCONF(NETDEV_CHANGE): bridgeif1: link becomes ready
 10695	[   12.671028] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled
 10696	[   12.673230] r8152 2-1:1.0 bridgeif1: carrier on
 10697	[   12.675782] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled
 10698	[   12.874553] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
 10699	[   12.874606] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 10700	[   14.648321] dwmac-sun8i 1c30000.ethernet bridgeif0: Link is Up - 100Mbps/Full - flow control off
 10701	[   14.648373] IPv6: ADDRCONF(NETDEV_CHANGE): bridgeif0: link becomes ready
 10702	[   15.880578] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled
 10703	[   16.696122] dwmac-sun8i 1c30000.ethernet bridgeif0: Link is Down
 10704	[   19.768218] dwmac-sun8i 1c30000.ethernet bridgeif0: Link is Up - 100Mbps/Full - flow control rx/tx
 10705	[   35.831768] vcc3v0: disabling
 10706	[   35.831791] vcc5v0: disabling
 10707	[ 1063.202413] ------------[ cut here ]------------
 10708	[ 1063.202481] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:448 dev_watchdog+0x213/0x214
 10709	[ 1063.202500] NETDEV WATCHDOG: bridgeif1 (r8152): transmit queue 0 timed out
 10710	[ 1063.202506] Modules linked in: hsr evdev lima gpu_sched snd_soc_simple_card snd_soc_simple_card_utils zram sun8i_codec_analog sun8i_adda_pr_regmap sun4i_i2s sun4i_gpadc_iio snd_soc_core industrialio snd_pcm_dmaengine snd_pcm r8152 snd_timer snd cdc_ether sun8i_thermal soundcore usbnet sunxi_cedrus(C) v4l2_mem2mem gpio_keys uio_pdrv_genirq uio cpufreq_dt sch_fq_codel usb_f_acm u_serial g_serial libcomposite ip_tables x_tables pwrseq_simple realtek
 10711	[ 1063.202605] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G         C        5.4.28-sunxi #20.02.7
 10712	[ 1063.202610] Hardware name: Allwinner sun8i Family
 10713	[ 1063.202640] [<c010da8d>] (unwind_backtrace) from [<c010a0ad>] (show_stack+0x11/0x14)
 10714	[ 1063.202661] [<c010a0ad>] (show_stack) from [<c0951bef>] (dump_stack+0x6f/0x7c)
 10715	[ 1063.202687] [<c0951bef>] (dump_stack) from [<c011b60b>] (__warn+0xb7/0xb8)
 10716	[ 1063.202702] [<c011b60b>] (__warn) from [<c011b8b7>] (warn_slowpath_fmt+0x5f/0x74)
 10717	[ 1063.202716] [<c011b8b7>] (warn_slowpath_fmt) from [<c0850083>] (dev_watchdog+0x213/0x214)
 10718	[ 1063.202740] [<c0850083>] (dev_watchdog) from [<c017209b>] (call_timer_fn+0x27/0x128)
 10719	[ 1063.202752] [<c017209b>] (call_timer_fn) from [<c0172c15>] (run_timer_softirq+0x3f9/0x418)
 10720	[ 1063.202763] [<c0172c15>] (run_timer_softirq) from [<c01022f7>] (__do_softirq+0xdf/0x288)
 10721	[ 1063.202775] [<c01022f7>] (__do_softirq) from [<c012035f>] (irq_exit+0x7b/0x90)
 10722	[ 1063.202792] [<c012035f>] (irq_exit) from [<c016051f>] (__handle_domain_irq+0x47/0x84)
 10723	[ 1063.202812] [<c016051f>] (__handle_domain_irq) from [<c05e3c4d>] (gic_handle_irq+0x39/0x6c)
 10724	[ 1063.202829] [<c05e3c4d>] (gic_handle_irq) from [<c0101ae5>] (__irq_svc+0x65/0x94)
 10725	[ 1063.202841] Exception stack(0xc0f01f20 to 0xc0f01f68)
 10726	[ 1063.202855] 1f20: 00000000 0050f000 ef69ff34 c0116341 ffffe000 c0f04f68 c0f04fb0 00000001
 10727	[ 1063.202865] 1f40: c0f04f48 00000000 c0ec48f0 c0ff67f6 c0f05028 c0f01f70 c010792f c0107930
 10728	[ 1063.202869] 1f60: 400d0033 ffffffff
 10729	[ 1063.202886] [<c0101ae5>] (__irq_svc) from [<c0107930>] (arch_cpu_idle+0x28/0x2c)
 10730	[ 1063.202900] [<c0107930>] (arch_cpu_idle) from [<c013fa4f>] (do_idle+0x15b/0x1cc)
 10731	[ 1063.202912] [<c013fa4f>] (do_idle) from [<c013fcb9>] (cpu_startup_entry+0x19/0x20)
 10732	[ 1063.202932] [<c013fcb9>] (cpu_startup_entry) from [<c0e00c6d>] (start_kernel+0x3fb/0x40c)
 10733	[ 1063.202948] ---[ end trace 8a7042696d164652 ]---
 10734	[ 1063.202968] r8152 2-1:1.0 bridgeif1: Tx timeout
 10735	[ 1064.777084] r8152 2-1:1.0 bridgeif1: Tx status -2
 10736	[ 1064.780443] r8152 2-1:1.0 bridgeif1: Tx status -2
 10737	[ 1064.783815] r8152 2-1:1.0 bridgeif1: Tx status -2
 10738	[ 1064.787064] r8152 2-1:1.0 bridgeif1: Tx status -2
 10739	[ 1068.322762] r8152 2-1:1.0 bridgeif1: Tx timeout
 10740	[ 1074.211116] r8152 2-1:1.0 bridgeif1: Tx timeout
 10741	[ 1079.075375] r8152 2-1:1.0 bridgeif1: Tx timeout
 10742	[ 1084.195734] r8152 2-1:1.0 bridgeif1: Tx timeout
 10743	[ 1089.315981] r8152 2-1:1.0 bridgeif1: Tx timeout
 10744	[ 1095.204340] r8152 2-1:1.0 bridgeif1: Tx timeout
 10745	[ 1100.324633] r8152 2-1:1.0 bridgeif1: Tx timeout
 10746	[ 1106.212944] r8152 2-1:1.0 bridgeif1: Tx timeout
 10747	[ 1111.077223] r8152 2-1:1.0 bridgeif1: Tx timeout
 10748	[ 1116.197542] r8152 2-1:1.0 bridgeif1: Tx timeout
 10749	[ 1121.317802] r8152 2-1:1.0 bridgeif1: Tx timeout
 10750	[ 1127.206158] r8152 2-1:1.0 bridgeif1: Tx timeout
 10751	[ 1132.326404] r8152 2-1:1.0 bridgeif1: Tx timeout
 10752	[ 1138.214721] r8152 2-1:1.0 bridgeif1: Tx timeout
 10753	[ 1143.078976] r8152 2-1:1.0 bridgeif1: Tx timeout
 10754	[ 1148.199250] r8152 2-1:1.0 bridgeif1: Tx timeout
 10755	[ 1153.319543] r8152 2-1:1.0 bridgeif1: Tx timeout
 10756	[ 1159.207853] r8152 2-1:1.0 bridgeif1: Tx timeout
 10757	[ 1164.328134] r8152 2-1:1.0 bridgeif1: Tx timeout
 10758	[ 1170.216436] r8152 2-1:1.0 bridgeif1: Tx timeout
 10759	[ 1175.080678] r8152 2-1:1.0 bridgeif1: Tx timeout
 10760	[ 1180.201193] r8152 2-1:1.0 bridgeif1: Tx timeout
 10761	[ 1185.321188] r8152 2-1:1.0 bridgeif1: Tx timeout
 10762	[ 1191.209491] r8152 2-1:1.0 bridgeif1: Tx timeout
 10763	[ 1196.329740] r8152 2-1:1.0 bridgeif1: Tx timeout
 10764	[ 1202.218054] r8152 2-1:1.0 bridgeif1: Tx timeout
 10765	[ 1207.082286] r8152 2-1:1.0 bridgeif1: Tx timeout
 10766	[ 1212.202523] r8152 2-1:1.0 bridgeif1: Tx timeout
 10767	[ 1217.322777] r8152 2-1:1.0 bridgeif1: Tx timeout
 10768	[ 1223.211058] r8152 2-1:1.0 bridgeif1: Tx timeout
 10769	[ 1228.331309] r8152 2-1:1.0 bridgeif1: Tx timeout
 10770	[ 1234.219597] r8152 2-1:1.0 bridgeif1: Tx timeout
 10771	[ 1239.083829] r8152 2-1:1.0 bridgeif1: Tx timeout
 10772	[ 1244.204071] r8152 2-1:1.0 bridgeif1: Tx timeout
 10773	[ 1249.324313] r8152 2-1:1.0 bridgeif1: Tx timeout
 10774	[ 1255.212602] r8152 2-1:1.0 bridgeif1: Tx timeout
 10775	[ 1260.332834] r8152 2-1:1.0 bridgeif1: Tx timeout
 10776	[ 1266.221110] r8152 2-1:1.0 bridgeif1: Tx timeout
 10777	[ 1271.085335] r8152 2-1:1.0 bridgeif1: Tx timeout
 10778	[ 1276.205574] r8152 2-1:1.0 bridgeif1: Tx timeout
 10779	[ 1281.325815] r8152 2-1:1.0 bridgeif1: Tx timeout
 10780	[ 1287.214079] r8152 2-1:1.0 bridgeif1: Tx timeout
 10781	[ 1292.334321] r8152 2-1:1.0 bridgeif1: Tx timeout
 10782	[ 1298.222578] r8152 2-1:1.0 bridgeif1: Tx timeout
 10783	[ 1303.086798] r8152 2-1:1.0 bridgeif1: Tx timeout
 10784	[ 1308.207024] r8152 2-1:1.0 bridgeif1: Tx timeout
 10785	[ 1313.327255] r8152 2-1:1.0 bridgeif1: Tx timeout
 10786	[ 1319.215517] r8152 2-1:1.0 bridgeif1: Tx timeout
 10787	[ 1324.335751] r8152 2-1:1.0 bridgeif1: Tx timeout
 10788	[ 1330.224002] r8152 2-1:1.0 bridgeif1: Tx timeout
 10789	[ 1335.088218] r8152 2-1:1.0 bridgeif1: Tx timeout
 10790	[ 1340.208445] r8152 2-1:1.0 bridgeif1: Tx timeout
 10791	[ 1345.328670] r8152 2-1:1.0 bridgeif1: Tx timeout
 10792	[ 1351.216923] r8152 2-1:1.0 bridgeif1: Tx timeout
 10793	[ 1356.337149] r8152 2-1:1.0 bridgeif1: Tx timeout
 10794	[ 1362.225400] r8152 2-1:1.0 bridgeif1: Tx timeout
 10795	[ 1367.089604] r8152 2-1:1.0 bridgeif1: Tx timeout
 10796	[ 1372.209825] r8152 2-1:1.0 bridgeif1: Tx timeout
 10797	[ 1377.330044] r8152 2-1:1.0 bridgeif1: Tx timeout
 10798	[ 1383.218298] r8152 2-1:1.0 bridgeif1: Tx timeout
 10799	[ 1388.338517] r8152 2-1:1.0 bridgeif1: Tx timeout
 10800	[ 1394.226765] r8152 2-1:1.0 bridgeif1: Tx timeout
 10801	[ 1399.090969] r8152 2-1:1.0 bridgeif1: Tx timeout
 10802	[ 1404.211185] r8152 2-1:1.0 bridgeif1: Tx timeout
 10803	[ 1409.331406] r8152 2-1:1.0 bridgeif1: Tx timeout
 10804	[ 1415.219644] r8152 2-1:1.0 bridgeif1: Tx timeout
 10805	[ 1420.339862] r8152 2-1:1.0 bridgeif1: Tx timeout
 10806	[ 1426.228097] r8152 2-1:1.0 bridgeif1: Tx timeout
 10807	[ 1431.092293] r8152 2-1:1.0 bridgeif1: Tx timeout
 10808	[ 1436.212502] r8152 2-1:1.0 bridgeif1: Tx timeout
 10809	[ 1441.332714] r8152 2-1:1.0 bridgeif1: Tx timeout
 10810	[ 1447.220963] r8152 2-1:1.0 bridgeif1: Tx timeout
 10811	[ 1452.341168] r8152 2-1:1.0 bridgeif1: Tx timeout
 10812	[ 1458.229403] r8152 2-1:1.0 bridgeif1: Tx timeout
 10813	[ 1463.093607] r8152 2-1:1.0 bridgeif1: Tx timeout
 10814	[ 1468.213811] r8152 2-1:1.0 bridgeif1: Tx timeout
 10815	[ 1473.334015] r8152 2-1:1.0 bridgeif1: Tx timeout
 10816	[ 1479.222255] r8152 2-1:1.0 bridgeif1: Tx timeout
 10817	[ 1484.342458] r8152 2-1:1.0 bridgeif1: Tx timeout
 10818	[ 1490.230695] r8152 2-1:1.0 bridgeif1: Tx timeout
 10819	[ 1495.094882] r8152 2-1:1.0 bridgeif1: Tx timeout
 10820	[ 1500.215088] r8152 2-1:1.0 bridgeif1: Tx timeout
 10821	[ 1505.335292] r8152 2-1:1.0 bridgeif1: Tx timeout
 10822	[ 1511.223529] r8152 2-1:1.0 bridgeif1: Tx timeout
 10823	[ 1516.343733] r8152 2-1:1.0 bridgeif1: Tx timeout
 10824	[ 1522.231964] r8152 2-1:1.0 bridgeif1: Tx timeout
 10825	[ 1527.096153] r8152 2-1:1.0 bridgeif1: Tx timeout
 10826	[ 1532.216355] r8152 2-1:1.0 bridgeif1: Tx timeout
 10827	[ 1537.336553] r8152 2-1:1.0 bridgeif1: Tx timeout
 10828	[ 1543.224791] r8152 2-1:1.0 bridgeif1: Tx timeout
 10829	[ 1548.344992] r8152 2-1:1.0 bridgeif1: Tx timeout
 10830	[ 1554.233216] r8152 2-1:1.0 bridgeif1: Tx timeout
 10831	[ 1559.097401] r8152 2-1:1.0 bridgeif1: Tx timeout
 10832	[ 1564.217596] r8152 2-1:1.0 bridgeif1: Tx timeout
 10833	[ 1569.337793] r8152 2-1:1.0 bridgeif1: Tx timeout
 10834	[ 1575.226025] r8152 2-1:1.0 bridgeif1: Tx timeout
 10835	[ 1580.154332] usb 2-1: reset high-speed USB device number 2 using ehci-platform
 10836	[ 1580.346228] r8152 2-1:1.0 bridgeif1: Tx timeout
 10837	[ 1586.234452] r8152 2-1:1.0 bridgeif1: Tx timeout
 10838	[ 1590.794665] usb 2-1: device not accepting address 2, error -110
 10839	[ 1590.926658] usb 2-1: reset high-speed USB device number 2 using ehci-platform
 10840	[ 1591.098639] r8152 2-1:1.0 bridgeif1: Tx timeout
 10841	[ 1591.350662] usb 2-1: device not accepting address 2, error -71
 10842	[ 1591.690677] usb 2-1: reset high-speed USB device number 2 using ehci-platform
 10843	[ 1596.218831] r8152 2-1:1.0 bridgeif1: Tx timeout
 10844	[ 1596.858874] usb 2-1: device descriptor read/64, error -110
 10845	[ 1601.339028] r8152 2-1:1.0 bridgeif1: Tx timeout
 10846	[ 1607.227257] r8152 2-1:1.0 bridgeif1: Tx timeout
 10847	[ 1612.347466] r8152 2-1:1.0 bridgeif1: Tx timeout
 10848	[ 1612.479473] usb 2-1: device descriptor read/64, error -110
 10849	[ 1612.719486] usb 2-1: reset high-speed USB device number 2 using ehci-platform
 10850	[ 1613.067489] usb 2-1: device descriptor read/64, error -71
 10851	[ 1618.235679] r8152 2-1:1.0 bridgeif1: Tx timeout
 10852	[ 1623.099860] r8152 2-1:1.0 bridgeif1: Tx timeout
 10853	[ 1628.220058] r8152 2-1:1.0 bridgeif1: Tx timeout
 10854	[ 1628.604091] usb 2-1: device descriptor read/64, error -110
 10855	[ 1628.716148] r8152 2-1:1.0 bridgeif1: Get ether addr fail
 10856	[ 1628.721491] r8152 2-1:1.0 bridgeif1: Promiscuous mode enabled
 10857	[ 1628.728148] usb 2-1: USB disconnect, device number 2
 10858	[ 1628.736033] device bridgeif1 left promiscuous mode
 10859	[ 1629.048173] usb 2-1: new high-speed USB device number 3 using ehci-platform
 10860	[ 1639.692512] usb 2-1: device not accepting address 3, error -110
 10861	[ 1639.824514] usb 2-1: new high-speed USB device number 4 using ehci-platform
 10862	[ 1640.248526] usb 2-1: device not accepting address 4, error -71
 10863	[ 1640.254411] usb usb2-port1: attempt power cycle
 10864	[ 1640.904546] usb 2-1: new high-speed USB device number 5 using ehci-platform
 10865	[ 1646.268756] usb 2-1: device descriptor read/64, error -110
 10866	[ 1661.885363] usb 2-1: device descriptor read/64, error -110
 10867	[ 1662.125384] usb 2-1: new high-speed USB device number 6 using ehci-platform
 10868	[ 1662.473360] usb 2-1: device descriptor read/64, error -71
 10869	[ 1678.013953] usb 2-1: device descriptor read/64, error -110
 10870	[ 1678.126003] usb usb2-port1: unable to enumerate USB device
 10871	[ 1678.517957] usb 6-1: new full-speed USB device number 2 using ohci-platform
 10872	[ 1694.202558] usb 6-1: device descriptor read/64, error -110
 10873	[ 1709.819134] usb 6-1: device descriptor read/64, error -110
 10874	[ 1710.119160] usb 6-1: new full-speed USB device number 3 using ohci-platform
 10875	[ 1725.691731] usb 6-1: device descriptor read/64, error -110
 10876	[ 1741.308300] usb 6-1: device descriptor read/64, error -110
 10877	[ 1741.420340] usb usb6-port1: attempt power cycle
 10878	[ 1741.924322] usb 6-1: new full-speed USB device number 4 using ohci-platform
 10879	[ 1752.592714] usb 6-1: device not accepting address 4, error -110
 10880	[ 1752.784726] usb 6-1: new full-speed USB device number 5 using ohci-platform
 10881	[ 1763.601125] usb 6-1: device not accepting address 5, error -110
 10882	[ 1763.607104] usb usb6-port1: unable to enumerate USB device
 10883
 10884
 10885	vm.admin_reserve_kbytes = 8192
 10886	vm.block_dump = 0
 10887	vm.compact_unevictable_allowed = 1
 10888	vm.dirty_background_bytes = 0
 10889	vm.dirty_background_ratio = 10
 10890	vm.dirty_bytes = 0
 10891	vm.dirty_expire_centisecs = 3000
 10892	vm.dirty_ratio = 20
 10893	vm.dirtytime_expire_seconds = 43200
 10894	vm.dirty_writeback_centisecs = 500
 10895	vm.extfrag_threshold = 500
 10896	vm.highmem_is_dirtyable = 0
 10897	vm.laptop_mode = 0
 10898	vm.legacy_va_layout = 0
 10899	vm.lowmem_reserve_ratio = 32	0	0
 10900	vm.max_map_count = 65530
 10901	vm.min_free_kbytes = 3465
 10902	vm.mmap_min_addr = 32768
 10903	vm.mmap_rnd_bits = 8
 10904	vm.oom_dump_tasks = 1
 10905	vm.oom_kill_allocating_task = 0
 10906	vm.overcommit_kbytes = 0
 10907	vm.overcommit_memory = 0
 10908	vm.overcommit_ratio = 50
 10909	vm.page-cluster = 0
 10910	vm.panic_on_oom = 0
 10911	vm.percpu_pagelist_fraction = 0
 10912	vm.stat_interval = 1
 10913	vm.swappiness = 100
 10914	vm.user_reserve_kbytes = 31523
 10915	vm.vfs_cache_pressure = 100
 10916	vm.watermark_boost_factor = 15000
 10917	vm.watermark_scale_factor = 10
 10918
 10919	### interrupts:
 10920	           CPU0       CPU1       CPU2       CPU3
 10921	 17:          0          0          0          0     GICv2  50 Level     timer@1c20c00
 10922	 18:          0          0          0          0     GICv2  29 Level     arch_timer
 10923	 19:     893595     920978   13609274     332435     GICv2  30 Level     arch_timer
 10924	 22:          0          0          0          0     GICv2  82 Level     1c02000.dma-controller
 10925	 24:     307699          0          0          0     GICv2  92 Level     sunxi-mmc
 10926	 25:        461          0          0          0     GICv2  93 Level     sunxi-mmc
 10927	 26:        643          0          0          0     GICv2  94 Level     sunxi-mmc
 10928	 27:          0          0          0          0     GICv2 103 Level     musb-hdrc.1.auto
 10929	 28:          0          0          0          0     GICv2 104 Level     ehci_hcd:usb1
 10930	 29:          0          0          0          0     GICv2 105 Level     ohci_hcd:usb5
 10931	 30:     320521          0          0          0     GICv2 106 Level     ehci_hcd:usb2
 10932	 31:         51          0          0          0     GICv2 107 Level     ohci_hcd:usb6
 10933	 32:          0          0          0          0     GICv2 108 Level     ehci_hcd:usb3
 10934	 33:          0          0          0          0     GICv2 109 Level     ohci_hcd:usb7
 10935	 34:        174          0    9443594          0     GICv2 110 Level     ehci_hcd:usb4
 10936	 35:          0          0          0          0     GICv2 111 Level     ohci_hcd:usb8
 10937	 39:    1714419          0          0          0     GICv2 114 Level     bridgeif0
 10938	 43:        458          0          0          0     GICv2  33 Level     ttyS1
 10939	 44:          0          0          0          0     GICv2  38 Level     mv64xxx_i2c
 10940	 45:          0          0          0          0     GICv2  72 Level     1f00000.rtc
 10941	 48:          0          0          0          0     GICv2  90 Level     1c0e000.video-codec
 10942	 49:          0          0          0          0     GICv2 129 Level     gp
 10943	 50:          0          0          0          0     GICv2 130 Level     gpmmu
 10944	 51:          0          0          0          0     GICv2 131 Level     pp0
 10945	 52:          0          0          0          0     GICv2 132 Level     ppmmu0
 10946	 53:          0          0          0          0     GICv2 134 Level     pp1
 10947	 54:          0          0          0          0     GICv2 135 Level     ppmmu1
 10948	 56:    1187613          0          0          0     GICv2  63 Level     ths
 10949	 57:          0          0          0          0     GICv2 152 Level     arm-pmu
 10950	 58:          0          0          0          0     GICv2 153 Level     arm-pmu
 10951	 59:          0          0          0          0     GICv2 154 Level     arm-pmu
 10952	 60:          0          0          0          0     GICv2 155 Level     arm-pmu
 10953	128:          1          0          0          0  sunxi_pio_edge   3 Edge      reset
 10954	IPI0:          0          0          0          0  CPU wakeup interrupts
 10955	IPI1:          0          0          0          0  Timer broadcast interrupts
 10956	IPI2:     170575     327164     258300     614706  Rescheduling interrupts
 10957	IPI3:         24         41         21         26  Function call interrupts
 10958	IPI4:          0          0          0          0  CPU stop interrupts
 10959	IPI5:     117770      41383    1046856      20612  IRQ work interrupts
 10960	IPI6:          0          0          0          0  completion interrupts
 10961	Err:          0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
An update: before building the full system, last year we built a smaller, 8-node system, which I just set up again. This system is still running the "Armbian_5.90_Nanopi-r1_Ubuntu_bionic_next_4.19.57" image, and I can't reproduce the problem with this kernel (4.19.57-sunxi). The size of the network doesn't seem to be a factor, as we encountered the problem with just five nodes.
Here's another oddity: if I run iperf3 between two directly connected NanoPi R1's (from one's LAN to the other's WAN), I get about 94Mbit with kernel 4.19.62 or older, but only about 13Mbit with all newer ones I've tested (including 5.4.35).
I'll have to burn fresh images to make sure the results aren't affected by any other configuration changes I've done, but so far this seems consistent and reproducible.
Hi,
Please could you give us more information about your Linux kernel version and driver used into your test.
I am trying to use one Debian 5.10 standard kernel  without capabilities to ping one external target connected on WAN port. At the same time, no problems encountered when connected (even with VLAN) on LAN port ?
Thanks in advance for your help
