Is the OPI PC overclocked on newer OS builds?
nikkoaki
I remember that the maximum frequency was 1296Mhz back with Xenial, with kernel 3.x. It even says here
Quote
"It's rated to run at 1.296GHz, anything higher is overclocking (and usually overvolting). If you run it without heatsink, fan and proper dvfs settings, you risk overheating."
Heat is not a problem since i have a large heatsink and temperature controlled fan, i was just curious about why the max frequency was bumped to 1368Mhz on the newer builds. What's the rationale behind it?
Numbers are more or less the same. DVFS procedures were in modern kernel (5 ->) basically written from the scratch and we can say they are a bit more fine tuned.
