Gossamer Posted April 20, 2020 Share Posted April 20, 2020 Hi people. My ubuntu machine serves as a samba and openvpn servers. Sometimes it hangs and I'm unable to connect using ssh/openvpn. I've been searching the logs syslog and dmesg, but I'm stil unable to find the cause. Could you point where I should search for the problem? Or help me to troubleshoot and find the problem? Thanks in advance Link to comment Share on other sites More sharing options...
Werner Posted April 20, 2020 Share Posted April 20, 2020 armbianmonitor -u Link to comment Share on other sites More sharing options...
Gossamer Posted April 20, 2020 Author Share Posted April 20, 2020 file attached armbianmonitor -u.txt Link to comment Share on other sites More sharing options...
Werner Posted April 20, 2020 Share Posted April 20, 2020 You should get an up to date kernel/image at first. Yours is quite outdated. IMAGE_TYPE=user-built Therefore unsupported anyway. Link to comment Share on other sites More sharing options...
Gossamer Posted April 20, 2020 Author Share Posted April 20, 2020 16 minutes ago, Werner said: You should get an up to date kernel/image at first. Yours is quite outdated. IMAGE_TYPE=user-built Therefore unsupported anyway. This is the image from the balbes TVBOX Amlogic 905X release. If you could help me troubleshoot the problem your help would be very appreciated. Link to comment Share on other sites More sharing options...
Werner Posted April 20, 2020 Share Posted April 20, 2020 Them maybe @balbes150 can help Link to comment Share on other sites More sharing options...
