Orange Pi RK3399 does not start with Armbian images
WZab
I'm trying to run Armbian on Orange Pi RK3399 board.
I have TP50265 permanently shorted to the ground to enable SD card booting.
The board starts without any problems with Debian and Ubuntu images downloaded from the manufacturer website, e.g. https://drive.google.com/drive/folders/1wAdkC25BmjMwapWahEEQGTvi-yuwo8Gx
Quote
DDR Version 1.08 20170320
In
Channel 0: DDR3, 800MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel 1: DDR3, 800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x20
ch 1 ddrconfig = 0x101, ddrsize = 0x20
pmugrf_os_reg[2] = 0x32817281, stride = 0x9
OUT
Boot1: 2017-04-07, version: 1.06
CPUId = 0x0
ChipType = 0x10, 1824
mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
mmc: ERROR: Card did not respond to voltage select!
emmc reinit
emmc reinit
SdmmcInit=2 1
SdmmcInit=0 0
BootCapSize=0
UserCapSize=7420MB
FwPartOffset=2000 , 0
StorageInit ok = 57188
LoadTrustBL
No find bl30.bin
No find bl32.bin
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):55aa0b4
NOTICE:  BL31: Built : 16:55:03, Mar 31 2017
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1089): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-g0f7b3ff-dirty (Oct 10 2018 - 10:02:23 +0800)
Model: OrangePi RK3399 Board
DRAM:  2 GiB
MMC:   dwmmc@fe320000: 1, sdhci@fe330000: 0
mmc_init: -95, time 20
*** Warning - No block device, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@fe300000
Hit any key to stop autoboot:  0
mmc_init: -95, time 19
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:6...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
184 bytes read in 4 ms (44.9 KiB/s)
1:      kernel-4.4
Retrieving file: /Image
reading /Image
19568648 bytes read in 1249 ms (14.9 MiB/s)
append: earlyprintk console=ttyFIQ0,1500000n8 rw root=PARTUUID=b921b045-1d rootfstype=ext4 init=/sbin/init rootwait
Retrieving file: /rk3399-orangepi.dtb
reading /rk3399-orangepi.dtb
78885 bytes read in 9 ms (8.4 MiB/s)
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Device Tree to 000000007dee9000, end 000000007deff424 ... OK
Starting kernel ...
<hit enter to activate fiq debugger>
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
after the above, kernel boots and the system starts perfectly.
However, when I try the images downloaded from Armbian website (both, based on the old kernel, like
https://dl.armbian.com/orangepi-rk3399/archive/Armbian_20.02.1_Orangepi-rk3399_bionic_legacy_4.4.213_desktop.7z and the new ones, like
https://dl.armbian.com/orangepi-rk3399/archive/Armbian_20.02.1_Orangepi-rk3399_buster_current_5.4.20_desktop.7z I get the similar output:
Quote
DDR Version 1.24 20191016
In
256B stride
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 242
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=14760MB
StorageInit ok = 44157
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
GPT part:  0, name:            uboot, start:0x6000, size:0x2000
GPT part:  1, name:            trust, start:0x8000, size:0x2000
GPT part:  2, name:             boot, start:0xc000, size:0x10000
GPT part:  3, name:           rootfs, start:0x5c000, size:0x1c77fdf
recovery gpt success!
find part:uboot OK. first_lba:0x6000.
find part:trust OK. first_lba:0x8000.
LoadTrust Addr:0x8000
LoadTrust Addr:0x8400
LoadTrust Addr:0x8800
LoadTrust Addr:0x8c00
LoadTrust Addr:0x9000
LoadTrust Addr:0x9400
LoadTrust Addr:0x9800
LoadTrust Addr:0x9c00
Addr:0x8000 No find trust.img!
LoadTrustBL error:-3
SecureMode = 0
SecureInit ret = -2, SecureMode = 0
After that the system remains frozen...
What am I doing incorrectly?
Thank you very much in advance,
With best regards,
Wojtek
Edited by WZab
Corrected link to the working manufacturer's image
The version Armbian_20.05.0-trunk.111_Orangepi-rk3399_focal_dev_5.6.5_minimal.img starts, and displays the following:
Quote
In
256B stride
OUT
CPUId = 0x0
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=14760MB
StorageInit ok = 44011
SecureMode = 0
recovery gpt...
GPT part:  0, name:          loader1, start:0x40, size:0x1f40
GPT part:  1, name:        reserved1, start:0x1f80, size:0x80
GPT part:  2, name:        reserved2, start:0x2000, size:0x2000
GPT part:  3, name:          loader2, start:0x4000, size:0x2000
GPT part:  4, name:              atf, start:0x6000, size:0x2000
GPT part:  5, name:             boot, start:0x8000, size:0x38000
GPT part:  6, name:                 , start:0x40000, size:0x1c93fdf
no find partition:uboot.
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xa6740
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    Using opteed sec cpu_context!
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE wi
ll return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    SPSR = 0x3c9
U-Boot 2020.04-armbian (Apr 20 2020 - 08:39:15 +0200)
SoC: Rockchip rk3399
Reset cause: POR
Model: Orange Pi RK3399 Board
DRAM:  2 GiB
PMIC:  RK808
MMC:   dwmmc@fe310000: 2, dwmmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... Card did not respond to voltage select!
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
Scanning mmc 1:1...
2940 bytes read in 6 ms (478.5 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
102 bytes read in 5 ms (19.5 KiB/s)
9862241 bytes read in 423 ms (22.2 MiB/s)
22151680 bytes read in 940 ms (22.5 MiB/s)
74330 bytes read in 12 ms (5.9 MiB/s)
2698 bytes read in 10 ms (262.7 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 39000000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    9862177 Bytes = 9.4 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
   Loading Ramdisk to 7d5ba000, end 7df21c21 ... OK
   Loading Device Tree to 000000007d53f000, end 000000007d5b9fff ... OK
Starting kernel ...
[    7.111047] OF: graph: no port node found in /i2c@ff3d0000/fusb302@22
[    7.289623] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4356-sdio for chip BCM4356/2
[   10.385057] brcmfmac: brcmf_sdio_readshared: invalid sdpcm_shared address 0xFE8B0174
[   10.385759] brcmfmac: brcmf_sdio_readshared: unable to obtain sdpcm_shared info: rv=-22 (addr=0xfe8b0174)
Armbian 20.05.0-trunk.111 Focal ttyS2
orangepi-rk3399 login:
So it works, but unfortunately I don't see the messages from booting kernel. As I'm mainly working at low level applications and kernel drivers, it is not the most comfortable situation...
With best regards,
Wojtek
