r2d2r01 Posted April 22, 2020 Share Posted April 22, 2020 Quote Hi I have flashed an armbian 4.14 on µsd & switch system on a ssd sandisk 120Gb with nand-sata-install which works fine. I try without success to do a fsck on boot on mmcblk & sda, only mmcblk is checked, not /dev/sda1, however all seems fine. Below config used and armbian log zipped. Any help would be appeciated Quote dmesg extract ------------- [ 0.000000] Booting Linux on physical CPU 0x100 [ 0.000000] Linux version 4.14.176-odroidxu4 (root@ubuntu4armbian) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #15 SMP PREEMPT Wed Apr 15 08:03:33 CEST 2020 [ 0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=50c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Hardkernel Odroid XU4 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 128 MiB at 0xb6800000 [ 0.000000] Samsung CPU ID: 0xe5422001 root@SVRLOC-IQB:/var/log# dmesg | grep mmcblk [ 15.339553] mmcblk1: mmc1:1234 SA16G 14.4 GiB [ 15.340824] mmcblk1: p1 [ 25.691854] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: commit=600,errors=remount-ro root@SVRLOC-IQB:/var/log# dmesg | grep sda [ 16.705101] sd 0:0:0:0: [sda] 234455040 512-byte logical blocks: (120 GB/112 GiB) [ 16.705111] sd 0:0:0:0: [sda] 4096-byte physical blocks [ 16.705338] sd 0:0:0:0: [sda] Write Protect is off [ 16.705347] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08 [ 16.705801] sd 0:0:0:0: [sda] Disabling FUA [ 16.705811] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 16.706294] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes) [ 16.709480] sda: sda1 [ 16.714168] sd 0:0:0:0: [sda] Attached SCSI disk [ 18.934347] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 19.815763] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro root@SVRLOC-IQB:~# lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster root@SVRLOC-IQB:~# uname -a Linux SVRLOC-IQB 4.14.176-odroidxu4 #15 SMP PREEMPT Wed Apr 15 08:03:33 CEST 2020 armv7l GNU/Linux root@SVRLOC-IQB:/var/log# cat /etc/fstab # <file system> <mount point> <type> <options> <dump> <pass> tmpfs /tmp tmpfs defaults,nosuid 0 0 UUID=87887d05-2ce6-4959-a4ba-59d7ed36e7c1 /media/mmcboot ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 /media/mmcboot/boot /boot none bind 0 0 UUID=b86978b6-aac1-4547-9a2d-378e6b69dd9e / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 root@SVRLOC-IQB:/var/log# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 111.8G 0 disk └─sda1 8:1 0 111.8G 0 part / mmcblk1 179:0 0 14.4G 0 disk └─mmcblk1p1 179:1 0 14.3G 0 part /media/mmcboot zram0 253:0 0 50M 0 disk /var/log zram1 253:1 0 998M 0 disk [SWAP] root@SVRLOC-IQB:/var/log# blkid /dev/mmcblk1p1: UUID="87887d05-2ce6-4959-a4ba-59d7ed36e7c1" TYPE="ext4" PARTUUID="639d21b3-01" /dev/zram0: LABEL="log2ram" UUID="e9451ae1-a82b-4976-b4f3-74aeb892a5da" TYPE="ext4" /dev/mmcblk1: PTUUID="639d21b3" PTTYPE="dos" /dev/sda1: UUID="b86978b6-aac1-4547-9a2d-378e6b69dd9e" TYPE="ext4" PARTUUID="47d60e09-01" /dev/zram1: UUID="63d9f06e-ea12-4679-afb5-6c86e66cb6f1" TYPE="swap" root@SVRLOC-IQB:/var/log# mount | grep /dev/ devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000) /dev/sda1 on / type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600,data=ordered) tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev) mqueue on /dev/mqueue type mqueue (rw,relatime) /dev/mmcblk1p1 on /media/mmcboot type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600,x-gvfs-hide) /dev/mmcblk1p1 on /boot type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600) /dev/sda1 on /var/log.hdd type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600,data=ordered) /dev/zram0 on /var/log type ext4 (rw,relatime,discard) root@SVRLOC-IQB:/var/log# dmesg | grep /dev/disk [ 25.636241] systemd[1]: Started File System Check on /dev/disk/by-uuid/87887d05-2ce6-4959-a4ba-59d7ed36e7c1. root@SVRLOC-IQB:/var/log# grep /dev/disk/ * armbian-hardware-monitor.log:[ 25.910551] systemd[1]: Started File System Check on /dev/disk/by-uuid/87887d05-2ce6-4959-a4ba-59d7ed36e7c1. armbian-hardware-monitor.log:[ 24.612965] systemd[1]: Started File System Check on /dev/disk/by-uuid/87887d05-2ce6-4959-a4ba-59d7ed36e7c1. armbian-hardware-monitor.log:[ 26.166894] systemd[1]: Started File System Check on /dev/disk/by-uuid/87887d05-2ce6-4959-a4ba-59d7ed36e7c1. armbian-hardware-monitor.log:[ 24.898750] systemd[1]: Started File System Check on /dev/disk/by-uuid/87887d05-2ce6-4959-a4ba-59d7ed36e7c1. armbian-hardware-monitor.log:[ 25.636241] systemd[1]: Started File System Check on /dev/disk/by-uuid/87887d05-2ce6-4959-a4ba-59d7ed36e7c1. root@SVRLOC-IQB:/var/log# grep systemd-fsck syslog syslog:Apr 22 11:47:18 localhost systemd-fsck[317]: /dev/mmcblk1p1: Superblock last write time is in the future. syslog:Apr 22 11:47:18 localhost systemd-fsck[317]: #011(by less than a day, probably due to the hardware clock being incorrectly set) syslog:Apr 22 11:47:18 localhost systemd-fsck[317]: /dev/mmcblk1p1 has been mounted 1 times without being checked, check forced. syslog:Apr 22 11:47:18 localhost systemd-fsck[317]: /dev/mmcblk1p1: 44867/920000 files (0.1% non-contiguous), 356440/3745832 blocks syslog:Apr 22 11:47:43 localhost systemd[1]: systemd-fsckd.service: Succeeded. root@SVRLOC-IQB:/var/log# cat /run/initramfs/fsck.log Log of fsck -C -a -V -t ext4 /dev/sda1 Sat Jan 1 00:00:25 2000 fsck from util-linux 2.33.1 [/sbin/fsck.ext4 (1) -- /dev/sda1] fsck.ext4 -a -C0 /dev/sda1 /dev/sda1 has been mounted 1 times without being checked, check forced. /dev/sda1: 44858/7331840 files (0.1% non-contiguous), 892892/29306624 blocks Sat Jan 1 00:00:26 2000 ---------------- root@SVRLOC-IQB:/var/log# tune2fs -l /dev/sda1 tune2fs 1.44.5 (15-Dec-2018) Filesystem volume name: <none> Last mounted on: /root Filesystem UUID: b86978b6-aac1-4547-9a2d-378e6b69dd9e Filesystem magic number: 0xEF53 Filesystem revision #: 1 (dynamic) Filesystem features: has_journal ext_attr resize_inode dir_index filetype needs_recovery extent 64bit flex_bg sparse_super large_file huge_file dir_nlink extra_isize metadata_csum Filesystem flags: unsigned_directory_hash Default mount options: user_xattr acl Filesystem state: clean Errors behavior: Continue Filesystem OS type: Linux Inode count: 7331840 Block count: 29306624 Reserved block count: 1465331 Free blocks: 28413732 Free inodes: 7286982 First block: 0 Block size: 4096 Fragment size: 4096 Group descriptor size: 64 Reserved GDT blocks: 1024 Blocks per group: 32768 Fragments per group: 32768 Inodes per group: 8192 Inode blocks per group: 512 Flex block group size: 16 Filesystem created: Mon Apr 20 12:30:11 2020 Last mount time: Sat Jan 1 01:00:26 2000 Last write time: Sat Jan 1 01:00:26 2000 Mount count: 1 Maximum mount count: 1 Last checked: Mon Apr 20 12:30:11 2020 Check interval: 0 (<none>) Lifetime writes: 2691 MB Reserved blocks uid: 0 (user root) Reserved blocks gid: 0 (group root) First inode: 11 Inode size: 256 Required extra isize: 32 Desired extra isize: 32 Journal inode: 8 Default directory hash: half_md4 Directory Hash Seed: ae131f81-b92d-4507-a9ba-e18d4a038750 Journal backup: inode blocks Checksum type: crc32c Checksum: 0x8c28e750 root@SVRLOC-IQB:/var/log# grep 87887d05 * armbian-hardware-monitor.log:[ 25.636241] systemd[1]: Started File System Check on /dev/disk/by-uuid/87887d05-2ce6-4959-a4ba-59d7ed36e7c1. armbian-hardware-monitor.log:└─mmcblk1p1 ext4 14.3G /media/mmcboot 87887d05-2ce6-4959-a4ba-59d7ed36e7c1 kern.log:Apr 20 12:04:37 localhost kernel: [ 0.000000] Kernel command line: console=ttySAC2,115200n8 console=tty1 consoleblank=0 loglevel=1 root=UUID=87887d05-2ce6-4959-a4ba-59d7ed36e7c1 rootfstype=ext4 rootwait rw smsc95xx.macaddr=00:1e:06:61:7a:55 governor=performance hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=true vout=hdmi usb-storage.quirks= s5p_mfc.mem=16M root@SVRLOC-IQB:/var/log# grep b86978b6 * armbian-hardware-monitor.log:[ 0.000000] Kernel command line: console=ttySAC2,115200n8 console=tty1 consoleblank=0 loglevel=1 root=UUID=b86978b6-aac1-4547-9a2d-378e6b69dd9e rootfstype=ext4 rootwait rw smsc95xx.macaddr=00:1e:06:61:7a:55 governor=performance hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=true vout=hdmi usb-storage.quirks= s5p_mfc.mem=16M armbian-hardware-monitor.log:setenv rootdev UUID=b86978b6-aac1-4547-9a2d-378e6b69dd9e armbian-hardware-monitor.log:└─sda1 ext4 111.8G / b86978b6-aac1-4547-9a2d-378e6b69dd9e kern.log:Apr 22 11:47:18 localhost kernel: [ 0.000000] Kernel command line: console=ttySAC2,115200n8 console=tty1 consoleblank=0 loglevel=1 root=UUID=b86978b6-aac1-4547-9a2d-378e6b69dd9e rootfstype=ext4 rootwait rw smsc95xx.macaddr=00:1e:06:61:7a:55 governor=performance hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=true vout=hdmi usb-storage.quirks= s5p_mfc.mem=16M abm.tar.gz Link to comment Share on other sites More sharing options...
kdeenkhoorn Posted May 14, 2020 Share Posted May 14, 2020 Hi, my 50ct: You have disabled automatic checking by setting: Check interval to 0 (<none>) so no automatic time dependent checking after a day or week or month or so will take place. Also you have : Mount count set to 1 and Maximum mount count also set to 1. At the first mount nothing will happen because 1 is equal to 1 not greater. According to the manual only the second time it is mounted it will be checked because mount count will be 2 and maximum mount count still 1. Afterwards the counter Mount count will be reset. See: http landoflinux.com/linux_tune2fs_command.html tune2fs options -c max-mount-counts Adjust the number of mounts after which the filesystem will be checked by e2fsck(8). If max-mount-counts is 0 or -1, the number of times the filesystem is mounted will be disregarded by e2fsck(8) and the kernel. -C mount-count Set the number of times the filesystem has been mounted. If set to a greater value than the max-mount-counts parameter set by the -c option, e2fsck(8) will check the filesystem at the next reboot. -i interval-between-checks[d|m|w] Adjust the maximal time between two filesystem checks. No postfix or d result in days, m in months, and w in weeks. A value of zero will disable the time-dependent checking. It is strongly recommended that either -c (mount-count-dependent) or -i (time-depen- dent) checking be enabled to force periodic full e2fsck(8) checking of the filesystem. Failure to do so may lead to filesystem corruption (due to bad disks, cables, memory, or kernel bugs) going unnoticed, ultimately resulting in data loss or corruption. Have Fun! Link to comment Share on other sites More sharing options...
