blh7855 Posted April 22, 2020 Share Posted April 22, 2020 Hi, I have a sunvell Qplus TV Box with Allwinner H6 I write the img by @balbes150 into SD Cards And I use the dtb by @hexdump The Qplus Box boot into Armbian but failed connect to the Ethernet of WIfi (found no device) So is there anyway to make it fine? Thanks! Link to comment Share on other sites More sharing options...
balbes150 Posted April 22, 2020 Share Posted April 22, 2020 44 minutes ago, blh7855 said: So is there anyway to make it fine? Not the right DTB. Link to comment Share on other sites More sharing options...
hexdump Posted April 23, 2020 Share Posted April 23, 2020 this dtb is very old and will most probably no longer work with the latest images - just try all the h6 dtbs which are part of the images - the qplus is quite a standard box, so it should work with one of them, but on the other side the qplus hardware seems to vary quite a bit so it might also not work at all due to memory initializing problems or something like this good luck and best wishes - hexdump Link to comment Share on other sites More sharing options...
