ethDreamer Posted April 27, 2020 Share Posted April 27, 2020 So I noticed my NanoPC-T4's will not boot an image made with the latest armbian build script. I did a binary search on the commits and tracked down the breaking change: commit 75d0f64e3d75e7c34466871b9723ef1a238609d8 <- THIS COMMIT AND ANYTHING AFTER IS BROKEN Author: Piotr Szczepanik <piter75@gmail.com> Date: Fri Apr 17 21:30:37 2020 +0200 Switch rk3399 to u-boot v2020.04 (#1873) * Switched rk3399 to u-boot 2020.04-rc4 * Switched rk3399 u-boot to v2020.04, synchronized configs * Updated to u-boot v2020.04 final * Fixed OrangePi 4 device tree reference commit cc98ba3c0d3ff8d84ed08bfbf691b3bc94a6bc2b <- THIS BOOTS FINE Author: Igor Pečovnik <igorpecovnik@users.noreply.github.com> Date: Fri Apr 17 21:29:06 2020 +0200 Disable MESA on bionic (#1895) Also enable xfce4 power manager on some boards Signed-off-by: Igor Pecovnik <igor.pecovnik@gmail.com> I checked the output on the serial console, it looks like the board gets stuck in an infinite boot loop: ######## POWER ON BOARD ######## DDR Version 1.24 20191016 In Channel 0: LPDDR3, 800MHz CS = 0 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x2 MR5=0x1 MR6=0x6 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F CS = 1 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x2 MR5=0x1 MR6=0x6 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB Channel 1: LPDDR3, 800MHz CS = 0 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x2 MR5=0x1 MR6=0x6 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F CS = 1 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x2 MR5=0x1 MR6=0x6 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB 256B stride ch 0 ddrconfig = 0x101, ddrsize = 0x2020 ch 1 ddrconfig = 0x101, ddrsize = 0x2020 pmugrf_os_reg[2] = 0x3AA0DAA0, stride = 0xD OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 248 mmc: ERROR: sdhci_complete_adma: transfer error, stat 0x408000, adma error 0, retry 9996026, cmd 0x83a mmc: ERROR: sdhci_complete_adma: transfer error, stat 0x408000, adma error 0, retry 9996025, cmd 0x83a emmc reinit mmc: ERROR: sdhci_complete_adma: transfer error, stat 0x408000, adma error 0, retry 9996026, cmd 0x83a mmc: ERROR: sdhci_complete_adma: transfer error, stat 0x408000, adma error 0, retry 9996027, cmd 0x83a emmc reinit mmc: ERROR: sdhci_complete_adma: transfer error, stat 0x408000, adma error 0, retry 9996021, cmd 0x83a mmc: ERROR: sdhci_complete_adma: transfer error, stat 0x408000, adma error 0, retry 9996022, cmd 0x83a SdmmcInit=2 1 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=128001MB FwPartOffset=2000 , 0 StorageInit ok = 121149 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, Load OK, addr=0x200000, size=0xad9e8 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will reK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.04-armbian (Apr 26 2020 - 00:46:29 +0000) SoC: Rockchip rk3399 Reset cause: POR Model: FriendlyElec NanoPC-T4 DRAM: 3.9 GiB PMIC: RK808 MMC: dwmmc@fe310000: 2, dwmmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - No block device, using default environment "Synchronous Abort" handler, esr 0x96000045 elr: 0000000000231550 lr : 00000000002314ec (reloc) elr: 00000000f4576550 lr : 00000000f45764ec x0 : 00000000f254a3c0 x1 : 00000000f8000000 x2 : 00000000f82a4000 x3 : 0000000000000000 x4 : 0000000011b3dc40 x5 : 0000000011b3dc40 x6 : 00000000ffffdff1 x7 : 0000000000000128 x8 : 0000000000000129 x9 : 0000000000000008 x10: 0000000000000008 x11: 0000000000000001 x12: 000000000000012a x13: 0000000000005dc0 x14: 0000000000000000 x15: 00000000f252d698 x16: 0000000000008080 x17: 0000000000000032 x18: 00000000f253cdd8 x19: 00000000f254a3c0 x20: 00000000f25415a0 x21: 00000000f252d480 x22: 00000000f45ea6c8 x23: 00000000f45ea6c8 x24: 00000000f254a368 x25: 00000000f254a370 x26: 00000000f254a130 x27: 00000000f254a378 x28: 0000000000000002 x29: 00000000f252d430 Code: 8b020022 eb02003f 54fffee2 b9403403 (b8004423) Resetting CPU ... resetting ... ######## OUTPUT REPATS AT THIS POINT ######## Link to comment Share on other sites More sharing options...
Werner Posted April 27, 2020 Share Posted April 27, 2020 @piter75 Link to comment Share on other sites More sharing options...
piter75 Posted April 27, 2020 Share Posted April 27, 2020 9 hours ago, ethDreamer said: I checked the output on the serial console, it looks like the board gets stuck in an infinite boot loop Do you have HDMI connected to your T4 while booting? If so, can you test it with HDMI disconnected? HDMI is one of the possible offenders that come to my mind as it was freshly enabled for rk3399 boards in v2020.04. I have tested the change with M4 (v1) and M4V2 albeit without HDMI - it works well. I tested it with HDMI on OrangePi 4 and it booted although the HDMI output in u-boot was garbled. Link to comment Share on other sites More sharing options...
ethDreamer Posted April 29, 2020 Author Share Posted April 29, 2020 On 4/27/2020 at 8:06 AM, piter75 said: Do you have HDMI connected to your T4 while booting? If so, can you test it with HDMI disconnected? HDMI is one of the possible offenders that come to my mind as it was freshly enabled for rk3399 boards in v2020.04. I have tested the change with M4 (v1) and M4V2 albeit without HDMI - it works well. I tested it with HDMI on OrangePi 4 and it booted although the HDMI output in u-boot was garbled. Yup that did it. It boots fine with the latest commit 716bd3b9dc.. as long as HDMI is unplugged. If HDMI is plugged in, it will enter that boot loop. I can plug in HDMI after the boot loader gets to this point: Quote Found U-Boot script /boot/boot.scr 2940 bytes read in 5 ms (574.2 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 151 bytes read in 5 ms (29.3 KiB/s) 6786524 bytes read in 396 ms (16.3 MiB/s) 19296264 bytes read in 1083 ms (17 MiB/s) 104819 bytes read in 13 ms (7.7 MiB/s) ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 6786460 Bytes = 6.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f1eb1000, end f2529d9c ... OK ERROR: reserving fdt memory region failed (addr=0 size=0) Loading Device Tree to 00000000f1e2f000, end 00000000f1eb0fff ... OK Starting kernel ... I feel like I'm not going to be the last person to run into this issue so I hope they find this post.. Side note: is there any way to have the kernel redirect output to the serial console after this point? Because otherwise I don't see anything until the system reaches the login prompts. I'm more than happy to be a tester for this. Link to comment Share on other sites More sharing options...
piter75 Posted April 29, 2020 Share Posted April 29, 2020 13 hours ago, ethDreamer said: I feel like I'm not going to be the last person to run into this issue so I hope they find this post. I will probably disable HDMI in u-boot at least for NanoPC-T4 for now to avoid it. 13 hours ago, ethDreamer said: is there any way to have the kernel redirect output to the serial console after this point? Set verbosity=7 in /boot/armbianEnv.txt instead of the default of 1 to make the kernel output verbose. Link to comment Share on other sites More sharing options...
