Can't install kernal-headers
wollik
Hi forum members,
when I try to install the kernel headers via: "sudo apt-get install kernel-headers-$(uname -r)"
I gote these errors:
Reading package lists... Done
Building dependency tree
E: Unable to locate package kernel-headers-4.19.62-sunxi
E: Couldn't find any package by glob 'kernel-headers-4.19.62-sunxi'
E: Couldn't find any package by regex 'kernel-headers-4.19.62-sunxi'
In the /etc/apt/sources.list the lines with the deb-src links are comments.
I've tried to uncomment these but got the same errors.
So please can somwone point me right kernel-headers Armbian is using ?
Many Thanks
wollik
We fix kernel headers only lately, since they were mainly broken before. With latest kernel, they are present. Install them via armbian-config to make sure.
Hi Igor,
thanks for this hint!
But i still need the build directory and I have no idea how to get it created and filled with the tools to get the compilation done.
compile with KDIR=/lib/modules/4.19.62-sunxi/build/, at /home/pi/tools/CAN/can4linux_svn273/can4linux
CC = cc
make    -C /lib/modules/4.19.62-sunxi/build/ C=0 M=/home/pi/tools/CAN/can4linux_svn273/can4linux TARGET=BANANAPI modules
make[1]: *** /lib/modules/4.19.62-sunxi/build/: No such file or directory.  Stop.
Makefile:664: recipe for target 'all' failed
make: *** [all] Error 2
Please can you help again ?
Many Thanks
wollik
kernel-headers-$(uname -r) is not kernel header package name provided by armbian. the real name is linux-headers-next-sunxi_5.31
linux-headers-{branch}-{family}_{armbian version} is the syntax.
it is in /etc/armbian-release , it is updated with board package, but I don't know whether kernel header package is update with board package?
need @Igor to answer.
If installed, yes, otherwise not. This is the correct way:
apt install linux-headers-${BRANCH}-${FAMILY}
I'm trying to compile a wifi driver for RTL8898ES chip on my S905x box which is running Armbian 20.10.1 Focal with Linux 5.9.0-arm-64.
I can't get the kernel-headers installed either within the armbian-config menu or all the above apt install commands. It reported it can't find the kernel header files.
sudo apt install linux-headers-${BRANCH}-${FAMILY}
[sudo] password for bthoven:
E: Unable to locate package linux-headers-
bthoven@bthoven-X96:~$ sudo apt-get install kernel-headers-$(uname -r)
E: Unable to locate package kernel-headers-5.9.0-arm-64
E: Couldn't find any package by glob 'kernel-headers-5.9.0-arm-64'
E: Couldn't find any package by regex 'kernel-headers-5.9.0-arm-64'
Anyone has succeeded doing it lately?
Thanks
