xwiggen Posted May 18, 2020 Share Posted May 18, 2020 see title, can help setup letsencrypt cron if needed Link to comment Share on other sites More sharing options...
Igor Posted May 18, 2020 Share Posted May 18, 2020 Fixed. It is something with cronjob / permission. Manual script run solved the issue. 3 hours ago, xwiggen said: see title, can help setup If you find something: https://armbian.atlassian.net/projects/AR/issues/?filter=allissues& Give PM to @lanefu or @Igor for write access. Thanks! Link to comment Share on other sites More sharing options...
