chriss Posted May 19, 2020 Share Posted May 19, 2020 Armbianmonitor: http://ix.io/2mGZ Hello everyone, odroid xu4 user here with buster minimal 5.4 from https://dl.armbian.com/odroidxu4/Buster_current_minimal please have a look at the following output ... May 19 12:58:11 localhost kernel: [ 1581.893003] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250) May 19 12:58:12 localhost kernel: [ 1582.352546] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) May 19 12:58:12 localhost kernel: [ 1582.389396] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) May 19 12:58:12 localhost kernel: [ 1582.426230] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) ... This messages repeat multiple times every second. Board is running fine except the messages spamming my log Link to comment Share on other sites More sharing options...
Igor Posted May 19, 2020 Share Posted May 19, 2020 2 minutes ago, chriss said: Board is running fine except the messages spamming my log Kernel 5.x for Odroid XU4 is still considered experimental, not fully supported yet. There will be troubles here, troubles there. In case you worry about, use stock K4.14.y 2 minutes ago, chriss said: Hello Hello! Link to comment Share on other sites More sharing options...
chriss Posted May 20, 2020 Author Share Posted May 20, 2020 Hi Igor, thank you for your blazing fast answer! Unfortunately, I can only post once, every 24 hours? I downgraded the kernel via sudo apt-get install armbian-config result: Linux odroidxu4 4.14.150-odroidxu4 #2 SMP PREEMPT Mon Oct 28 08:07:45 CET 2019 armv7l GNU/Linux This seemed to help for like one reboot, the messages are back now. Link to comment Share on other sites More sharing options...
chriss Posted May 21, 2020 Author Share Posted May 21, 2020 Hi, reinstalled using https://dl.armbian.com/odroidxu4/Buster_legacy running kernel Linux odroidxu4 4.14.180-odroidxu4 #16 SMP PREEMPT Wed May 20 19:58:06 CEST 2020 armv7l GNU/Linux still the same issue. updated diagnosis I think it has something to do with the empty emmc slot: SD Card: cat /sys/kernel/debug/mmc1/ios clock: 200000000 Hz actual clock: 200000000 Hz vdd: 16 (2.8 ~ 2.9 V) bus mode: 2 (push-pull) chip select: 0 (don't care) power mode: 2 (on) bus width: 2 (4 bits) timing spec: 6 (sd uhs SDR104) signal voltage: 1 (1.80 V) driver type: 0 (driver type B) MMC slot: clock: 0 Hz vdd: 7 (1.65 - 1.95 V) bus mode: 2 (push-pull) chip select: 0 (don't care) power mode: 1 (up) bus width: 0 (1 bits) timing spec: 0 (legacy) signal voltage: 1 (1.80 V) driver type: 0 (driver type B) but it keeps bouncing between different values: MMC Slot with a different reading: clock: 100000 Hz actual clock: 100000 Hz vdd: 7 (1.65 - 1.95 V) bus mode: 2 (push-pull) chip select: 0 (don't care) power mode: 2 (on) bus width: 0 (1 bits) timing spec: 0 (legacy) signal voltage: 1 (1.80 V) driver type: 0 (driver type B) I tried to swap my 64 gig samsung "pro plus Class 10 U3" card for a more generic Sandisk 64 gig Class 10 UHS 1 card, also no difference.. Link to comment Share on other sites More sharing options...
