Date synchronization
Romber
I run this command I saw that my system clock is not synchronized.
destructor@orangepiplus:~$ timedatectl
               Local time: Mon 2020-05-18 14:05:45 EEST
           Universal time: Mon 2020-05-18 11:05:45 UTC
                 RTC time: Tue 1970-01-06 15:48:55
                Time zone: Europe/Kiev (EEST, +0300)
System clock synchronized: no
              NTP service: inactive
          RTC in local TZ: no
So how can I active ntp server?
I undestand that is common Linux OS question but when I installed Linux OS on PC devices it never disturb me because there it worked as default
          RTC in local TZ: no
You'll need to check your chrony config (https://chrony.tuxfamily.org/index.html) which is enabled by default.
12 hours ago, Werner said:
armbianmonitor -u
destructor@orangepiplus:~$ armbianmonitor -u
Network/firewall problem detected. Not able to upload debug info.
Please fix this or use "-U" instead and upload whole output manually
timedatectl belongs to the timesyncd - which is normally used on the ubuntu-desktop.
If you use armbian then normally ntpd or chronyd is used.
To enable ntp for timesyncd
( see also https://askubuntu.com/questions/1058593/how-to-sync-the-time-to-network-with-timedatectl-on-ubuntu-18-04 )
use
sudo timedatectl set-ntp true
or
timedatectl set-ntp 1
then check id it does work via
systemctl status systemd-timesyncd.service
check also if the ntp-servers in /etc/systemd/timesyncd.conf are reachable
(german: https://www.dinotools.de/2015/01/12/zeit-per-systemd-mit-timesyncd-synchronisieren/ )
or use chronyd ;)
Ahhh :) if you cant upload the log maybe you also cant reach the ntp server - so no sychonisation! :)
For a test I deinstalled chrony on my armbian and armbian did automatically install/activate me timesyncd as replacement:
Spoiler
root@npi-neo2-24(192.168.6.24):~# apt remove chrony
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  systemd-timesyncd
The following packages will be REMOVED:
  chrony
The following NEW packages will be installed:
  systemd-timesyncd
0 upgraded, 1 newly installed, 1 to remove and 0 not upgraded.
Need to get 123 kB of archives.
After this operation, 314 kB disk space will be freed.
Do you want to continue? [Y/n]
Get:1 http://httpredir.debian.org/debian bullseye/main arm64 systemd-timesyncd arm64 245.5-3 [123 kB]
Fetched 123 kB in 1s (244 kB/s)
dpkg: chrony: dependency problems, but removing anyway as you requested:
 systemd depends on systemd-timesyncd | time-daemon; however:
  Package systemd-timesyncd is not installed.
  Package time-daemon is not installed.
  Package chrony which provides time-daemon is to be removed.
(Reading database ... 37771 files and directories currently installed.)
Removing chrony (3.5-8) ...
Selecting previously unselected package systemd-timesyncd.
(Reading database ... 37741 files and directories currently installed.)
Preparing to unpack .../systemd-timesyncd_245.5-3_arm64.deb ...
Unpacking systemd-timesyncd (245.5-3) ...
Setting up systemd-timesyncd (245.5-3) ...
Created symlink /etc/systemd/system/sysinit.target.wants/systemd-timesyncd.service → /lib/systemd/system/systemd-timesyncd.service.
Processing triggers for dbus (1.12.16-2) ...
Processing triggers for man-db (2.9.1-1) ...
and timedatectl is working fine :)
root@npi-neo2-24(192.168.6.24):~# timedatectl
               Local time: Wed 2020-05-20 22:29:21 +03
           Universal time: Wed 2020-05-20 19:29:21 UTC
                 RTC time: Wed 2020-05-20 19:29:23
                Time zone: Asia/Istanbul (+03, +0300)
System clock synchronized: yes
              NTP service: active
          RTC in local TZ: no
  Reveal hidden contents
  systemd-timesyncd
  chrony
  systemd-timesyncd
              NTP service: active
          RTC in local TZ: no
But not in my server
firstly you need to get your network running (incl. internet-access) to complete
- armbianmonitor -u
- systemctl status systemd-timesyncd.service
and
- timedatectl
to check if you can connect to the internet/ntp-servers and what kind of armbian you run
Without that information is mostly impossible to help :(
         _,met$$$$$gg.           @orangepiplus
      ,g$$$$$$$$$$$$$$$P.        OS: Debian 10 buster
    ,g$$P""       """Y$$.".      Kernel: armv7l Linux 5.4.35-sunxi
   ,$$P'              `$$$.      Uptime: 2d 28m
  ',$$P       ,ggs.     `$$b:    Packages: 961
  `d$$'     ,$P"'   .    $$$     Shell: 21642
   $$P      d$'     ,    $$P     CPU: ARMv7 rev 5 (v7l) @ 4x 1.368GHz
   $$:      $$.   -    ,d$$'     GPU:
   $$\;      Y$b._   _,d$P'      RAM: 172MiB / 2012MiB
   Y$$.    `.`"Y$$$$P"'
   `$$b      "-.__
    `Y$$
     `Y$$.
       `$$b.
         `Y$$b.
            `"Y$b._
@orangepiplus:~$ systemctl status systemd-timesyncd.service
● systemd-timesyncd.service - Network Time Synchronization
   Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled; vendor preset: enabled)
  Drop-In: /lib/systemd/system/systemd-timesyncd.service.d
           └─disable-with-time-daemon.conf
   Active: inactive (dead)
Condition: start condition failed at Tue 2020-05-19 12:33:35 EEST; 24h ago
     Docs: man:systemd-timesyncd.service(8)
May 18 12:56:57 orangepiplus systemd[1]: Condition check resulted in Network Time Synchronization being skipped.
May 19 12:33:01 orangepiplus systemd[1]: Condition check resulted in Network Time Synchronization being skipped.
May 19 12:33:35 orangepiplus systemd[1]: Condition check resulted in Network Time Synchronization being skipped.
               Local time: Wed 2020-05-20 13:26:14 EEST
           Universal time: Wed 2020-05-20 10:26:14 UTC
                 RTC time: Thu 1970-01-08 15:09:11
          RTC in local TZ: no
What @guidol is saying is that without internet connectivity you won't be able to NTP sync your clock (as NTP = network time protocol). The fact that 'armbianmonitor -u' is unable to upload you debug info indicates there's a problem with your network.
Please use 'armbianmonitor -U' (notice capital U, see also note given in your output) and upload the results manually or post them here (try using a codebox).
If this does not work for you atleast try something like 'ping google.com' to make sure your board can even connect to the internet. Otherwise NTP will not work.
All these messages show us, that you network isnt working or isnt working correct.
How did you configure your network? Network-Manager? /etc/network/interfaces? armbian-config?
Can you ping 8.8.8.8?
Can you ping armbian.com?
What says ifconfig for eth0 or wlan0?
whats the IP of your gateway/DNS?
what is the content of /etc/resolv.conf (when not using network-manager)
Network is connected. ping Google.com is executing good.  armbianmonitor -U shows very much text.
destructor@orangepiplus:~$ cat /etc/network/interfaces
source /etc/network/interfaces.d/*
# Network is managed by Network manager
auto lo iface lo inet loopback
All ping work
:28:19 2020 from destructor@orangepiplus:~$ sudo ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500         inet 192.168.0.104  netmask 255.255.255.0  broadcast 192.168.0.255         inet6 fe80::8e0:7c3e:c125:9a2a  prefixlen 64  scopeid 0x20<link>         ether 02:81:7d:85:f6:f7  txqueuelen 1000  (Ethernet)         RX packets 117227  bytes 98206563 (93.6 MiB)         RX errors 0  dropped 0  overruns 0  frame 0         TX packets 68716  bytes 8157760 (7.7 MiB)         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0         device interrupt 32  lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536         inet 127.0.0.1  netmask 255.0.0.0         inet6 ::1  prefixlen 128  scopeid 0x10<host>  loop  txqueuelen 1000  (Local Loopback)         RX packets 302  bytes 15100 (14.7 KiB)         RX errors 0  dropped 0  overruns 0  frame 0         TX packets 302  bytes 15100 (14.7 KiB)         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0  wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500         ether e0:b9:4d:1e:8e:3f  txqueuelen 1000  (Ethernet)         RX packets 0  bytes 0 (0.0 B) RX errors 0  dropped 0  overruns 0  frame 0         TX packets 0  bytes 0 (0.0 B) TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
destructor@orangepiplus:~$ cat /etc/resolv.conf
# Generated by NetworkManagernameserver 8.8.8.8 nameserver 192.168.0.1
# sudo ufw reset
# armbianmonitor -u
# ntpdate -vd <ntpserver>
5 hours ago, xwiggen said:
# sudo ufw reset
# armbianmonitor -u
sudo: ufw: command not found
Ok, I've installed it.
@orangepiplus:~$ sudo ufw reset
Resetting all rules to installed defaults. This may disrupt existing ssh
connections. Proceed with operation (y|n)? y
Backing up 'user.rules' to '/etc/ufw/user.rules.20200522_144043'
Backing up 'before.rules' to '/etc/ufw/before.rules.20200522_144043'
Backing up 'after.rules' to '/etc/ufw/after.rules.20200522_144043'
Backing up 'user6.rules' to '/etc/ufw/user6.rules.20200522_144043'
Backing up 'before6.rules' to '/etc/ufw/before6.rules.20200522_144043'
Backing up 'after6.rules' to '/etc/ufw/after6.rules.20200522_144043'
What is next? I think that I more and more break my system
I'm pretty sure you started with a debian img and migrated to armbian:
# fping armbian.com
yields command not find, right?
Anyhow, looks like fake hwclock failed to retain at least the datetime after last package install/reboot/shutdown.
That's bad cause pretty much anything in userspace assumes datetime only moves forward.
Start with a clean armbian image for your board (https://www.armbian.com/download) and come back if ntp is still not working.
# fping armbian.com
Anyhow, looks like fake hwclock failed to retain at least the datetime after last package install/reboot/shutdown, maybe because /var is optimized in armbian (ram sync) and possibly not in debian resulting in an empty hwclock file.
On 5/23/2020 at 1:22 AM, xwiggen said:
motd seems weird. did you start with a debian image
this seems to be an optional systeminfo-"tool" named neofetch:
https://github.com/dylanaraps/neofetch
Quote
Neofetch is a command-line system information tool written in bash 3.2+. Neofetch displays information about your operating system, software and hardware in an aesthetic and visually pleasing way.
Installation:
https://github.com/dylanaraps/neofetch/wiki/Installation
2 examples:
root@npi-neo2-24(192.168.6.24):/home/guido/neofetch# neofetch
       _,met$$$$$gg.          root@npi-neo2-24
    ,g$$$$$$$$$$$$$$$P.       ----------------
  ,g$$P"     """Y$$.".        OS: Debian GNU/Linux bullseye/sid aarch64
 ,$$P'              `$$$.     Host: FriendlyARM NanoPi NEO 2
',$$P       ,ggs.     `$$b:   Kernel: 5.6.12-sunxi64
`d$$'     ,$P"'   .    $$$    Uptime: 4 days, 1 hour, 49 mins
 $$P      d$'     ,    $$P    Packages: 534 (dpkg)
 $$:      $$.   -    ,d$$'    Shell: bash 5.0.16
 $$;      Y$b._   _,d$P'      Terminal: /dev/pts/0
 Y$$.    `.`"Y$$$$P"'         CPU: sun50iw1p1 (4) @ 1.008GHz
 `$$b      "-.__              Memory: 124MiB / 987MiB
  `Y$$
   `Y$$.
     `$$b.
       `Y$$b.
          `"Y$b._
root@fox-g20(192.168.6.15):/home/guido/neofetch# neofetch
       _,met$$$$$gg.          root@fox-g20
  ,g$$P"     """Y$$.".        OS: Debian GNU/Linux 9 (stretch) armv5tejl
 ,$$P'              `$$$.     Host: Acme Systems FOX Board G20
',$$P       ,ggs.     `$$b:   Kernel: 4.9.124+
`d$$'     ,$P"'   .    $$$    Uptime: 1 day, 11 hours, 22 mins
 $$P      d$'     ,    $$P    Packages: 442 (dpkg)
 $$:      $$.   -    ,d$$'    Shell: bash 4.4.12
 Y$$.    `.`"Y$$$$P"'         CPU: Atmel AT91SAM9 (1)
 `$$b      "-.__              Memory: 10MiB / 56MiB
  `Y$$
   `Y$$.
     `$$b.
       `Y$$b.
          `"Y$b._
see also:
https://www.omgubuntu.co.uk/2016/11/neofetch-terminal-system-info-app
Installation:
2 examples:
  `Y$$
   `Y$$.
     `$$b.
       `Y$$b.
          `"Y$b._
  `Y$$
   `Y$$.
     `$$b.
       `Y$$b.
          `"Y$b._
see also:
Ah thx, didn't know about this packagw.
On 5/24/2020 at 10:46 AM, Heisath said:
Can you tell us which image you installed? MOTD really does seem weird.
destructor@orangepiplus:~$ screenfetch
         _,met$$$$$gg.           destructor@orangepiplus
   ,$$P'              `$$$.      Uptime: 1m
  ',$$P       ,ggs.     `$$b:    Packages: 963
  `d$$'     ,$P"'   .    $$$     Shell: 1583
   $$\;      Y$b._   _,d$P'      RAM: 169MiB / 2012MiB
   Y$$.    `.`"Y$$$$P"'
   `$$b      "-.__
    `Y$$
     `Y$$.
       `$$b.
         `Y$$b.
            `"Y$b._
On 5/27/2020 at 8:37 PM, Romber said:
You're wrong. I installed clean armbian image.
You miss fping which is installed by default and used by armbianmonitor to check network availability (uploading).
Go ahead, install it and try armbianmonitor -u.
The only other possible explanation I can think of not reaching NTP servers is that your ISP is blocking remote NTP servers (DDOS mitigation), that happens rarely, is easily checked by 'ntpdate -vd pool.ntp.org' (non privileged port, so not blocked), or even simpler, use your gateway ip as most routers broadcast it anyway.
destructor@orangepiplus:~$ sudo apt install fping
[sudo] password for destructor:
fping is already the newest version (4.2-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
