1 1
laurentppol
OPi 3 display problem(?)
Hi there,
just got OPi3 (4x 1.8GHz, 2GB RAM, eMMC), and I have (probably) issue with display settings (resolution / refresh rate?).
I have an 1280x1024@60Hz VGA monitor, connected to an KVM switch (VGA+USB), then to HDMI->VGA converter. It worked OK for my 2 OPiPC+.
Now what happens when I connect OPi3 instead od one of OPiPC+:
- installed "OOB" Armbian Buster for OPi3, (server),
- during initial startup there was NO question about monitor resolution (differs from initial startup for PC+),
- only login / new user dialog.
- now screen "flickers", text mode for few seconds, then blank screen, "power" LED of monitor is lit, like there is signal. Random periods.
- can user armbian-config to set up basic parameters, network and install "desktop",
- can SSH and do remote X session,
- during boot-up to GUI there is NO display at all.
- if I log in as root (CLI) and then issue "startx", GUI starts, but shifted 1/4 screen high (part of GUI offscreen), 1/4 screen high black bar on bottom.
Questions:
- hardware problem, or Armbian config problem?
- how do I change screen resolution / refresh rate (CLI or GUI)? For text mode and X.
Share this post
Link to post
Share on other sites
1 1
