darkgeekyang Posted May 15, 2020 Share Posted May 15, 2020 (edited) Hi, all: Today I just upgraded my packages as normal, by using "apt update && apt upgrade", on my RockPi 4B (legacy kernel), and I saw there was a hostapd package updated. However, after this upgrade, my hostapd won't start anymore now: Configuration file: /etc/hostapd.conf wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE Using interface wlan0 with hwaddr 6c:21:a2:37:ff:1a and ssid "RockPi-Armbian" Failed to set beacon parameters Interface initialization failed wlan0: interface state COUNTRY_UPDATE->DISABLED wlan0: AP-DISABLED wlan0: Unable to setup interface. wlan0: interface state DISABLED->DISABLED wlan0: AP-DISABLED wlan0: CTRL-EVENT-TERMINATING hostapd_free_hapd_data: Interface wlan0 wasn't started nl80211: deinit ifname=wlan0 disabled_11b_rates=0 The culprit might be "Failed to set beacon parameters", but not for sure, even if I search on Google and still couldn't figure it out. The following is the output of "sudo armbianmonitor -U": See here Not sure if it's a RockPi specific or common issue. If you need more information, just tell me. Thanks. Edited May 15, 2020 by darkgeekyang Link to comment Share on other sites More sharing options...
Igor Posted May 15, 2020 Share Posted May 15, 2020 2 hours ago, darkgeekyang said: Today I just upgraded my packages as normal, by using "apt update && apt upgrade", on my RockPi 4B (legacy kernel), and I saw there was a hostapd package updated. However, after this upgrade, my hostapd won't start anymore now: We have no capacity to test this function on upgrade yet, but at least testing - that we will know it fails - will be probably established by the end of this year. 2 hours ago, darkgeekyang said: If you need more information Who needs more information? Check support terms https://github.com/armbian/build#support Link to comment Share on other sites More sharing options...
Quang-vip Posted May 24, 2020 Share Posted May 24, 2020 So I was trying to set up a portable wifi hotspot on my Orange Pi Zero (running Armbian buster with Linux 5.4.34-sunxi). But whenever I try to enable wifi hotspot on it through armbian-config, it refuses to create a hotspot. When I looked closely, it tried to probe the nl80211 driver without any error but then it also tried to probe realtek's driver, which is rtl871xdrv according to hostapd.conf in /etc . During its probing, in the corner of the terminal, it said: ioctl[SIOCSIWMODE]: Invalid argument And as a result, it returned the No compatible driver found error. I even tried to make NetworkManager ignore it (wlan0) and stop NetworkManager before enabling the hotspot, and start hostapd manually but no positive results. I'm using the pi's built-in wifi chip - XR819, I'm aware that this wifi chipset isn't greatly supported but before all of this mess, it ran without any hassle. I only encountered this problem after doing an apt upgrade. And I also tried to downgrade hostapd to an earlier version - 2.7 - but still, nothing. What can I do to make hostapd working again? Any help would be appreciated! I also included a screenshot of hostapd when I manually start it. Link to comment Share on other sites More sharing options...
Igor Posted May 24, 2020 Share Posted May 24, 2020 33 minutes ago, Quang-vip said: But whenever I try to enable wifi hotspot on it through armbian-config, it refuses to create a hotspot. https://armbian.atlassian.net/browse/AR-245 Planned to look into this in the upcoming months. 33 minutes ago, Quang-vip said: What can I do to make hostapd working again? Manual way ... All those project are open source, there is a documentation for hostapd and network manager way. Both project are independent from Armbian. Try using attached hostapd. hostapd_2.9-99~armbian5.98+1_armhf.deb Link to comment Share on other sites More sharing options...
Igor Posted May 24, 2020 Share Posted May 24, 2020 In progress https://github.com/armbian/build/pull/1985 Link to comment Share on other sites More sharing options...
Quang-vip Posted May 24, 2020 Share Posted May 24, 2020 Quote Try using attached hostapd. Surprisingly, it successfully ran with the config file in /etc, the network showed up in my phone But what I see weird is that despite the correct password I put into my phone, it didn't want to authenticate. I double checked the password in the config file and the one in my phone, they're the same but it kept telling me it wasn't correct Maybe I missed something or I didn't set it up correctly. But thanks for your temporary solution Link to comment Share on other sites More sharing options...
Igor Posted May 24, 2020 Share Posted May 24, 2020 1 hour ago, Quang-vip said: it didn't want to authenticate Try armbian-config now. It should work, but AC mode doesn't work. I already waste afternoon ... Link to comment Share on other sites More sharing options...
Quang-vip Posted May 25, 2020 Share Posted May 25, 2020 Well, suddenly NetworkManager keeps telling rfkill to block the wlan interface (happens on boot and everytime I restart NetworkManager). But what's weirder is that even after I unblock the interface, it still can't scan for any wifi network. And as a result, the option to create a hotspot in armbian-config isn't available. However, if I start hostapd manually (an updated version thru apt I just updated yesterday), it will open a hotspot with that config file. But sadly it still doesn't want to authenticate. Welp I'll make more investigation on this. Link to comment Share on other sites More sharing options...
Quang-vip Posted May 29, 2020 Share Posted May 29, 2020 Good news Several days ago, I tried armbian-config again to try to create a hotspot. And surprisingly, it worked :DD The hotspot has been running for days now. Thanks for your hard work @Igor, I really appreciate it 1 Link to comment Share on other sites More sharing options...
