egg Posted June 2, 2020 Share Posted June 2, 2020 The Espresobin wiki says 2 x Gigabit Ethernet 1Gbps / 2.5Gbps SGMII / HS-SGMII / RGMII Does that mean we actually have 2.5Gbps Nic x2? I also find this link But it's saying Quote ..and I think i'm officially convinced that the max bandwidth between topaz switch and cpu is in fact 1gigabit... The connection is using a seperate RGMII lane. (eth0) And there is even an official wiki talking about 2.5Gbps. Anyone has any luck on 2.5Gbps mode? 0 Quote Link to comment Share on other sites More sharing options...
Heisath Posted June 3, 2020 Share Posted June 3, 2020 The information you linked indicating there is 2.5Gbps mode is always only for the chip (Armada 3700) used on the espressobin. This Marvell chip does have the 2.5Gbps interface. That is also the reason it is explained on Marvell github. The espressobin itself has all 3 ethernet ports wired through one switch with only RGMII going in. As can be seen here: http://wiki.espressobin.net/tiki-index.php?page=Block+diagram As only one RGMII is feeding all 3 ports I dont think 2.5Gbps will be possible on any of them. 2 Quote Link to comment Share on other sites More sharing options...
egg Posted July 9, 2020 Author Share Posted July 9, 2020 (edited) Yeah, I noticed it's kind of lame the single RGMII is bottlenecking the forwarding performance. I am using openwrt 19.07 and benchmarking the nat forwarding performance, it turns out for 1Gbps from wan to lan0, the eth0 has 1Gbps traffic on both RX and TX. So the 3 Nics are sharing single a 1Gbps on eth0, which is kind of slow for some use cases. PRC | sys 4.15s | user 0.02s | | | #proc 63 | #trun 2 | #tslpi 34 | #tslpu 0 | #zombie 0 | clones 0 | | | no procacct | CPU | sys 2% | user 0% | irq 149% | | idle 49% | wait 0% | steal 0% | guest 0% | | ipc notavail | cycl unknown | avgf 724MHz | avgscal 90% | cpu | sys 1% | user 0% | irq 76% | | idle 23% | cpu000 w 0% | steal 0% | guest 0% | | ipc notavail | cycl unknown | avgf 724MHz | avgscal 90% | cpu | sys 0% | user 0% | irq 74% | | idle 26% | cpu001 w 0% | steal 0% | guest 0% | | ipc notavail | cycl unknown | avgf 724MHz | avgscal 90% | CPL | avg1 0.50 | | avg5 0.48 | avg15 0.39 | | | csw 32526 | | intr 513384 | | | numcpu 2 | | MEM | tot 999.0M | free 944.9M | cache 11.3M | dirty 0.0M | buff 1.1M | slab 21.8M | slrec 12.4M | shmem 1.4M | shrss 0.0M | shswp 0.0M | vmbal 0.0M | hptot 0.0M | hpuse 0.0M | SWP | tot 0.0M | free 0.0M | | | | | | | | | vmcom 11.9M | | vmlim 499.5M | NET | eth0 85% | pcki 880470 | pcko 880566 | sp 1000 Mbps | si 852 Mbps | so 853 Mbps | | coll 0 | mlti 0 | erri 0 | erro 0 | drpi 0 | drpo 0 | NET | lan0 81% | pcki 166027 | pcko 709256 | sp 1000 Mbps | si 29 Mbps | so 813 Mbps | | coll 0 | mlti 0 | erri 0 | erro 0 | drpi 0 | drpo 0 | NET | wan 80% | pcki 712159 | pcko 168320 | sp 1000 Mbps | si 808 Mbps | so 31 Mbps | | coll 0 | mlti 0 | erri 0 | erro 0 | drpi 0 | drpo 0 | NET | lan1 0% | pcki 2284 | pcko 2722 | sp 1000 Mbps | si 127 Kbps | so 2318 Kbps | | coll 0 | mlti 0 | erri 0 | erro 0 | drpi 1 | drpo 0 | Edited July 9, 2020 by egg 0 Quote Link to comment Share on other sites More sharing options...
Heisath Posted July 9, 2020 Share Posted July 9, 2020 Yep the Espressobin is not optimal for routing / switching. If you need multiple eth's maybe look at the PCEngines boards (APU2) which have up to 4 dedicated Gbit ports. https://pcengines.ch/apu4d4.htm Or check the Clearfogpro / base. These atleast have a seperate SFP port, which can be used as copper/fiber with up to 2.5Gbit/s and additional LANs. 0 Quote Link to comment Share on other sites More sharing options...
sfx2000 Posted July 11, 2020 Share Posted July 11, 2020 >> Yep the Espressobin is not optimal for routing / switching. mixed feelings here - espressobin includes topaz... which is really the limit... MV3720 is fast enough - across BR-LAN on a specific design, it's fast enough. 0 Quote Link to comment Share on other sites More sharing options...
egg Posted July 12, 2020 Author Share Posted July 12, 2020 (edited) I might switch to rpi4(1Gbps + usb 3.0 ethernet adapter) or NanoPi R2S(1Gbp x2 RK3328) or NanoPi NEO3 (1Gbps x1 + Usb3.0 RK3328), or just hEX once I get bored of SBC DIY stuff. Both APUx or Clearfogpro are way above my budget. Edited July 12, 2020 by egg 0 Quote Link to comment Share on other sites More sharing options...
