DevShanky Posted June 5, 2020 Share Posted June 5, 2020 Device: Orange Pi +2e. Builds 20.20, 20.05, 20.08 The Armbian Boot Logo is shown only when we boot from SD Card. Do nand-sata-install to eMMC and boot from eMMC, the logo disappears. Could this be a timing issue as it boots faster on eMMC? I do not see any flicker or flash during u-boot. --Rajesh 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted June 5, 2020 Share Posted June 5, 2020 armbianmonitor -u 0 Quote Link to comment Share on other sites More sharing options...
DevShanky Posted June 5, 2020 Author Share Posted June 5, 2020 5 minutes ago, Werner said: armbianmonitor -u Armbianmonitor log: http://ix.io/2omP --Rajesh 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted June 5, 2020 Share Posted June 5, 2020 Not sure about this one. I know that for some boards the logo has been disabled to enhance HDMI detection. logo=disabled You can try to play with this value in /boot/armbianEnv.txt 0 Quote Link to comment Share on other sites More sharing options...
DevShanky Posted June 5, 2020 Author Share Posted June 5, 2020 11 minutes ago, Werner said: Not sure about this one. I know that for some boards the logo has been disabled to enhance HDMI detection. logo=disabled You can try to play with this value in /boot/armbianEnv.txt logo=enabled does not help. I am aware about logo being disabled for HDMI Patch. I applied these patches to 20.08-trunk to get the logo enabled 1. disable patch xxx-disable-de2-to-improve-edid-detection.patch 2. enable patch remove-boot-messages-from-hdmi.patch I works for 20.08-trunk but only on SD Card. Flash the image on eMMC and the boot logo disappears. I did armbianmonitor -u after boot from SD Card for comparison ( http://ix.io/2omV ) and compared the two logs. They are absolutely same until about 6 seconds when the kernel starts to load. --Rajesh 0 Quote Link to comment Share on other sites More sharing options...
DevShanky Posted June 5, 2020 Author Share Posted June 5, 2020 These are the initial boot messages I see while booting from onboard eMMC vs SD Card Onboard eMMC: SD Card / Show Logo: Does this ring any bells? --Rajesh 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted June 6, 2020 Share Posted June 6, 2020 16 hours ago, Rajesh said: Does this ring any bells? /boot/boot.env is only present if a u-boot "saveenv" has been executed. The 230454 file read is the /boot//boot.bmp logo ... 0 Quote Link to comment Share on other sites More sharing options...
DevShanky Posted June 6, 2020 Author Share Posted June 6, 2020 I am trying to make sense of all of this but it is getting more complicated for me. I read this message on the forum which includes you comments but appears beyond my capability to deal with this. If you can give me little more pointers on how to deal with this, I will try to give my best. Best Regards Rajesh 0 Quote Link to comment Share on other sites More sharing options...
DevShanky Posted June 7, 2020 Author Share Posted June 7, 2020 There was this patch introduced when HDMI driver was added - sunxi-boot-splash.patch: It appears that this patch always looks for boot.bmp in mmc 0. Probably this is why the boot.bmp is displayed only when I boot from SD card. When I boot from onboard eMMC, mmc device number is 2 and not 0. I will try to load bitmap in boot.cmd and see if this makes the difference. --Rajesh 0 Quote Link to comment Share on other sites More sharing options...
DevShanky Posted June 7, 2020 Author Share Posted June 7, 2020 Resolved: I added this code in boot.cmd and did 'mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr' The boot logo is now shown when I boot from splash also. Hope this help to anyone facing similar issue. -Rajesh 0 Quote Link to comment Share on other sites More sharing options...
MikePooh Posted September 30, 2020 Share Posted September 30, 2020 It is so nice that you post the code as image. Please let me paste it as code. if test -e ${devtype} ${devnum} ${prefix}boot.bmp; then splashpos=m,m splashimage=66000000 load ${devtype} ${devnum} ${splashimage} ${prefix}boot.bmp bmp d ${splashimage} fi P.S. Code works. 1 Quote Link to comment Share on other sites More sharing options...
