Darkyere Posted June 16, 2020 Share Posted June 16, 2020 I have an OPZ+ server with Armbian buster that has the following information cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepizeroplus BOARD_NAME="Orange Pi Zero Plus" BOARDFAMILY=sun50iw2 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=c865c065-dirty VERSION=5.91 LINUXFAMILY=sunxi64 BRANCH=next ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster uname -a Linux orangepizeroplus 4.19.63-sunxi64 #5.92 SMP Fri Aug 2 00:18:27 CEST 2019 aarch64 GNU/Linux ---- I see on the download page of Armbian OPZ+ That there is a new version of Armbian out. Armbian_20.05.2_Orangepizeroplus_buster_current_5.4.43.img.xz As you can see i am currently running the 4.19 kernel and version 5.91 of Armbian. ---- How do i go around to upgrade my current Armbian to the Newest version of Armbian. As in upgrade or similar. I dont wish to reinstall to much work in that. ---- Ty for reading, Darkyere 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted June 16, 2020 Share Posted June 16, 2020 You can use armbian-config to switch to the current kernel branch. For the rest a simple upgrade should do it. 0 Quote Link to comment Share on other sites More sharing options...
Darkyere Posted June 16, 2020 Author Share Posted June 16, 2020 Is that under Armbian-config -> System Settings -> Other (Switch to other kernels) And then just pick the newest version. Or do i go about it some where else i armbian-config? 0 Quote Link to comment Share on other sites More sharing options...
Darkyere Posted June 16, 2020 Author Share Posted June 16, 2020 Ty for pointing me in the right direction. I found this site and it explained what to do. So i choose the current branch and now everything looks like this cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepizeroplus BOARD_NAME="Orange Pi Zero Plus" BOARDFAMILY=sun50iw2 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=eb9dad92 DISTRIBUTION_CODENAME=buster DISTRIBUTION_STATUS=supported VERSION=20.05.2 LINUXFAMILY=sunxi64 BRANCH=current ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster uname -a Linux orangepizeroplus 5.4.43-sunxi64 #20.05.2 SMP Tue Jun 2 17:20:17 CEST 2020 aarch64 GNU/Linux So i think everything is as it should be. Ty for your time, Darkyere 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted June 16, 2020 Share Posted June 16, 2020 Awesome 0 Quote Link to comment Share on other sites More sharing options...
