Darkyere Posted June 16, 2020 Share Posted June 16, 2020 I have an OPZ+ server with Armbian buster that has the following information cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepizeroplus BOARD_NAME="Orange Pi Zero Plus" BOARDFAMILY=sun50iw2 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=c865c065-dirty VERSION=5.91 LINUXFAMILY=sunxi64 BRANCH=next ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster uname -a Linux orangepizeroplus 4.19.63-sunxi64 #5.92 SMP Fri Aug 2 00:18:27 CEST 2019 aarch64 GNU/Linux ---- I see on the download page of Armbian OPZ+ That there is a new version of Armbian out. Armbian_20.05.2_Orangepizeroplus_buster_current_5.4.43.img.xz As you can see i am currently running the 4.19 kernel and version 5.91 of Armbian. ---- How do i go around to upgrade my current Armbian to the Newest version of Armbian. As in upgrade or similar. I dont wish to reinstall to much work in that. ---- Ty for reading, Darkyere Link to comment Share on other sites More sharing options...
Werner Posted June 16, 2020 Share Posted June 16, 2020 You can use armbian-config to switch to the current kernel branch. For the rest a simple upgrade should do it. Link to comment Share on other sites More sharing options...
Darkyere Posted June 16, 2020 Author Share Posted June 16, 2020 Is that under Armbian-config -> System Settings -> Other (Switch to other kernels) And then just pick the newest version. Or do i go about it some where else i armbian-config? Link to comment Share on other sites More sharing options...
Darkyere Posted June 16, 2020 Author Share Posted June 16, 2020 Ty for pointing me in the right direction. I found this site and it explained what to do. So i choose the current branch and now everything looks like this cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepizeroplus BOARD_NAME="Orange Pi Zero Plus" BOARDFAMILY=sun50iw2 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=eb9dad92 DISTRIBUTION_CODENAME=buster DISTRIBUTION_STATUS=supported VERSION=20.05.2 LINUXFAMILY=sunxi64 BRANCH=current ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster uname -a Linux orangepizeroplus 5.4.43-sunxi64 #20.05.2 SMP Tue Jun 2 17:20:17 CEST 2020 aarch64 GNU/Linux So i think everything is as it should be. Ty for your time, Darkyere Link to comment Share on other sites More sharing options...
Werner Posted June 16, 2020 Share Posted June 16, 2020 Awesome Link to comment Share on other sites More sharing options...
