sbay Posted June 20, 2020 Share Posted June 20, 2020 Hello Community, I'm trying to get Armbian running on my Banana PI M1 with the following image: https://dl.armbian.com/bananapi/archive/Armbian_20.05.2_Bananapi_buster_current_5.4.43_minimal.img.xz I flashed the image with Etcher on my SD Card which is a Sandisk Ultra 16GB SDHC Card. After flashing I have inserted the Card into my Banana PI but I only get a red light, I already tried different images like the bionic image but without positive result and tried different power supply cables. In my DHCP Server I see no request. I have also flashed for testing reasons current image of Bananian which was directly working but I don't want to use that because their project is not under active development anymore and they recommend to use Armbian. I would appreciate any ideas. Link to comment Share on other sites More sharing options...
Igor Posted June 20, 2020 Share Posted June 20, 2020 24 minutes ago, sbay said: I would appreciate any ideas. Start here:https://docs.armbian.com/User-Guide_Getting-Started/ and here:https://forum.armbian.com/forum/31-sd-card-and-psu-issues/ Link to comment Share on other sites More sharing options...
guidol Posted June 20, 2020 Share Posted June 20, 2020 2 hours ago, sbay said: I'm trying to get Armbian running on my Banana PI M1 with the following image: https://dl.armbian.com/bananapi/archive/Armbian_20.05.2_Bananapi_buster_current_5.4.43_minimal.img.xz I did download the image, flashed it to a 8GB(SLC) Toshiba SD-HC Card and boot. DHCP is OK: Quote login as: root root@192.168.6.150's password: ____ ____ _ | __ )| _ \(_) | _ \| |_) | | | |_) | __/| | |____/|_| |_| Welcome to Armbian buster with Linux 5.4.43-sunxi package bsp-kernel[20.05.2] u-boot[20.05.2] dtb [20.05.2] firmware [20.05.2] branch[current] root@bananapi:~# ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.6.150 netmask 255.255.255.0 broadcast 192.168.6.255 inet6 fe80::bf89:abed:4c0d:f8b6 prefixlen 64 scopeid 0x20<link> ether 02:0b:02:01:d6:a4 txqueuelen 1000 (Ethernet) RX packets 1181 bytes 85702 (83.6 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 337 bytes 51150 (49.9 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 61 System diagnosis information has been uploaded to http://ix.io/2pFz @Igor Iam missing the last times the possibility to insert a code-fragment in the forum editor Is that due to answer on questions from new members? because it isnt helpful to give a answer when it cant be formatted in mono-font when copying something from the console 1 Link to comment Share on other sites More sharing options...
hexdump Posted June 20, 2020 Share Posted June 20, 2020 it is sometimes not shown if you have a too small screen - for instance i have this on my thinkpad x61s with its 1024x768 screen - which is my everyday machine ... what helped was to zoom out in firefox (something like 80%) for posting in that case ... Link to comment Share on other sites More sharing options...
