DevShanky Posted June 24, 2020 Share Posted June 24, 2020 There are several variant of Tanix TX6 models listed here https://linux-sunxi.org/Tanix_TX6 and they mostly differ in RAM and eMMC sizes. There is reference to single dtb file there sun50i-h6-tanix-tx6.dtb for all these models. Will this dtb file work with all the models with the Single Armbian Image for RK+AML+AW (aarch64 ARMv8)? If not what changes would be needed in dtb files for these models? Thanks Rajesh Link to comment Share on other sites More sharing options...
Zoom Posted June 25, 2020 Share Posted June 25, 2020 I can say that for my model (TX6a) dtb files from Armbian and LibreElec are probably not working correctly: sound doesn't work (it's buggy even on stock firmware) and HDMI can't identify correct resolution. Link to comment Share on other sites More sharing options...
DevShanky Posted June 25, 2020 Author Share Posted June 25, 2020 1 hour ago, Zoom said: I can say that for my model (TX6a) dtb files from Armbian and LibreElec are probably not working correctly: sound doesn't work (it's buggy even on stock firmware) and HDMI can't identify correct resolution. TX6a is I believe 4 GM RAM / 32 GB eMMC. Well if you are able to boot and bring up the OS then it could be something else and not the DTB file. This is the dts file from @jernej https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/allwinner/sun50i-h6-tanix-tx6.dts You can convert it to dtb and give it a try. If you have issues with your stock firmware also then it might be something to do with the box. --R Link to comment Share on other sites More sharing options...
jernej Posted June 25, 2020 Share Posted June 25, 2020 @Zoom do you have Android image or update file for your TX6a variant? I would like to extract DTB file from it. Link to comment Share on other sites More sharing options...
DevShanky Posted June 25, 2020 Author Share Posted June 25, 2020 1 hour ago, jernej said: @Zoom do you have Android image or update file for your TX6a variant? I would like to extract DTB file from it. Tanix TX6 which I think is of type 6Xa has firmware download available here http://www.tanix-box.com/downloads/ -R Link to comment Share on other sites More sharing options...
Zoom Posted June 26, 2020 Share Posted June 26, 2020 12 hours ago, Rajesh said: If you have issues with your stock firmware also then it might be something to do with the box. --R It may be, but it seems it's not a problem specific to my device. I found a few posts over freaktab and 4pda forums, as well as YT which state sound issues with the stock firmware. No specifics on model version there, though. @jernej I tried to dump the dtb from the recovery partition of the box with extract-dtb, but I'm not sure it was extracted correctly. I can send you the .img of the partition, is it ok? Link to comment Share on other sites More sharing options...
jernej Posted June 28, 2020 Share Posted June 28, 2020 @Zoom yes, but download link is preferable Link to comment Share on other sites More sharing options...
Zoom Posted June 30, 2020 Share Posted June 30, 2020 @jernej here's a stock recovery from my TX6-A. I doubt there will be any difference with other models, but it would be nice to be wrong about this. tx6-a-recovery.img.xz Link to comment Share on other sites More sharing options...
chalesY Posted July 16, 2020 Share Posted July 16, 2020 I find out a tx6 variant board , It use PF2,PF4 for uart pin, and 356,357 for LED and USB power. Link to comment Share on other sites More sharing options...
