David-L Posted June 26, 2020 Share Posted June 26, 2020 Armbianmonitor: http://ix.io/2qgc The module ds2490 seem to be missing in the new release. Should be: /lib/modules/4.19.62-sunxi/kernel/drivers/w1/slaves/w1_ds2490.ko 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted June 27, 2020 Share Posted June 27, 2020 May have been removed while merging upstream config. I'll take a look. Aight there are two options for you: - Replace the legacy with the current kernel which contains this module or - Use the build script to create your own legacy kernel package which then will be up-to-date as well 1 Quote Link to comment Share on other sites More sharing options...
David-L Posted June 30, 2020 Author Share Posted June 30, 2020 I'll try the current kernel! Thanks 0 Quote Link to comment Share on other sites More sharing options...
