How to install Radxa SATA HAT driver on armbian-RockPI 4A
dpSky
I use Armbian_20.05.3_Rockpi-4a_buster_legacy_4.4.213
The armbian kernel version uses 4.4-213
Follow the radxa official installation script:
curl -sL https://rock.sh/get-rockpi-penta | sudo -E bash -
The output is as follows:
Quote
root@rockpi-4a:~# curl -sL https://rock.sh/get-rockpi-penta | sudo -E bash -
(Reading database ... 56045 files and directories currently installed.)
Preparing to unpack /tmp/tmp.pMsOHNj5fC ...
Removed /etc/systemd/system/multi-user.target.wants/rockpi-penta.service.
Unpacking rockpi-penta (0.10) over (0.10) ...
Setting up rockpi-penta (0.10) ...
Created symlink /etc/systemd/system/multi-user.target.wants/rockpi-penta.service → /lib/systemd/system/rockpi-penta.service.
running install
running bdist_egg
running egg_info
creating Adafruit_SSD1306.egg-info
writing Adafruit_SSD1306.egg-info/PKG-INFO
writing dependency_links to Adafruit_SSD1306.egg-info/dependency_links.txt
writing requirements to Adafruit_SSD1306.egg-info/requires.txt
writing top-level names to Adafruit_SSD1306.egg-info/top_level.txt
writing manifest file 'Adafruit_SSD1306.egg-info/SOURCES.txt'
reading manifest file 'Adafruit_SSD1306.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-aarch64/egg
running install_lib
running build_py
creating build
creating build/lib
creating build/lib/Adafruit_SSD1306
copying Adafruit_SSD1306/__init__.py -> build/lib/Adafruit_SSD1306
copying Adafruit_SSD1306/SSD1306.py -> build/lib/Adafruit_SSD1306
creating build/bdist.linux-aarch64
creating build/bdist.linux-aarch64/egg
creating build/bdist.linux-aarch64/egg/Adafruit_SSD1306
copying build/lib/Adafruit_SSD1306/__init__.py -> build/bdist.linux-aarch64/egg/Adafruit_SSD1306
copying build/lib/Adafruit_SSD1306/SSD1306.py -> build/bdist.linux-aarch64/egg/Adafruit_SSD1306
byte-compiling build/bdist.linux-aarch64/egg/Adafruit_SSD1306/__init__.py to __init__.cpython-37.pyc
byte-compiling build/bdist.linux-aarch64/egg/Adafruit_SSD1306/SSD1306.py to SSD1306.cpython-37.pyc
creating build/bdist.linux-aarch64/egg/EGG-INFO
copying Adafruit_SSD1306.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO
copying Adafruit_SSD1306.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying Adafruit_SSD1306.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying Adafruit_SSD1306.egg-info/requires.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying Adafruit_SSD1306.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents...
creating dist
creating 'dist/Adafruit_SSD1306-1.6.2-py3.7.egg' and adding 'build/bdist.linux-aarch64/egg' to it
removing 'build/bdist.linux-aarch64/egg' (and everything under it)
Processing Adafruit_SSD1306-1.6.2-py3.7.egg
Removing /usr/local/lib/python3.7/dist-packages/Adafruit_SSD1306-1.6.2-py3.7.egg
Copying Adafruit_SSD1306-1.6.2-py3.7.egg to /usr/local/lib/python3.7/dist-packages
Adafruit-SSD1306 1.6.2 is already the active version in easy-install.pth
Installed /usr/local/lib/python3.7/dist-packages/Adafruit_SSD1306-1.6.2-py3.7.egg
Processing dependencies for Adafruit-SSD1306==1.6.2
Searching for Adafruit-GPIO==1.0.5
Best match: Adafruit-GPIO 1.0.5
Processing Adafruit_GPIO-1.0.5-py3.7.egg
Adafruit-GPIO 1.0.5 is already the active version in easy-install.pth
Using /usr/local/lib/python3.7/dist-packages/Adafruit_GPIO-1.0.5-py3.7.egg
Searching for spidev==3.5
Best match: spidev 3.5
Processing spidev-3.5-py3.7-linux-aarch64.egg
spidev 3.5 is already the active version in easy-install.pth
Using /usr/local/lib/python3.7/dist-packages/spidev-3.5-py3.7-linux-aarch64.egg
Searching for Adafruit-PureIO==1.1.5
Best match: Adafruit-PureIO 1.1.5
Processing Adafruit_PureIO-1.1.5-py3.7.egg
Adafruit-PureIO 1.1.5 is already the active version in easy-install.pth
Using /usr/local/lib/python3.7/dist-packages/Adafruit_PureIO-1.1.5-py3.7.egg
Finished processing dependencies for Adafruit-SSD1306==1.6.2
I don’t know where the problem is after execution, I still can’t drive it....
It feels like a failure caused by the kernel, it seems that it only supports linux-image-4.4.154-110-rockchip-gcef30e88a9f5
I executed the command to install the kernel:
sudo apt-get install linux-4.4-latest
Something went wrong.
Quote
root@rockpi-4a:~# sudo apt-get install linux-4.4-latest
Reading package lists... Done
Building dependency tree
linux-4.4-latest is already the newest version (4.4.154-110-rockchip).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up rockchip-fstab (0.1) ...
sed: -e expression #1, char 0: no previous regular expression
mount all partitions
mount: vfat: mount point does not exist.
dpkg: error processing package rockchip-fstab (--configure):
 installed rockchip-fstab package post-installation script subprocess returned error exit status 32
Setting up linux-image-4.4.154-110-rockchip-gcef30e88a9f5 (4.4.154-110-rockchip) ...
update-initramfs: Generating /boot/initrd.img-4.4.154-110-rockchip-gcef30e88a9f5
update-initramfs: Converting to u-boot format
Kernel configuration : earlyprintk console=ttyFIQ0,1500000n8 rw init=/sbin/init rootfstype=ext4 rootwait root=PARTUUID=B921B045-1DF0-41C3-AF44-4C6F280D3FAE
Creating new extlinux.conf...
cp: cannot stat '/usr/lib/linux-image-4.4.213-rockchip64': No such file or directory
run-parts: /etc/kernel/postinst.d/zz-update-extlinux exited with return code 1
dpkg: error processing package linux-image-4.4.154-110-rockchip-gcef30e88a9f5 (--configure):
 installed linux-image-4.4.154-110-rockchip-gcef30e88a9f5 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-4.4-latest:
 linux-4.4-latest depends on linux-image-4.4.154-110-rockchip-gcef30e88a9f5; however:
  Package linux-image-4.4.154-110-rockchip-gcef30e88a9f5 is not configured yet.
dpkg: error processing package linux-4.4-latest (--configure):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
 rockchip-fstab
 linux-4.4-latest
E: Sub-process /usr/bin/dpkg returned an error code (1)
I just started contacting SBC System and hope I can get help here!!!!!!!!!!!!!!!!!
General support terms:
https://github.com/armbian/build#support
Start here: https://forum.armbian.com/subscriptions/ or fix problems, hire and expert (buy him tools and time) and provide solution https://docs.armbian.com/Process_Contribute/ You have this hardware and presumable more time than we have.
This hat should just work OOB but the display and fan. Radxa software support  is done in a quick and dirty way and installer will not just work on Armbian. Anyway - IHMO the only interesting (sane) way is to bring this up on a modern 5.4.y  / 5.7.y kernel. Investing (100% our) money to support this add-on on Legacy 4.4 kernel is pointless / throwing something we don't have through the window. And if we choose to do anything ... there is a big big pile of requests, people forget to support with any resource.
