justin256 Posted July 8, 2020 Share Posted July 8, 2020 Hi, I am new to all this and I have downloaded everything to my sd card. When I power on the board it gets stuck on "started update UTMP about system runlevel changes" and does nothing more. some images at https://imgur.com/92ZOiwD 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 8, 2020 Share Posted July 8, 2020 Everything is fine but your monitor which doesn't show the login prompt. What if you type ENTER few times - can you login ... how? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-login 0 Quote Link to comment Share on other sites More sharing options...
Technicavolous Posted July 9, 2020 Share Posted July 9, 2020 does your monitor have an 'auto adjust' ?I had a similar issue where the monitor was underscanning or overscanning or something and 'auto adjust' (from the monitors menu) brought the whole screen into the viewport of the monitor. 1 Quote Link to comment Share on other sites More sharing options...
Werner Posted July 9, 2020 Share Posted July 9, 2020 15 hours ago, Technicavolous said: does your monitor have an 'auto adjust' ?I had a similar issue where the monitor was underscanning or overscanning or something and 'auto adjust' (from the monitors menu) brought the whole screen into the viewport of the monitor. Also my guess since [ OK is missing before the ] ... 0 Quote Link to comment Share on other sites More sharing options...
João Henrique Da Silva Nunes Jales Ribeiro Posted December 1, 2023 Share Posted December 1, 2023 Hi there, I'm really pissed off, my orange pi one will only boot the original images with kernel 3.14 or similar, anything higher will NOT boot even when the boot partition is fat32. I have noticed that NONE of the current images for this board has the boot partition in fat32 and I believe this is definitely related to the god damned issue. Can anyone help in getting this to boot newer images? The repositories on the original ones do not work and I am unable to do anything I need without these. Also, anyone has any instructions on how to upgrade the onboard FEL firmware? I have reason to believe this is the real culprit of all the issues as my board is quite old. When I bought it they still costed 12.5€ (less than half of todays price) so this is a first gen board. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted December 1, 2023 Share Posted December 1, 2023 Cannot reproduce. https://paste.armbian.com/yabotibeno 0 Quote Link to comment Share on other sites More sharing options...
Stephen Graf Posted February 5 Share Posted February 5 What are you booting from? I use an SD card with the up to date image which works just fine. There is no boot partition in the image, just a boot directory. Can you try an up to date image with and SD card? The fel firmware would be part of u-boot that is on the Armbian image. 0 Quote Link to comment Share on other sites More sharing options...
