Alex_ro Posted July 18, 2020 Share Posted July 18, 2020 No boot from sd card Armbian_20.05.7_Orangepi4_focal_current_5.4.49.img.xz The Image OrangePi_4_ubuntu_bionic_desktop_linux4.4.179_v1.3.tar.gz is boot normaly. SD card SanDisk Ultra 64G 10class. gdisk p table Number Start (sector) End (sector) Size Code Name 1 24576 32767 4.0 MiB 8300 uboot 2 32768 40959 4.0 MiB 8300 trust 3 49152 114687 32.0 MiB 8300 boot 4 376832 124735454 59.3 GiB 8300 rootfs console debug no viewer, but my usb-ttl not support 1500000! Where SD card is new, armbian boot normaly!!!! After OrangePi image no... Board: Not on the list 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted July 18, 2020 Share Posted July 18, 2020 Quote console debug no viewer, but my usb-ttl not support 1500000! You should get a proper one. Best debug tool for SBCs. Quote Board: Not on the list OPI4 is built around the RK3399 SoC but since youo state it does not boot at all it kind a finds here too. 0 Quote Link to comment Share on other sites More sharing options...
piter75 Posted July 18, 2020 Share Posted July 18, 2020 1 hour ago, Alex_ro said: Where SD card is new, armbian boot normaly!!!! After OrangePi image no... This a known issue. If Rockchip's loader finds GPT partition table (in this case the recovery one) it tries to boot using the GPT partition layout which Armbian does not use. At this point to quickly recover the SD card after Xunlong's image you need to erase last 33 sectors holding a GPT recovery partition table and before writing Armbian image. 0 Quote Link to comment Share on other sites More sharing options...
