PiHole and Unbound isssue on Odroid HC1
aian
Hi all,
I have a Rpi 3B+ where I am running Pihole with Unbound. As a secondary DNS, I am planning to use an Odroid HC1 which will also be running other stuff.
Today I installed Armbian_20.05.7_Odroidxu4_buster_current_5.4.50_minimal.img and started the installation of Pihole, which went through just fine.
Then I attempted to install Unbound, but got an error message. The command I run was:
sudo apt install unbound -y
And this is what was returned:
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  libevent-2.1-6 libpython3.7 libunbound8 unbound-anchor
Suggested packages:
  apparmor
The following NEW packages will be installed:
  libevent-2.1-6 libpython3.7 libunbound8 unbound unbound-anchor
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,682 kB of archives.
After this operation, 7,786 kB of additional disk space will be used.
Get:1 http://security.debian.org buster/updates/main armhf libunbound8 armhf 1.9.0-2+deb10u2 [411 kB]
Get:2 http://deb.debian.org/debian buster/main armhf libevent-2.1-6 armhf 2.1.8-stable-4 [159 kB]
Get:3 http://deb.debian.org/debian buster/main armhf libpython3.7 armhf 3.7.3-2+deb10u1 [1,282 kB]
Get:4 http://security.debian.org buster/updates/main armhf unbound-anchor armhf 1.9.0-2+deb10u2 [145 kB]
Get:5 http://security.debian.org buster/updates/main armhf unbound armhf 1.9.0-2+deb10u2 [686 kB]
Fetched 2,682 kB in 1s (4,479 kB/s)
Selecting previously unselected package libevent-2.1-6:armhf.
(Reading database ... 27770 files and directories currently installed.)
Preparing to unpack .../libevent-2.1-6_2.1.8-stable-4_armhf.deb ...
Unpacking libevent-2.1-6:armhf (2.1.8-stable-4) ...
Selecting previously unselected package libpython3.7:armhf.
Preparing to unpack .../libpython3.7_3.7.3-2+deb10u1_armhf.deb ...
Unpacking libpython3.7:armhf (3.7.3-2+deb10u1) ...
Selecting previously unselected package libunbound8:armhf.
Preparing to unpack .../libunbound8_1.9.0-2+deb10u2_armhf.deb ...
Unpacking libunbound8:armhf (1.9.0-2+deb10u2) ...
Selecting previously unselected package unbound-anchor.
Preparing to unpack .../unbound-anchor_1.9.0-2+deb10u2_armhf.deb ...
Unpacking unbound-anchor (1.9.0-2+deb10u2) ...
Selecting previously unselected package unbound.
Preparing to unpack .../unbound_1.9.0-2+deb10u2_armhf.deb ...
Unpacking unbound (1.9.0-2+deb10u2) ...
Setting up libpython3.7:armhf (3.7.3-2+deb10u1) ...
Setting up libevent-2.1-6:armhf (2.1.8-stable-4) ...
Setting up libunbound8:armhf (1.9.0-2+deb10u2) ...
Setting up unbound-anchor (1.9.0-2+deb10u2) ...
Setting up unbound (1.9.0-2+deb10u2) ...
Created symlink /etc/systemd/system/multi-user.target.wants/unbound.service → /lib/systemd/system/unbound.service.
Created symlink /etc/systemd/system/unbound.service.wants/unbound-resolvconf.service → /lib/systemd/system/unbound-resolvconf.service.
Job for unbound.service failed because the control process exited with error code.
See "systemctl status unbound.service" and "journalctl -xe" for details.
invoke-rc.d: initscript unbound, action "start" failed.
● unbound.service - Unbound DNS server
   Loaded: loaded (/lib/systemd/system/unbound.service; enabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Sat 2020-07-18 17:29:48 BST; 24ms ago
     Docs: man:unbound(8)
  Process: 2692 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
  Process: 2697 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
  Process: 2701 ExecStart=/usr/sbin/unbound -d $DAEMON_OPTS (code=exited, status=1/FAILURE)
 Main PID: 2701 (code=exited, status=1/FAILURE)
Processing triggers for systemd (241-7~deb10u4) ...
Processing triggers for libc-bin (2.28-10) ...
4th line from the bottom, the error (code=exited, status=1/FAILURE) appeared.
Any idea what I did wrong and how to solve this?
Thanks in advance.
