Guest Posted July 26, 2020 Share Posted July 26, 2020 Hi everybody, I have a problem with this version: Armbian_20.05.2_Rockpro64_buster_legacy_4.4.213.img I don't see my disk that is plugged on the PCIe To SATA Marvell 88SE9230 in the system. I've create the file /etc/udev/rules.d/99-marvell.rules with the following line on it: ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x1b4b", ATTR{device}=="0x9230", RUN+="/bin/bash -c 'echo %k > /sys/bus/pci/drivers/ahci/bind'" If I do the same thing with this version: Armbian_20.05.4_Rockpro64_focal_current_5.4.46.img, I see my disk after creating the file. But, there's two problem with this version: first the fan always running and, more important, second I can't install OpenMediaVault on it. My question is, do I have to do something on the kernel? If so, could someone tell me what I have to activate to see my disk ? I don't have a lot of knowledge about kernels but I'm ready to jump it if someone could tell me where to check. Thank you all in advance. 0 Quote Link to comment Share on other sites More sharing options...
soerenderfor Posted August 2, 2020 Share Posted August 2, 2020 Hi, Myself has a bunch of Marvell chipset sata cards. And almost sure all of them work on kernel 5.7.12 - Try it out and let me know. I did notice months back probs in OMV with that type of cards. I run kernel 5.7.12 with simpnas and works like charm. 0 Quote Link to comment Share on other sites More sharing options...
