fayehoo Posted August 2, 2020 Share Posted August 2, 2020 There are two install emmc files in armbian amlogic verison by balbes150. install-aml.sh and install-aml-s905-emmc.sh. What's the difference between these? If install armbian to a S912 TVbox emmc, which one should be choosed? Link to comment Share on other sites More sharing options...
spikerguy Posted August 2, 2020 Share Posted August 2, 2020 Can you please post the content of both the files? I am not sure so it will be better to read the content and understand what it is trying to do, AFAIK I have been using the latest iteration of the install script which includes support for RGB YUV for aml devices which have green screen issue. Link to comment Share on other sites More sharing options...
fayehoo Posted August 2, 2020 Author Share Posted August 2, 2020 diff -u install-aml.sh install-aml-s905-emmc.sh | colordiff --- install-aml.sh 2020-07-23 10:47:15.088753970 +0000 +++ install-aml-s905-emmc.sh 2020-07-23 10:47:15.096757969 +0000 @@ -47,19 +47,12 @@ echo $DEV_EMMC echo "Start backup u-boot default" +dd if="${DEV_EMMC}" of=/root/u-boot-default-aml-s905.img bs=1M count=4 -dd if="${DEV_EMMC}" of=/root/u-boot-default-aml.img bs=1M count=4 - -echo "Start create MBR and partittion" - -parted -s "${DEV_EMMC}" mklabel msdos -parted -s "${DEV_EMMC}" mkpart primary fat32 700M 1212M -parted -s "${DEV_EMMC}" mkpart primary ext4 1213M 100% - -echo "Start restore u-boot" - -dd if=/root/u-boot-default-aml.img of="${DEV_EMMC}" conv=fsync bs=1 count=442 -dd if=/root/u-boot-default-aml.img of="${DEV_EMMC}" conv=fsync bs=512 skip=1 seek=1 +if [ -f /root/u-boot/u-boot-s905/u-boot.img ] ; then + echo "Start install u-boot to eMMC" + dd if=/root/u-boot/u-boot-s905/u-boot.img of="${DEV_EMMC}" +fi sync @@ -98,16 +91,10 @@ -i "$DIR_INSTALL/uEnv.txt" echo "done." -rm $DIR_INSTALL/s9* +#rm $DIR_INSTALL/s9* rm $DIR_INSTALL/aml* rm $DIR_INSTALL/boot.ini -mv -f $DIR_INSTALL/boot-emmc.scr $DIR_INSTALL/boot.scr - -if [ -f /boot/u-boot.ext ] ; then - mv -f $DIR_INSTALL/u-boot.sd $DIR_INSTALL/u-boot.emmc - mv -f $DIR_INSTALL/boot-emmc.ini $DIR_INSTALL/boot.ini - sync -fi +#mv -f $DIR_INSTALL/s905_emmc_autoscript $DIR_INSTALL/s905_autoscript umount $DIR_INSTALL Link to comment Share on other sites More sharing options...
