[Banana]" Error ramlog" armbian 3.2 Kernel 3.4.108
sgei
Hi Igor,
I've installed a clean version of your image for BananaPi:
Hardware: BananaPi
Image-Version: 3.2 Kernel 3.4.108 Debian Wheezy
Installed Packages:
zip, unzip
ftp
dialog
xorg
lxde
slim
tightvncserver
I get the following ErrorMessage:
Boot
Jul 12 06:03:11 Enabling ramlog...                                       [ OK ]
Jul 12 06:03:14 Disabling ramlog...                                      [ OK ]
Jan 01 01:00:44 Enabling ramlog...                                       [ OK ]
Jul 24 08:01:08 Stopping ramlog: Error: ramlog is not running            [fail]
Jul 24 08:02:04 Starting ramlog-tmpfs 2.0.0:                             [ OK ]
Jul 24 08:23:29 Saving logs to hdd:                                      [ OK ]
Jul 24 08:23:30 Stopping ramlog:                                         [ OK ]
Jul 24 08:24:12 Starting ramlog-tmpfs 2.0.0:                             [ OK ]
Jul 24 08:29:22 Saving logs to hdd:                                      [ OK ]
Jul 24 08:29:22 Stopping ramlog:                                         [ OK ]
Jul 24 08:30:04 Starting ramlog-tmpfs 2.0.0:                             [ OK ]
Jul 24 11:07:43 Saving logs to hdd:                                      [ OK ]
Jul 24 11:07:45 Stopping ramlog:                                         [ OK ]
Jul 24 11:08:31 Starting ramlog-tmpfs 2.0.0:                             [ OK ]
Jul 24 11:39:22 Saving logs to hdd:                                      [ OK ]
Jul 24 11:39:22 Stopping ramlog:                                         [ OK ]
Jul 24 11:40:02 Starting ramlog-tmpfs 2.0.0:                             [ OK ]
Jul 24 11:46:09 Saving logs to hdd:                                      [ OK ]
Jul 24 11:46:10 Stopping ramlog:                                         [ OK ]
Jul 24 11:47:05 Starting ramlog-tmpfs 2.0.0:                             [ OK ]
Jul 24 11:54:24 Saving logs to hdd:                                      [ OK ]
Jul 24 11:54:24 Stopping ramlog:                                         [ OK ]
Jan 01 01:00:17 Starting ramlog-tmpfs 2.0.0:                             [ OK ]
Jul 24 13:23:54 Saving logs to hdd:                                      [ OK ]
Jul 24 13:23:59 Stopping ramlog:                                         [ OK ]
Jul 24 13:24:45 Starting ramlog-tmpfs 2.0.0:                             [ OK ]
Jul 24 13:40:13 Saving logs to hdd:                                      [ OK ]
Jul 24 13:40:19 Stopping ramlog:                                         [ OK ]
Jul 24 13:41:09 Starting ramlog-tmpfs 2.0.0: Error: /var/log is in use... [fail]
Jul 24 13:41:09 The list of open files: (You need to close below daemons if you want to start/stop ramlog manually)
COMMAND  PID USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
slim    1999 root    3w   REG  179,1      334 1598 /var/log/slim.log
sh      2002 root    3w   REG  179,1      334 1598 /var/log/slim.log
Jul 24 13:41:09 Test result: ramlog cannot be started or stopped at the moment.
Jul 24 13:46:19 ramlog: Cannot find shutdown flag file.                  [warning]
Jul 24 13:46:19 Stopping ramlog: Error: ramlog is not running            [fail]
Jul 24 13:47:00 Starting ramlog-tmpfs 2.0.0: Error: /var/log is in use... [fail]
Jul 24 13:47:01 The list of open files: (You need to close below daemons if you want to start/stop ramlog manually)
slim    1980 root    3w   REG  179,1      677 1598 /var/log/slim.log
Xorg    1992 root    0w   REG  179,1        0  745 /var/log/Xorg.0.log.old
Xorg    1992 root    3w   REG  179,1      677 1598 /var/log/slim.log
Jul 24 13:47:01 Test result: ramlog cannot be started or stopped at the moment.
Jul 24 14:04:32 ramlog: Cannot find shutdown flag file.                  [warning]
Jul 24 14:04:33 Stopping ramlog: Error: ramlog is not running            [fail]
Jul 24 14:05:14 Starting ramlog-tmpfs 2.0.0: Error: /var/log is in use... [fail]
Jul 24 14:05:15 The list of open files: (You need to close below daemons if you want to start/stop ramlog manually)
slim    1981 root    3w   REG  179,1      910 1598 /var/log/slim.log
Jul 24 14:05:15 Test result: ramlog cannot be started or stopped at the moment.
Shutdown/Reboot:
[warn] ramlog: Cannot find shutdown flag file. ... (warning)
[FAIL] Cannot find shutdown flag file. [.......] Stopping ramlog: Error: ramlog is not running Failed!
Can you help me?
Steffen
I would suggest to disable ramlog service with:
service ramlog disable
it's disabled after reboot. If you upgraded to Jessie, Ramlog can't work - not compatible with systemd.
If you are still on Wheezy than try to tweak the boot sequence. Ramlog should be started as early as possible.
Uh :unsure:  No ideas for a simple strait answer. It's not simple but also not so complex.
http://askubuntu.com/questions/18802/how-to-correctly-add-a-custom-daemon-to-init-d
http://minecraft.gamepedia.com/Tutorials/Server_startup_script
Try google for more info if this is not enough.
It's strange because I use similar desktop configuration and it's working without a problem. Also it's pity that Ramlog is not supported anymore: http://www.tremende.com/ramlog/ Try to ping author  ;)
Hi Igor,
With these two lines in LSB-Tags of ramlog I don't get any Errors:
# X-Stop-After: $syslog
# X-Interactive: true
Source: https://debianforum.de/forum/viewtopic.php?f=27&t=131540
### BEGIN INIT INFO
# Provides: ramlog
# Required-Start:
# Should-Start: $local_fs
# Required-Stop:
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: moves /var/log into ramdisk
# Description: ramlog daemon moves /var/log to ramdisk on startup and copies it back to harddrive on shutdown or restart
### END INIT INFO
Steffen
