laurentppol Posted August 4, 2020 Share Posted August 4, 2020 Hi there, how do I configure / start an WiFi AP on OPi3? In armbian-config (found using google, and found on OPiPC+) from my current Buster (OOB + update / upgrade) there is NO option to set up an AP. I may configure it "manually" (edit config files) but I need some tutorial if there is no "menu style" config. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 5, 2020 Share Posted August 5, 2020 So hostapd does not work on OPi3? 0 Quote Link to comment Share on other sites More sharing options...
laurentppol Posted August 6, 2020 Author Share Posted August 6, 2020 Guess it works, but don't know how to configure it. There is NO "hotspot" submenu in armbian-config/network... 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 6, 2020 Share Posted August 6, 2020 Hm odd. Maybe someone else has an OPi3 laying around and test if hostapd is broken for some reason. I don't have an H6 board with WiFi to test... A few month ago I tested this with my OPi0 which worked flawless. 0 Quote Link to comment Share on other sites More sharing options...
laurentppol Posted August 6, 2020 Author Share Posted August 6, 2020 Are there somewhere "howto's" on setting hostapd config "manually"? Directly editing needed config files? I didn't say "hostapd does not work", I just said "there is NO 'menu entry' for this on OPi3 armbian-config". 0 Quote Link to comment Share on other sites More sharing options...
laurentppol Posted August 8, 2020 Author Share Posted August 8, 2020 Just checked: Quote root@orangepi3:/var/motion# apt list hostapd Listing... Gotowe hostapd/buster,now 3:2.9-102~armbian20.05.2+1 arm64 [installed] hostapd/buster 3:2.9-102~armbian20.05.2+1 armhf root@orangepi3:/var/motion# host host hostapd hostapd_cli hostid hostname hostnamectl So hostapd IS there, "only" need to know how ("manually") configure it, OR enable it in menu-driven armbian-config. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 8, 2020 Share Posted August 8, 2020 If the wifi interfaces is there (iwconfig) then I don't know. In the meantime you surely will find some tutorials in the web how to setup a hotspot on buster with hostapd. 0 Quote Link to comment Share on other sites More sharing options...
laurentppol Posted August 8, 2020 Author Share Posted August 8, 2020 This one: https://raspberrypi.stackexchange.com/questions/89803/access-point-as-wifi-router-repeater-optional-with-bridge/89804?newreg=e46b9f0f237d4913b4b807b2369df10c looks promising as it covers AP AND STA setup, don't know about WDS. 0 Quote Link to comment Share on other sites More sharing options...
laurentppol Posted August 12, 2020 Author Share Posted August 12, 2020 Only looks This is based on WiFi management by systemd, and in Buster this is done by NetworkManager. How to setup / use AP in this case? (I want to setup AP on different channel from "main AP" for webcams, for troughtput reasons). 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted August 12, 2020 Share Posted August 12, 2020 5 hours ago, laurentppol said: This is based on WiFi management by systemd, and in Buster this is done by NetworkManager. Is wifi otherwise working properly? If you would provide logs, solution might be visible from there. 0 Quote Link to comment Share on other sites More sharing options...
laurentppol Posted August 12, 2020 Author Share Posted August 12, 2020 YES, WiFi (client) works OK with NM. If I start hostapd manually from command line (default config) then AP appears but cant connect using def pass "12345678" :( When stopped it does NOT reastore original WiFi client. (wlan0 is not configured / attached to AP). Shoudl I provide (compressed) /var/log/messages from boot moment to "statble"? Or some outpout of journalctl (please advize on command syntax)? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 12, 2020 Share Posted August 12, 2020 34 minutes ago, laurentppol said: Shoudl I provide (compressed) /var/log/messages from boot moment to "statble"? Or some outpout of journalctl (please advize on command syntax)? None of that. Read the topic @Igor linked above. 0 Quote Link to comment Share on other sites More sharing options...
laurentppol Posted August 12, 2020 Author Share Posted August 12, 2020 Ok, didn't remarked that it is a link, not a simple underline. 0 Quote Link to comment Share on other sites More sharing options...
laurentppol Posted August 14, 2020 Author Share Posted August 14, 2020 OK, here it is: root@orangepi3:/var/motion# armbianmonitor -u System diagnosis information will now be uploaded to gzip: /var/log/armbian-hardware-monitor.log.1.gz: No such file or directory http://ix.io/2u7Y Please post the URL in the forum where you've been asked for. 0 Quote Link to comment Share on other sites More sharing options...
laurentppol Posted August 15, 2020 Author Share Posted August 15, 2020 Ok, have to respond to myself :-( - I CAN create an AP using nm-connection-editor, - CAN see it in systray after installing "nm-tray", - CAN connect to new network (after restarting NetworkManager), - can't get DHCP address from this (on laptop), - IP is in 10.42.x.x range, - manually config laptop WiFi IP gives at least PING response. What I want: - make dhcp availavble on new AP, - change IP to 192.168.15.x - if channels on WiFi (AP / STA) are NOT linked together, set up an WiFi client too, but priority is AP on channel OTHER that I use for "normal" network (I suppose congestion with WiFi webcam). What should I do? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted August 16, 2020 Share Posted August 16, 2020 On 8/15/2020 at 2:54 AM, laurentppol said: What should I do? Study https://wiki.gnome.org/Projects/NetworkManager 0 Quote Link to comment Share on other sites More sharing options...
laurentppol Posted August 20, 2020 Author Share Posted August 20, 2020 Somehow I managed to make WORKING connection, using NetworkManager "connection editor" or nmtui (don't remember). Will see it this survives reboot. But there is NO routing! I can connect to webcam (what is purpose of this WiFi setup, on channel 1, as my "normal" network is on channel 11), but ONLY from OPi3. I CAN ping OPi WiFi from laptop, but can't connect webcam on this wifi. (webcam does not respond to ping but this is Android "feature"). I CAN however connect this webcam from OPi! With "motion" and Firefox (on remote X on laptop). In next post I'll attach my config files, maybe someone could explain, WHY my previous setup does NOT work... 0 Quote Link to comment Share on other sites More sharing options...
