manpreet Posted August 24, 2020 Share Posted August 24, 2020 Has anyone tried using PXE boot and install on ODroid-N2 I have 12 Odroid-N2s, I want to install them automatically over network using FAI, I can seem to find a way to do that, actually I am currently unable to even boot the armbian kernel using netboot # generated by fai-chboot for host default with IP no IP default Debian Testing Netboot Installer(Armbian) LABEL Debian Testing Netboot Installer(Odroid) KERNEL /boot/vmlinuz INITRD /boot/initrd.gz DTB /boot/meson64_odroidn2.dtb APPEND ip=dhcp root=/srv/fai/nfsroot:vers=3 rootovl FAI_FLAGS=verbose,sshd,createvt FAI_CONFIG_SRC=nfs://pxe/srv/fai/config FAI_ACTION=install console=tty0 no_console_suspend earlyprintk=aml-uart,0xff803000 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 logo=osd0,loaded,0x3d800000 voutmode=hdmi hdmimode=1080p60hz osd_reverse=0 video_reverse=0 anna/no_kernel_modules=false LABEL Debian Testing Netboot Installer(Armbian) KERNEL /boot1/vmlinuz INITRD /boot1/initrd.img DTB /boot1/meson-odroid-n2.dtb APPEND ip=dhcp root=/srv/fai/nfsroot:vers=3 rootovl rootfstype=nfs FAI_FLAGS=verbose,sshd,createvt FAI_CONFIG_SRC=nfs://pxe/srv/fai/config FAI_ACTION=install console=tty0 no_console_suspend fsck.repair=yes net.ifname=0 elevator=noop cvbsmode=576cvbs hdmimode=1080p60hz consoleblank=0 log_level=1 display_autodetect="true" voutmode=hdmi max_freq_a73=1800 max_freq_a53=1896 maxcpus=6 First one using ODroid n2 kernel from forums boots Second one using ODroid n2 kernel from armbian doesnt boot. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted August 24, 2020 Share Posted August 24, 2020 Providing logs with armbianmonitor -u significantly raises chances that issue is getting addressed. Are you using the same kernel? If you want the same feature on a modern kernel its usually related to costs. 0 Quote Link to comment Share on other sites More sharing options...
manpreet Posted August 25, 2020 Author Share Posted August 25, 2020 Not starting yet this is to install armbian over network without using the image file. 0 Quote Link to comment Share on other sites More sharing options...
