Kernel 5.4-rc4 works...do I need U-Boot v2019.04-rc4?
gtg498u
Long story short:
Espressobin v7 1GB
Armbian (Ubuntu Bionic 18.04)
Kernel Mainline 5.4-rc4 (with custom userpatch (compiles fine))
U-Boot 2018.03-devel-18.12.3-gc9aa92c-armbian (Feb 20 2019 - 09:45:04 +0100)
Without my Atheros AR9380 chipset (ath9k) wifi card inserted into the mPCIe, boots fine into Ubuntu from SD.
With Atheros AR9380 chipset (ath9k) wifi card inserted into mPCIe I get a kernel hang (see below), I'm assuming it's because I'm using:
But according to this: https://docs.armbian.com/Hardware_Marvell/, I should be using U-Boot v2019.04-rc4
However, Marvell U-Boot only goes to 2018.03-armada 18.12: https://github.com/MarvellEmbeddedProcessors/u-boot-marvell
I read on other forums with similar ath9k kernel hangs, that the kernel should be matched with the u-boot...so, how do I get u-boot v2019.04-rc4 on my espressobin, if Marvell U-Boot github doesn't host it?
Here is the kernel hang:
Spoiler
TIM-1.0
WTMI-devel-18.12.1-e6bb176
WTMI: system early-init
SVC REV: 5, CPU VDD voltage: 1.050V
NOTICE:  Booting Trusted Firmware
NOTICE:  BL1: v1.5(release):1f8ca7e (Marvell-devel-18.12.2)
NOTICE:  BL1: Built : 16:25:52, May 21 2019
NOTICE:  BL1: Booting BL2
NOTICE:  BL2: v1.5(release):1f8ca7e (Marvell-devel-18.12.2)
NOTICE:  BL2: Built : 16:25:53, May 21 2019
NOTICE:  BL1: Booting BL31
NOTICE:  BL31: v1.5(release):1f8ca7e (Marvell-devel-18.12.2)
NOTICE:  BL31: Built : 16:25:56, May
Model: Marvell Armada 3720 Community Board ESPRESSOBin
       CPU     600 [MHz]
       L2      800 [MHz]
       TClock  200 [MHz]
       DDR     600 [MHz]
DRAM:  1 GiB
Comphy chip #0:
Comphy-0: USB3          5 Gbps
Comphy-1: PEX0          2.5 Gbps
Comphy-2: SATA0         6 Gbps
SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: ncq led only pmp fbss pio slum part sxs
PCIE-0: Link up
MMC:   sdhci@d0000: 0, sdhci@d8000: 1
Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 64 KiB, total 4 MiB
OK
Net:   eth0: neta@30000 [PRIME]
starting USB...
USB0:   Register 2000104 NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1:   USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
** Bad device usb 0 **
## Executing script at 06d00000
Wrong image format for "source" command
/boot/
scanning bus for devices...
Device 0: unknown device
** Bad device scsi 0 **
/boot/
Card did not respond to voltage select!
** Bad device mmc 1 **
/boot/
** File not found /boot.scr **
/boot/
1119 bytes read in 15 ms (72.3 KiB/s)
240 bytes read in 5 ms (46.9 KiB/s)
17447424 bytes read in 769 ms (21.6 MiB/s)
9195816 bytes read in 410 ms (21.4 MiB/s)
** File not found /boot/dtb/marvell/armada-3720-community.dtb **
10860 bytes read in 8 ms (1.3 MiB/s)
## Loading init Ramdisk from Legacy Image at 01100000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    9195752 Bytes = 8.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 06000000
   Booting using the fdt blob at 0x6000000
   Loading Ramdisk to 3ed65000, end 3f62a0e8 ... OK
   Using Device Tree in place at 0000000006000000, end 0000000006005a6b
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.4.0-rc4-mvebu64 (root@ubuntu) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #trunk SMP PREEMPT Sat Aug 29 17:12:45 EDT 2020
[    0.000000] Machine model: Globalscale Marvell ESPRESSOBin Board
[    0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '')
[    0.000000] printk: bootconsole [ar3700_uart0] enabled
[  121.824019] SError Interrupt on CPU1, code 0xbf000002 -- SError
[  121.824025] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.0-rc4-mvebu64 #trunk
[  121.824029] Hardware name: Globalscale Marvell ESPRESSOBin Board (DT)
[  121.824032] pstate: 80000085 (Nzcv daIf -PAN -UAO)
[  121.824035] pc : advk_pcie_rd_conf+0x64/0x208
[  121.824038] lr : pci_bus_read_config_word+0x78/0xd0
[  121.824040] sp : ffffffc01002b790
[  121.824043] x29: ffffffc01002b790 x28: ffffff803f05a000
[  121.824050] x27: ffffff803f05a000 x26: ffffff803f05a828
[  121.824057] x25: ffffffc01118a268 x24: 0000000000000000
[  121.824063] x23: ffffffc01002b872 x22: ffffffc01002b814
[  121.824069] x21: 0000000000000002 x20: 0000000000000080
[  121.824075] x19: ffffff803f992400 x18: 0000000000000000
[  121.824081] x17: 0000000000000001 x16: 0000000000000019
[  121.824087] x15: ffffffc011093000 x14: ffffffc01112e3c0
[  121.824094] x13: 0000b66685e7f402 x12: 0000000000000001
[  121.824100] x11: 0000000000000000 x10: 0000000000000930
[  121.824106] x9 : ffffffc01002b6f0 x8 : ffffff803f880990
[  121.824112] x7 : ffffff803f880180 x6 : 000000000000401c
[  121.824118] x5 : 0000000001040008 x4 : 0000000000000001
[  121.824125] x3 : 0000000000000000 x2 : ffffffc011564020
[  121.824131] x1 : 0000000000000000 x0 : ffffff803f05a800
[  121.824139] Kernel panic - not syncing: Asynchronous SError Interrupt
[  121.824142] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.0-rc4-mvebu64 #trunk
[  121.824146] Hardware name: Globalscale Marvell ESPRESSOBin Board (DT)
[  121.824148] Call trace:
[  121.824151]  dump_backtrace+0x0/0x140
[  121.824153]  show_stack+0x14/0x20
[  121.824156]  dump_stack+0xa8/0xf0
[  121.824158]  panic+0x158/0x324
[  121.824160]  nmi_panic+0x84/0x88
[  121.824163]  arm64_serror_panic+0x74/0x80
[  121.824165]  do_serror+0x80/0x138
[  121.824168]  el1_error+0x84/0xf8
[  121.824171]  advk_pcie_rd_conf+0x64/0x208
[  121.824174]  pci_bus_read_config_word+0x78/0xd0
[  121.824177]  pcie_capability_read_word+0x8c/0xc8
[  121.824179]  pcie_get_aspm_reg+0x64/0x118
[  121.824182]  pcie_aspm_init_link_state+0x480/0xad8
[  121.824185]  pci_scan_slot+0x110/0x118
[  121.824188]  pci_scan_child_bus_extend+0x50/0x2a8
[  121.824191]  pci_scan_bridge_extend+0x294/0x570
[  121.824194]  pci_scan_child_bus_extend+0x1e4/0x2a8
[  121.824196]  pci_scan_root_bus_bridge+0x58/0xd8
[  121.824199]  pci_host_probe+0x14/0xc0
[  121.824202]  advk_pcie_probe+0x8a8/0x948
[  121.824204]  platform_drv_probe+0x50/0xa0
[  121.824207]  really_probe+0xd4/0x308
[  121.824209]  driver_probe_device+0x54/0xe8
[  121.824212]  device_driver_attach+0x6c/0x78
[  121.824215]  __driver_attach+0x54/0xd0
[  121.824217]  bus_for_each_dev+0x6c/0xc0
[  121.824220]  driver_attach+0x20/0x28
[  121.824222]  bus_add_driver+0x140/0x1e8
[  121.824225]  driver_register+0x60/0x110
[  121.824228]  __platform_driver_register+0x44/0x50
[  121.824231]  advk_pcie_driver_init+0x18/0x20
[  121.824234]  do_one_initcall+0x50/0x190
[  121.824236]  kernel_init_freeable+0x194/0x22c
[  121.824239]  kernel_init+0x10/0x100
[  121.824241]  ret_from_fork+0x10/0x18
[  121.824269] SMP: stopping secondary CPUs
[  121.824272] Kernel Offset: disabled
[  121.824274] CPU features: 0x0002,2000200c
[  121.824277] Memory Limit: none
For start update to latest u-boot and  kernel. You are using some very old build, nobody will even try to reason why it doesn't work as expected.
Thanks for the reply Igor, I tried the latest already. Still doesn't work with ath9k wifi card.
Is there an issues with the build script using:
https://github.com/MarvellEmbeddedProcessors/u-boot-marvell.git, branch u-boot-2018.03-armada-18.12
This is the latest, that the u-boot build scripts pulls from. Is there a config file I can use to tell the u-boot build script to pull from the u-boot mainline (similar to how I can tell the kernel build script which kernel I want to build)?
Perhaps I don't understand fully. TBH I'm just a practitioner. I specifically need 5.4-rc4 because I have an entire software stack that is married to that kernel (and for good reason). I have my set-up working (not armbian) on a different hardware SBC. So I'm trying to support this other board. It is crucial that I use 5.4-rc4 and Atheros AR9380 chipset (ath9k) wifi card.
There is no such things yet. Perhaps in a few months since there is some activity in that direction. And solo that usually brings nothing - it contains the same low level bugs and limitations. You just get new generic part.
Then this forum can't help you.
not armbian
And especially not in this case.
  • Igor locked and unlocked this topic
Hello @gtg498u! You should ignore @Igor's comments as it looks like that it is some local forum troll and joking that defend his decision that armbian erases ethernet MAC address is the correct. Also in this thread he said that U-Boot v2019.04-rc4 is very old version and you should use last version, but his armbian provides only U-Boot version U-Boot 2018.03, which is even older. So do not take his comments seriously.
And based on these fatal decisions I would not be surprised that other things start to be broken with new u-boot or kernel versions, if there are other similar custom armbian patches like that which erase MAC address.
@gtg498u: Could you look at thread https://forum.armbian.com/topic/15059-espressobin-mainline-u-bootatf/ and try to use @dhewg's builds of ATF+u-boot? We have sent more patches to upstream U-Boot to fix Armada 3720 HW, so it should work better than armbian builds.
Also from that kernel log I see that crash is in aardvark PCIe bus driver. I sent more fixes for aardvark driver into 5.8 kernel which should make support for ath10k cards more stable. Could try to use 5.8 kernel?
If problems are still there, please send me whole dmesg log and I will try to look at aardvark/A3720 issues.
Of it is correct., but not anymore. Which I told you but you are seeing only yourself. Without setting it (at that time), MAC would have been randomly generated. Which is even worse.
He is not using Armbian, but yes we plan to bump version to 5.8.y. It just happen that we are overloaded with other work. Which you and your friend are totally unable to understand.
Thank you so much @Pali and also thank you @Igor I thought your comments were amusing. :)
so I’ve tried many different options so far (and by the way I am trying to get this to work on the espressobin, please ignore any comments about the other SBC that I am using I’m not running Armbian on that one). I’m having issues with the latest Armbian (5.6.y) and u-boot (2018) for marvel on the espressobin. Armbian loads up great. the issue is the Atheros Wi-Fi card with the AR 9380 chipset. With that in the mPCIe slot of the espressobin v7, I get the kernel hang I posted earlier.
 I saw on some forms that there was a patch for the kernel on marvel targets in which the millisecond delay for one of the routines for the aardvark PCI driver needed to be increased to 50ms as opposed to 1ms.
  I have successfully been able to get the espressobin v7 to boot Armbian  and it works just fine with the Wi-Fi card using kernel 4.19 however when I use kernel 5.4 and up I get the kernel hang I posted earlier.
the issue is always with the aardvark PCI driver. I suspect that the latest u-boot from Marvell doesn’t support kernel 5.4 and up.
i was hoping it was just a slight modification of the kernel in aardvark PCI driver in the function: advk_pcie_rd_conf
any other ideas?
Thank you @Pali I did as you said, no dice. I could get latest 5.8 with 2018 uboot to recognize the wifi card, I could not get 5.6 with your 2020.10-rc4 to recognize the card, it just stops at waiting for kernel...I'm going to try to build my custom kernel with my 5.8 and apply my patches...hopefully that's all I need!
