wifi ip and wifi mac change after booting
kimwida
Armbianmonitor:
Hi.
I was testing pwm with a motor, then my rock pis stopped.
After boot, I couldn't see wlan0 in nmtui-connect.
So I reinstall fresh armbian, I can see wlan0 again.
I do wifi setting with nmtui-connect but after rebooting I can't connect wifi.
I have to redo wifi setting with nmtui-connect, put password again and it adds another wifi.
It seems like it can't connect to previous wifi.
When I do "nmcli con show", I can see the previous wifi but it is deactive.
I searched about it and found wifi mac address randomization issue.
So I checked "10-override-random-mac-disable.conf".
[connection]
wifi.mac-address-randomization=1
[device]
wifi.scan-rand-mac-address=no
Whenever I redo nmtui-connect, it add file count in "/etc/NetworkManager/system-connections"
Is there any way to solve it?
Or pwm thing break wifi chips??
I found a workaround.
After boot, p2p0 connection is alive.
But each booting make its ip address grow.
So I changed it fixed ip like it.
#ifconfig p2p0 down
#ifconfig p2p0 2.1.1.38 netmask 255.255.255.0 up
#route add default gw 2.1.1.1
then, I can use wifi with p2p0.
So I add these commands into "rc.local".
ifconfig p2p0 down
sleep 10
dhclient p2p0
I searched and found solution.
After install fresh armbian, I added this to "/etc/network/interfaces"
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet static
    address 2.1.1.38
    gateway 2.1.1.1
    dns-nameservers 168.126.63.1 168.126.63.2
wireless-mode Managed
wireless-power off
