Unify "missing data" reply action
Werner
Go to solution Solved by Werner,
At the moment there are three different saved actions that kind of cover the same thing: Complain about missing data :P
I suggest to merge those to one standardized reply that covers missing data and armbianmonitor -u as well as tips.
Something like this (with a bit of additional formatting):
Quote
Your support topic is lacking of important debugging information. Please edit and fix!
Please describe your setup as best as possible so we know what your operating environment is like.
  • Name of your board with all details, version number, take a picture if you are not sure what you have
  • Name of the image you installed or logs if you can boot the board: armbianmonitor -u (paste URL to your forum post)
  • If your board does not boot, provide a log from serial console (UART) or at least make and attach a picture, where it stops.
  • Describe the problem the best you can and provide all necessary info that we can reproduce the problem.
  • If anything is attached to the board, supply all details
Tips:
  • use spoiler  when adding a long text,
  • use  when adding a code,
  • be concise.
Will unhide and add this reply.
1 hour ago, Werner said:
I assume my suggestion is fine
Yes, I didn't notice it :P Also check if we have an extra field for (title -> prefix -> armbianmonitor) when adding a new post. That might help a bit.
