7profy Posted June 30, 2016 Share Posted June 30, 2016 (edited) I'm using Orange Pi One with ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i. To access to UART I'm using function serialOpen() of WiringPi library. Default device name for Raspberry is '/dev/ttyAMA0'. But I can't open this device (No such file or directory). How to enable ttyAMA0? Edited June 30, 2016 by wildcat_paris added board name in title Link to comment Share on other sites More sharing options...
martinayotte Posted June 30, 2016 Share Posted June 30, 2016 Do you mean the Hardware Serial Port on the Pi header ? It is not /dev/ttyAMA0, but /dev/ttyS2 and /dev/ttyS3, depending which pins you looking at. Link to comment Share on other sites More sharing options...
7profy Posted June 30, 2016 Author Share Posted June 30, 2016 I'm looking at pin 8 and pin 10. Device ttyS3 not available too. Link to comment Share on other sites More sharing options...
martinayotte Posted June 30, 2016 Share Posted June 30, 2016 Pin 8/10 ? it should be /dev/ttyS3. Maybe you will need to tweak FEX or DTS, depending of the kernel you are using. Link to comment Share on other sites More sharing options...
7profy Posted June 30, 2016 Author Share Posted June 30, 2016 And how to "tweak"? And what is "FEX"? I'm trying to migrate from Rasperry to Orange. Almost all done. I'm not powerful linux user. Link to comment Share on other sites More sharing options...
martinayotte Posted July 1, 2016 Share Posted July 1, 2016 Depending of the version of your kernel, old ones called Legacy, it is using FEX to define GPIOs and Peripherals pins. Wit Mainline Kernel, it is using DTS. Maybe the settings currently are already Ok, did you have an /dev/ttyS3 ? If not, then those settings need to be tweaked. What is the kernel version you are using ? Do some search about UART FEX for Legacy. For Mainline, I think my contribution to DTS is already in all Armbian images. Link to comment Share on other sites More sharing options...
7profy Posted July 1, 2016 Author Share Posted July 1, 2016 About month ago I install from armbian.com this os. root@orangepione ~ # uname -a Linux orangepione 3.4.112-sun8i #8 SMP PREEMPT Tue May 31 19:00:17 CEST 2016 armv7l GNU/Linux How to find out it using FEX or DTS? I have the next device list: root@orangepione ~ # ls /dev/ android_adb input ram1 tty18 tty45 uinput apm_bios ion ram2 tty19 tty46 urandom autofs kmsg ram3 tty2 tty47 usb_accessory block lircd ram4 tty20 tty48 usbdev1.1 btrfs-control log ram5 tty21 tty49 usbdev2.1 bus loop0 ram6 tty22 tty5 usbdev3.1 cachefiles loop1 ram7 tty23 tty50 usbdev4.1 cedar_dev loop2 random tty24 tty51 usbdev5.1 char loop3 rfkill tty25 tty52 usbdev6.1 console loop4 rtc tty26 tty53 usbdev7.1 cpu_dma_latency loop5 rtc0 tty27 tty54 usbdev8.1 cuse loop6 shm tty28 tty55 vcs disk loop7 snd tty29 tty56 vcs1 disp loop-control spidev0.0 tty3 tty57 vcs2 ecryptfs mapper stderr tty30 tty58 vcs3 fb0 mem stdin tty31 tty59 vcs4 fb1 misc_fatfs stdout tty32 tty6 vcs5 fb2 mmcblk0 sunxi-reg tty33 tty60 vcs6 fb3 mmcblk0p1 sunxi_soc_info tty34 tty61 vcsa fb4 mqueue tty tty35 tty62 vcsa1 fb5 mtp_usb tty0 tty36 tty63 vcsa2 fb6 net tty1 tty37 tty7 vcsa3 fb7 network_latency tty10 tty38 tty8 vcsa4 fd network_throughput tty11 tty39 tty9 vcsa5 full null tty12 tty4 ttyGS0 vcsa6 fuse ppp tty13 tty40 ttyGS1 vmouse hdmi psaux tty14 tty41 ttyGS2 watchdog i2c-0 ptmx tty15 tty42 ttyGS3 xconsole i2c-1 pts tty16 tty43 ttyS0 zero initctl ram0 tty17 tty44 uhid GPIO: +-----+-----+----------+------+---+--OrangePiPC--+---+------+---------+-----+--+ | BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM | +-----+-----+----------+------+---+----++----+---+------+----------+-----+-----+ | | | 3.3v | | | 1 || 2 | | | 5v | | | | 2 | 8 | SDA.0 | ALT5 | 0 | 3 || 4 | | | 5V | | | | 3 | 9 | SCL.0 | ALT5 | 0 | 5 || 6 | | | 0v | | | | 4 | 7 | GPIO.7 | ALT3 | 0 | 7 || 8 | 0 | ALT3 | TxD3 | 15 | 14 | | | | 0v | | | 9 || 10 | 0 | ALT3 | RxD3 | 16 | 15 | | 17 | 0 | RxD2 | ALT3 | 0 | 11 || 12 | 0 | OUT | GPIO.1 | 1 | 18 | | 27 | 2 | TxD2 | ALT3 | 0 | 13 || 14 | | | 0v | | | | 22 | 3 | CTS2 | ALT3 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4 | 4 | 23 | | | | 3.3v | | | 17 || 18 | 0 | ALT3 | GPIO.5 | 5 | 24 | | 10 | 12 | MOSI | ALT4 | 0 | 19 || 20 | | | 0v | | | | 9 | 13 | MISO | ALT4 | 0 | 21 || 22 | 0 | ALT3 | RTS2 | 6 | 25 | | 11 | 14 | SCLK | ALT4 | 0 | 23 || 24 | 0 | ALT4 | CE0 | 10 | 8 | | | | 0v | | | 25 || 26 | 0 | ALT3 | GPIO.11 | 11 | 7 | | 0 | 30 | SDA.1 | ALT4 | 0 | 27 || 28 | 0 | ALT4 | SCL.1 | 31 | 1 | | 5 | 21 | GPIO.21 | ALT3 | 0 | 29 || 30 | | | 0v | | | | 6 | 22 | GPIO.22 | ALT3 | 0 | 31 || 32 | 1 | OUT | RTS1 | 26 | 12 | | 13 | 23 | GPIO.23 | ALT3 | 0 | 33 || 34 | | | 0v | | | | 19 | 24 | GPIO.24 | OUT | 1 | 35 || 36 | 1 | OUT | CTS1 | 27 | 16 | | 26 | 25 | GPIO.25 | ALT3 | 0 | 37 || 38 | 1 | OUT | TxD1 | 28 | 20 | | | | 0v | | | 39 || 40 | 1 | OUT | RxD1 | 29 | 21 | +-----+-----+----------+------+---+----++----+---+------+----------+-----+-----+ | BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM | +-----+-----+----------+------+---+--OrangePIPC--+------+----------+-----+-----+ Although GPIO allows to change pins values ALTx, but actually they are not changed. What I have to do? Link to comment Share on other sites More sharing options...
7profy Posted July 1, 2016 Author Share Posted July 1, 2016 (edited) SOLVED! Here is solution (for H3): 1. Convert script.bin to FEX: cd /boot bin2fex script.bin script.fex 2. Edit script.fex to enable UART3: sudo nano script.fex Find section [uart0] and set the next to disable uart0-2 and enable uart3 only with 2-pin mode on pin 8/10: [uart0] uart_used = 0 uart_port = 0 uart_type = 2 uart_tx = port:PA04<2><1><default><default> uart_rx = port:PA05<2><1><default><default> [uart1] uart_used = 0 uart_port = 1 uart_type = 4 uart_tx = port:PG06<2><1><default><default> uart_rx = port:PG07<2><1><default><default> uart_rts = port:PG08<2><1><default><default> uart_cts = port:PG09<2><1><default><default> [uart2] uart_used = 0 uart_port = 2 uart_type = 4 uart_tx = port:PA00<2><1><default><default> uart_rx = port:PA01<2><1><default><default> uart_rts = port:PA02<2><1><default><default> uart_cts = port:PA03<2><1><default><default> [uart3] uart_used = 1 uart_port = 3 uart_type = 2 uart_tx = port:PA13<2><1><default><default> uart_rx = port:PA14<2><1><default><default> ;uart_rts = port:PA15<3><1><default><default> ;uart_cts = port:PA16<3><1><default><default> Remark: I don't find description for value <2> in PA13<2> but it works as expected. 3. Save changes. 4. Convert FEX to bin fex2bin script.fex script.bin 5. Reboot. 6. Device name is ttyS3. Default speed = 57600. To test it type "echo TEST > /dev/ttyS3" PS. Some times after apt-get upgrade script.bin replaces to default values, so it need to repeat all steps. Edited August 11, 2016 by 7profy 1 Link to comment Share on other sites More sharing options...
martinayotte Posted July 1, 2016 Share Posted July 1, 2016 Good ! Glad that you've figured out ! Link to comment Share on other sites More sharing options...
Ahmed Posted February 28, 2017 Share Posted February 28, 2017 Thanks 7profy and Martinayotte, your discussion was very helpful for me. Link to comment Share on other sites More sharing options...
angyalr Posted April 5, 2017 Share Posted April 5, 2017 I use Orange PI PC Plus with Debian 8. Need disable GPIO in fex file, for work ttyS3. [gpio_para] gpio_used = 0 gpio_num = 19 gpio_pin_1 = port:PA06<1><default><default><0> gpio_pin_2 = port:PA13<1><default><default><0> gpio_pin_3 = port:PA14<1><default><default><0> gpio_pin_4 = port:PA01<1><default><default><0> gpio_pin_5 = port:PD14<1><default><default><0> gpio_pin_6 = port:PA00<1><default><default><0> gpio_pin_7 = port:PA03<1><default><default><0> gpio_pin_8 = port:PC04<1><default><default><0> gpio_pin_9 = port:PC07<1><default><default><0> gpio_pin_10 = port:PA02<1><default><default><0> gpio_pin_11 = port:PA21<1><default><default><0> gpio_pin_12 = port:PA07<1><default><default><0> gpio_pin_13 = port:PA08<1><default><default><0> gpio_pin_14 = port:PG08<1><default><default><0> gpio_pin_15 = port:PA09<1><default><default><0> gpio_pin_16 = port:PA10<1><default><default><0> gpio_pin_17 = port:PG09<1><default><default><0> gpio_pin_18 = port:PG06<1><default><default><0> gpio_pin_19 = port:PG07<1><default><default><0> How can rewrite it to work well the GPIO, and also ttyS3? Thank You Link to comment Share on other sites More sharing options...
angyalr Posted April 6, 2017 Share Posted April 6, 2017 I rewrite this [gpio_para]gpio_used = 1gpio_num = 19gpio_pin_1 = port:PA06<1><default><default><0>gpio_pin_2 = port:PA15<1><default><default><0>gpio_pin_3 = port:PA16<1><default><default><0> And working fine. Without RTS and CTS. [uart3] uart_used = 1 uart_port = 3 uart_type = 2 uart_tx = port:PA13<3><1><default><default> uart_rx = port:PA14<3><1><default><default> ;uart_rts = port:PA15<3><1><default><default> ;uart_cts = port:PA16<3><1><default><default> Link to comment Share on other sites More sharing options...
ajgelado Posted April 24, 2017 Share Posted April 24, 2017 I need to use the serial port in the 26-pin header of an Orange Pi Zero. For what I have read, I assume that it is /dev/ttyS3. Is that right? I have followed the instructions of 7profy, and now ttyS3 shows in /dev/, but I can't get the port to work. But when I hook a serial-to-USB adapter to pins 6, 8 and 10, and try to communicate with it using minicom, nothing happens. I have double-checked the communications settings (both minicom and PuTTY are set to 9600,8,n,1) and the connections, and I have tested /dev/ttyS2 and /dev/ttyS1 just in case, but I have got no reply at all. How can I verify the serial port is enabled and working? Are there any extra steps to enable /dev/ttyS3 on the Orange Pi Zero? uname -a outputs the following: Linux orangepizero 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l GNU/Linux Link to comment Share on other sites More sharing options...
martinayotte Posted April 24, 2017 Share Posted April 24, 2017 To isolate the issue, maybe you should try to do a simple loopback test first, a jumper between 8 and 10, and use minicom or picocom to get local echo. BTW, in the case of Mainline, without having other uart enabled other than debug uart0, when I load overlay for uart2, it comes up as /dev/ttyS1, since debug is on /dev/ttyS0. 1 Link to comment Share on other sites More sharing options...
ajgelado Posted April 24, 2017 Share Posted April 24, 2017 Thanks, martinayotte. That was it! I have to use /dev/ttyS1 in the OPiZero. Link to comment Share on other sites More sharing options...
subnet Posted May 14, 2017 Share Posted May 14, 2017 Registered to thanks 7profy and Martinayotte, this post was very useful to me to enable UART1 Link to comment Share on other sites More sharing options...
pel.hu Posted May 23, 2017 Share Posted May 23, 2017 Orange Pi Zero working fine for me (ttyS1 on pin 8, pin 10) with this settings in script.fex: [uart1] uart_used = 1 uart_port = 1 uart_type = 2 uart_tx = port:PG06<2><1><default><default> uart_rx = port:PG07<2><1><default><default> There is no [gpio_para] section. Link to comment Share on other sites More sharing options...
Tommy Tang Posted July 9, 2017 Share Posted July 9, 2017 for mainline kernel ``` Linux version 4.11.5-sun8i (root@devel) (gcc version 7.1.1 20170510 (Linaro GCC 7.1-2017.05) ) #11 SMP Fri Jun 23 20:03:23 CEST 2017 user@orangepipcplus:/boot/dtb$ ls -al /dev/ttyS* crw--w---- 1 root tty 4, 64 Jun 25 12:07 /dev/ttyS0 crw-rw---- 1 root dialout 4, 65 Jun 25 12:07 /dev/ttyS1 crw-rw---- 1 root dialout 4, 66 Jun 25 12:07 /dev/ttyS2 crw-rw---- 1 root dialout 4, 67 Jun 25 12:07 /dev/ttyS3 crw-rw---- 1 root dialout 4, 68 Jun 25 12:07 /dev/ttyS4 crw-rw---- 1 root dialout 4, 69 Jun 25 12:07 /dev/ttyS5 crw-rw---- 1 root dialout 4, 70 Jun 25 12:07 /dev/ttyS6 crw-rw---- 1 root dialout 4, 71 Jun 25 12:07 /dev/ttyS7 ``` Even connected pin 38 and 40, no characters are shown in local echo. Any steps (kernel or user layout) required to enable ttyS1. Link to comment Share on other sites More sharing options...
martinayotte Posted July 9, 2017 Share Posted July 9, 2017 You need to add "overlays=uart1" in armbienEnv.txt and reboot Link to comment Share on other sites More sharing options...
Tommy Tang Posted July 9, 2017 Share Posted July 9, 2017 for mainline kernel ``` Linux version 4.11.5-sun8i (root@devel) (gcc version 7.1.1 20170510 (Linaro GCC 7.1-2017.05) ) #11 SMP Fri Jun 23 20:03:23 CEST 2017 user@orangepipcplus:/boot/dtb$ dtc -I dtb sun8i-h3-orangepi-pc-plus.dtb -O dts |less uart1 { pins = "PG6", "PG7"; function = "uart1"; linux,phandle = <0x19>; phandle = <0x19>; }; uart1_rts_cts { pins = "PG8", "PG9"; function = "uart1"; linux,phandle = <0x48>; phandle = <0x48>; }; user@orangepipcplus:/boot/dtb$ ls -al /dev/ttyS* crw--w---- 1 root tty 4, 64 Jun 25 12:07 /dev/ttyS0 crw-rw---- 1 root dialout 4, 65 Jun 25 12:07 /dev/ttyS1 crw-rw---- 1 root dialout 4, 66 Jun 25 12:07 /dev/ttyS2 crw-rw---- 1 root dialout 4, 67 Jun 25 12:07 /dev/ttyS3 crw-rw---- 1 root dialout 4, 68 Jun 25 12:07 /dev/ttyS4 crw-rw---- 1 root dialout 4, 69 Jun 25 12:07 /dev/ttyS5 crw-rw---- 1 root dialout 4, 70 Jun 25 12:07 /dev/ttyS6 crw-rw---- 1 root dialout 4, 71 Jun 25 12:07 /dev/ttyS7 minicom with hardware flow disabled and software flow enabled │ A - Serial Device : /dev/ttyS1 │ │ B - Lockfile Location : /var/lock │ │ C - Callin Program : │ │ D - Callout Program : │ │ E - Bps/Par/Bits : 9600 8N1 │ │ F - Hardware Flow Control : No │ │ G - Software Flow Control : Yes │ │ │ │ Change which setting? ``` Even connected pin 38 and 40, no characters are shown in local echo. Any steps (kernel or user layout) required to enable ttyS1. Link to comment Share on other sites More sharing options...
Tommy Tang Posted July 9, 2017 Share Posted July 9, 2017 18 minutes ago, martinayotte said: You need to add "overlays=uart1" in armbienEnv.txt and reboot It works perfect. This forum is far better than many worldwide software company Thanks for your prompt reply. Link to comment Share on other sites More sharing options...
martinayotte Posted July 9, 2017 Share Posted July 9, 2017 Welcome ! Link to comment Share on other sites More sharing options...
wawan Posted October 4, 2017 Share Posted October 4, 2017 Hi I tried to swap pin tx and rx on uart1 [uart1] uart_used = 0 uart_port = 1 uart_type = 4 uart_tx = port:PG07<2><1><default><default> uart_rx = port:PG06<2><1><default><default> physical pin on 38 and 40 but still, no change is it fixed pin mapping for PG07 and 06 with physical pin or there is another conf at fex file? Thanks Link to comment Share on other sites More sharing options...
martinayotte Posted October 4, 2017 Share Posted October 4, 2017 4 hours ago, wawan said: [uart1] uart_used = 0 "uart_used = 0" means "disabled". Change it to 1 will enable it ... (also, make sure PG06/PG07 are not part of GPIOs list) Link to comment Share on other sites More sharing options...
zador.blood.stained Posted October 4, 2017 Share Posted October 4, 2017 4 hours ago, wawan said: is it fixed pin mapping for PG07 and 06 with physical pin or there is another conf at fex file? It's fixed and can't be changed. Link to comment Share on other sites More sharing options...
tush.jambhekar Posted March 18, 2018 Share Posted March 18, 2018 Hi I am having following kernal Linux orangepi 3.4.39 #41 SMP PREEMPT Sun Jun 21 13:09:26 HKT 2015 armv7l armv7l armv7l GNU/Linux and in my boot directory there is no script.bin file. how can i enable my serial ports 2 and 3. also my serial port 1 seems to be used for console is there any way that i can disable console output and use the same port for my custom application Link to comment Share on other sites More sharing options...
Igor Posted March 18, 2018 Share Posted March 18, 2018 27 minutes ago, tush.jambhekar said: I am having following kernal Linux orangepi 3.4.39 #41 SMP PREEMPT Sun Jun 21 13:09:26 HKT 2015 armv7l armv7l armv7l GNU/Linux and in my boot directory there is no script.bin file. how can i enable my serial ports 2 and 3. also my serial port 1 seems to be used for console is there any way that i can disable console output and use the same port for my custom application That kernel is supported by no one and the process of changing parameters is not as simple as in armbian. Link to comment Share on other sites More sharing options...
TheOWL Posted November 18, 2018 Share Posted November 18, 2018 On 7/9/2017 at 11:18 PM, martinayotte said: You need to add "overlays=uart1" in armbienEnv.txt and reboot OHHHHHH Sh!t......it works!!! I sign up an account just to thank martinayotte !!! You are like god for me now ! 1 Link to comment Share on other sites More sharing options...
