Salvador Liébana Posted September 20, 2020 Share Posted September 20, 2020 HI. I burned the latest official Rockpi4 focal kernel 5.8.x on both rockpi 4 B and C. The problem is only present on the C model. Both USB 2.0 aren't working at all. 0 Quote Link to comment Share on other sites More sharing options...
piter75 Posted September 20, 2020 Share Posted September 20, 2020 26 minutes ago, Salvador Liébana said: I burned the latest official Rockpi4 focal kernel 5.8.x on both rockpi 4 B and C Did you use the w same image for ROCK Pi 4C and 4B? 4C needs different images for all usb ports to work properly. You could also adjust the currently burnt image by editing fdtfile setting in /boot/armbianEnv.txt. Make sure fdtfile contains 4c and not 4b and reboot. All usb ports should be working after the reboot. 0 Quote Link to comment Share on other sites More sharing options...
Salvador Liébana Posted September 21, 2020 Author Share Posted September 21, 2020 Thanks! I will try that! 1 Quote Link to comment Share on other sites More sharing options...
Werner Posted September 21, 2020 Share Posted September 21, 2020 Let us know if this solved your issue so the topic can be marked appropriately 0 Quote Link to comment Share on other sites More sharing options...
Salvador Liébana Posted September 23, 2020 Author Share Posted September 23, 2020 Solved! Thanks! I didn't tough they were require different dtbs. It should appear on the armbian site bc all the boards appear as the same (rockpi4b/a/c). 0 Quote Link to comment Share on other sites More sharing options...
