Irene Posted September 24, 2020 Share Posted September 24, 2020 We are starting a HW design for a board that will probably be using RK3328. We want this board to be running Armbian. We need to select BT and Wifi chips. Would like to use chips that are already supported by Armbian. Is there a list of Bluetooth and Wifi chips that Armbian supports? Any recommendations? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted September 24, 2020 Share Posted September 24, 2020 41 minutes ago, Irene said: We want Do you support Armbian? 0 Quote Link to comment Share on other sites More sharing options...
Irene Posted September 24, 2020 Author Share Posted September 24, 2020 Right now we are evaluating on ROCK64 board running Armbian. So, the answer is yes, on the new board we also want to be running Armbian. 0 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted September 25, 2020 Share Posted September 25, 2020 17 hours ago, Irene said: Any recommendations? IMHO, choose models that have good (full-fledged) support in the main core. This ensures that your equipment will always work. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted September 25, 2020 Share Posted September 25, 2020 16 hours ago, Irene said: Right now we are evaluating on ROCK64 board running Armbian. So, the answer is yes, on the new board we also want to be running Armbian. You didn't understand correctly. We don't want to have anything to do with the hardware you are making. For free support, apply here: but since we have no resources to support your business or hobby, chances are none. If you support Armbian, that we can hire help, we will help you. 0 Quote Link to comment Share on other sites More sharing options...
Irene Posted September 25, 2020 Author Share Posted September 25, 2020 Igor, I think you misunderstood what I was asking. I wasn't asking you to support hardware that we are making. I was asking which BT and Wifi chips that hardware that you are already supporting is using. We would like to use BT and Wifi chips that are already supported by Armbian, so that we don't need to add new drivers. 0 Quote Link to comment Share on other sites More sharing options...
NicoD Posted September 25, 2020 Share Posted September 25, 2020 41 minutes ago, Irene said: I was asking which BT and Wifi chips that hardware that you are already supporting is using. We would like to use BT and Wifi chips that are already supported by Armbian, so that we don't need to add new drivers. Maybe you can find this here. https://wiki.pine64.org/index.php/ROCK64#SoC_and_Memory_Specification Look what board is supported and then do your homework. All info is to be found on the internet. 0 Quote Link to comment Share on other sites More sharing options...
