ilyaigpetrov Posted October 4, 2020 Share Posted October 4, 2020 Armbianmonitor: http://ix.io/2zGW Device: Orange Pi PC. Image: Armbian_20.08.1_Orangepipc_focal_current_5.8.5.img. Issue: No sound in the terminal when I run `sudo speaker-test` or `speaker-test` or if I launch kodi-gbm. I have an old Armbian image with Linux 3.4.112-sun8i Ubuntu 16.04.7 Xenial, it has xfce desktop installed -- there if I set sndhdmi device as a fallback device then `speaker-test` plays fine. I tried installing xfce and pulseaudio on this current Armbian Focal (not via arm-config, but via `apt install xorg xfce4 pulseaudio`) but in the audio settings there are only 2 devices both named "Built-in Audio Stereo" and setting any of them as a fallback doesn't produce sound over hdmi in the speaker-test.And I'm interested in sound in terminal and kodi-bgm, not xfce desktop. $ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 [CDC PCM Codec-0] Subdevices: 0/1 Subdevice #0: subdevice #0 card 1: sun8ih3hdmi [sun8i-h3-hdmi], device 0: 1c22800.i2s-i2s-hifi i2s-hifi-0 [1c22800.i2s-i2s-hifi i2s-hifi-0] Subdevices: 0/1 Subdevice #0: subdevice #0 $ mpv --audio-device=help List of detected audio devices: 'auto' (Autoselect device) 'pulse/alsa_output.platform-hdmi-sound.stereo-fallback' (Built-in Audio Stereo) 'pulse/alsa_output.platform-1c22c00.codec.stereo-fallback' (Built-in Audio Stereo) 'alsa' (Default (alsa)) 'alsa/samplerate' (Rate Converter Plugin Using Samplerate Library) 'alsa/speexrate' (Rate Converter Plugin Using Speex Resampler) 'alsa/jack' (JACK Audio Connection Kit) 'alsa/oss' (Open Sound System) 'alsa/upmix' (Plugin for channel upmix (4,6,8)) 'alsa/vdownmix' (Plugin for channel downmix (stereo) with a simple spacialization) 'alsa/sysdefault:CARD=Codec' (H3 Audio Codec, CDC PCM Codec-0/Default Audio Device) 'alsa/dmix:CARD=Codec,DEV=0' (H3 Audio Codec, CDC PCM Codec-0/Direct sample mixing device) 'alsa/plughw:CARD=Codec,DEV=0' (H3 Audio Codec, CDC PCM Codec-0/Hardware device with all software conversions) 'alsa/usbstream:CARD=Codec' (H3 Audio Codec/USB Stream Output) 'alsa/sysdefault:CARD=sun8ih3hdmi' (sun8i-h3-hdmi, 1c22800.i2s-i2s-hifi i2s-hifi-0/Default Audio Device) 'alsa/dmix:CARD=sun8ih3hdmi,DEV=0' (sun8i-h3-hdmi, 1c22800.i2s-i2s-hifi i2s-hifi-0/Direct sample mixing device) 'alsa/plughw:CARD=sun8ih3hdmi,DEV=0' (sun8i-h3-hdmi, 1c22800.i2s-i2s-hifi i2s-hifi-0/Hardware device with all software conversions) 'alsa/usbstream:CARD=sun8ih3hdmi' (sun8i-h3-hdmi/USB Stream Output) 'jack' (Default (jack)) 'sdl' (Default (sdl)) 'sndio' (Default (sndio)) I tried different advice from different topics on this and other forums to no avail. 1) I tried adding my user to audio group (`sudo usermod -a -G audio <username>`). 2) I tried opening alsamixer and muting ("m" key) and unmuting line-in, line-out. 3) I tried adding and tweaking /etc/asound.conf. 0 Quote Link to comment Share on other sites More sharing options...
xwiggen Posted October 4, 2020 Share Posted October 4, 2020 did you try adding: defaults.pcm.card 1 defaults.ctl.card 1 to /etc/asound.conf? 0 Quote Link to comment Share on other sites More sharing options...
ilyaigpetrov Posted October 5, 2020 Author Share Posted October 5, 2020 This produces no effect: # cat << EOF > /etc/asound.conf > defaults.pcm.card 1 > defaults.ctl.card 1 > EOF # cat /etc/asound.conf defaults.pcm.card 1 defaults.ctl.card 1 # speaker-test @xwiggen # cat /etc/asound.conf pcm.!default { type hw card 1 } ctl.!default { type hw card 1 } # speaker-test speaker-test 1.2.2 Playback device is default Stream parameters are 48000Hz, S16_LE, 1 channels Using 16 octaves of pink noise Channels count (1) not available for playbacks: Invalid argument Setting of hwparams failed: Invalid argument # Changing `card 1` to `card 0` produces no sound. # Adding `device 0` or `device 1` doesn't help also. # cat /etc/asound.conf pcm.!default { type hw card 0 device 0 } ctl.!default { type hw card 0 device 0 } # speaker-test # No sound. 0 Quote Link to comment Share on other sites More sharing options...
ilyaigpetrov Posted October 9, 2020 Author Share Posted October 9, 2020 Here is armbianmonitor for Armbian Xenial (xfce, pulseaduio) where hdmi works: http://ix.io/2AcT. Here is armbianmonitor for Armbian Focal (terminal, no pulseaduio) where hdmi doesn't work: http://ix.io/2AcU. 0 Quote Link to comment Share on other sites More sharing options...
ning Posted November 2, 2020 Share Posted November 2, 2020 the simple way: install pulseaudio mpv -ao pulse xxx.mp3 0 Quote Link to comment Share on other sites More sharing options...
ilyaigpetrov Posted November 6, 2020 Author Share Posted November 6, 2020 On 11/2/2020 at 4:04 AM, ning said: the simple way: install pulseaudio mpv -ao pulse xxx.mp3 Thanks for you reply, @ning, but unfortunately it doesn't work: ilyaigpetrov@orangepipc:~$ mpv --ao=pulse ./foobar.mp3 (+) Audio --aid=1 (mp3 2ch 48000Hz) AO: [pulse] 48000Hz stereo 2ch float A: 00:00:00 / 01:20:04 (0%) No sound is heard. And it freezes at 00:00:00 and 0% not moving any further. I used `sudo apt install pulseaudio` for installing pulseaudio. 0 Quote Link to comment Share on other sites More sharing options...
