Docker unknown OS
Vin
Hello together,
for a few months im running into this problem, where i cannot initiate a docker container, it will return following error message.
docker: unknown server OS:
sudo -u Username docker run -d \
--name=deconz \
--net=host \
--restart=always \
-v /etc/localtime:/etc/localtime:ro \
-v /opt/deconz:/root/.local/share/dresden-elektronik/deCONZ \
--device=/dev/ttyACM0 \
-e DECONZ_VNC_MODE=1 \
-e DECONZ_WEB_PORT=82 \
-e DECONZ_WS_PORT=8443 \
marthoc/deconz
Linux rock64 5.8.13-rockchip64 #20.08.7 SMP PREEMPT Fri Oct 2 10:36:32 CEST 2020 aarch64 GNU/Linux
Anbody can help?
Thank you in advance.
Best Regards
Sven
I see you are using mainline (current) kernel, try legacy. Also, have you tried different versions of docker (official docker repos vs. distro repos)?
I can confirm docker runs well on the rock64 with legacy kernel and Bionic package (apt install docker.io)
Found the solution to this problem, just start it witout sudo
docker run -d \
--name=deconz \
--net=host \
--restart=always \
marthoc/deconz
JMCC thanks anyway for the reply :)
