buratino Posted October 13, 2020 Share Posted October 13, 2020 Hello! I wrote the wrong bootloader to the emms, now the download does not happen with either emmc or micro-sd. U-Boot TPL 2020.10-00676-g9885313b9a (Oct 13 2020 - 06:24:16) sdram_init: LPDDR3 - 933MHz failed! rk3399_dmc_init DRAM init failed -22 Missing DTB Now I can't use the board in any way, how can I clear the emmc memory? 0 Quote Link to comment Share on other sites More sharing options...
MacBreaker Posted October 13, 2020 Share Posted October 13, 2020 @buratino did you try this? Maybe it helps... 0 Quote Link to comment Share on other sites More sharing options...
buratino Posted October 13, 2020 Author Share Posted October 13, 2020 3 hours ago, MacBreaker said: @buratino did you try this? Maybe it helps... No, I set the bitrate to the correct one. It helped me to close contact TP50265 to GND during power-on. 0 Quote Link to comment Share on other sites More sharing options...
