pochin2208 Posted October 15, 2020 Share Posted October 15, 2020 Hi, I've been trying to get the next IMU sensor to work: Fusion_IMU_BNO055, on my OPi zero with Armbian Bionic 20.08.10 with the linux kernel 5.8.14-sunxi. I have installed everything from the official Adafruit guide but I still get the same error. I have followed all the steps of this guide for beginners: OPi_r1_guide, executing all the commands successfully. However, I still have the same error in Python that is related to the "board" module. root@orangepizero:/home/Test# python Python 3.6.9 (default, Oct 8 2020, 12:12:24) [GCC 8.4.0] on linux Type "help", "copyright", "credits" or "license" for more information. >>> import board Traceback (most recent call last): File "<stdin>", line 1, in <module> File "/usr/local/lib/python3.6/dist-packages/board.py", line 82, in <module> from adafruit_blinka.board.orangepi.orangepizero import * File "/usr/local/lib/python3.6/dist-packages/adafruit_blinka/board/orangepi/orangepizero.py", line 5, in <module> from adafruit_blinka.microcontroller.allwinner.h3 import pin File "/usr/local/lib/python3.6/dist-packages/adafruit_blinka/microcontroller/allwinner/h3/pin.py", line 4, in <module> PA0 = Pin(0) File "/usr/local/lib/python3.6/dist-packages/adafruit_blinka/microcontroller/generic_linux/libgpiod_pin.py", line 34, in __init__ self._chip = gpiod.Chip("gpiochip0", gpiod.Chip.OPEN_BY_NAME) AttributeError: module 'gpiod' has no attribute 'Chip' >>> exit() The python code that I try to execute is the following: import board import digitalio import busio print("Hello blinka!") # Try to great a Digital input pin = digitalio.DigitalInOut(board.PA6) print("Digital IO ok!") # Try to create an I2C device i2c = busio.I2C(board.SCL, board.SDA) print("I2C ok!") # Try to create an SPI device spi = busio.SPI(board.SCLK, board.MOSI, board.MISO) print("SPI ok!") print("done!") If you need more details I will gladly give them to you. Thank you. 0 Quote Link to comment Share on other sites More sharing options...
