Werner Posted October 18, 2020 Share Posted October 18, 2020 https://forum.armbian.com/guidelines/ I just dropped over this page by accident and I think this is the first time I have seen this since I registered I have my doubts that many actually reading those, last but not least it is a lot of text and most is already spreat around to places where it is actually important. So I suggest to simply remove the page due to lack of value. Link to comment Share on other sites More sharing options...
lanefu Posted October 18, 2020 Share Posted October 18, 2020 my only counterpoint is that it's a central place for us to reference when warning a user, etc. Link to comment Share on other sites More sharing options...
Werner Posted October 18, 2020 Author Share Posted October 18, 2020 There are still the registration terms which are way mor compact and kept generally valid: https://forum.armbian.com/terms Link to comment Share on other sites More sharing options...
chwe Posted October 22, 2020 Share Posted October 22, 2020 On 10/18/2020 at 11:33 AM, Werner said: I think this is the first time I have seen this since I registered well that's probably the problem of that page... It never got the attention it should. the guidlines are missing a few stuff.. e.g. that we refused to give an answer without providing 'armbianmonitor -u' and what the developer forum was ment to be (e.g. nobody ever cared but well.. now all SoCs are considered supported, so at least we can't blaim them for asking stuff anymore.. Quote A support question must include the following: Board you use Issue you face Description of your set-up (e.g. powering, connected hardware, used SD-Card) 'sudo armbianmonitor -u' - this gives us some needed logs which makes debugging a way easier! We are not 'SBC Whisperers' or mind-readers! We need logs to work with, that's why 'armbianmonitor -u' was developed. If your board refuses to boot with a freshly prepared Image from our download page, please read again 'SD card and power supply' and 'Getting started'. Chances are high that this is a related to SD card and or insufficient powering! If your board refuses to boot after upgrade, try to provide at least a bootlog from serial console. USB-UART bridges aren't that pricey (< 2USD shipped from Ebay/Aliexpress) and worth every cent when you work with SBCs. don't throw the sbc whisperers away.. it described it as best as we can.. Link to comment Share on other sites More sharing options...
Werner Posted October 23, 2020 Author Share Posted October 23, 2020 The other option is to bring the guidlines better to people's attention. Link to comment Share on other sites More sharing options...
Werner Posted October 25, 2020 Author Share Posted October 25, 2020 Okay, decided that the guidelines are kept but I did some adjustments. I think I will link them in the new topic rules where fitting too. Link to comment Share on other sites More sharing options...
