voltagex Posted October 20, 2020 Share Posted October 20, 2020 (edited) So, I thought this was worth a try: diff --git a/config/sources/families/mvebu64.conf b/config/sources/families/mvebu64.conf index 091b7633..79e85954 100644 --- a/config/sources/families/mvebu64.conf +++ b/config/sources/families/mvebu64.conf @@ -1,6 +1,6 @@ ARCH=arm64 -BOOTSOURCE='https://github.com/MarvellEmbeddedProcessors/u-boot-marvell.git' -BOOTBRANCH='branch:u-boot-2018.03-armada-18.12' +BOOTSOURCE='https://github.com/u-boot/u-boot' +BOOTBRANCH='branch:master' BOOTENV_FILE='mvebu64.txt' ATFSOURCE='https://github.com/MarvellEmbeddedProcessors/atf-marvell' ATFDIR='arm-trusted-firmware-espressobin' TIM-1.0 WTMI-devel-18.12.1-e6bb176 WTMI: system early-init DDR topology parameters: ======================== ddr type DDR3 ddr speedbin 12 bus width 16-bits cs num 2 cs[0] - group num 0 cs[0] - bank num 8 cs[0] - capacity 1024MiB cs[1] - group num 0 cs[1] - bank num 8 cs[1] - capacity 1024MiB CPU VDD voltage default value: 1.108V DRAM windows: ============= WIN[0] - base addr 0x60000000 WIN[0] - size 0x40000000 WIN[1] - base addr 0xa0000000 WIN[1] - size 0x20000000 memory test region: =================== CS[0] 0x60000000 - 0x9fffffff CS[1] 0xa0000000 - 0xbfffffff SELF-REFRESH TEST PASS SELF-REFRESH TEST PASS CS0: QS GATE TRAINING PASSED CS1: QS GATE TRAINING PASSED DLL TUNING PASSED NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.5(debug):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL1: Built : 14:05:30, Oct 20 2020 NOTICE: BL1: Booting BL2 NOTICE: BL2: v1.5(debug):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL2: Built : 14:05:30, Oct 20 2020 NOTICE: BL1: Booting BL31 NOTICE: BL31: v1.5(debug):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL31: Built : 14:05:30 U-Boot 2020.10-armbian (Oct 20 2020 - 14:05:01 +0000) DRAM: 2 GiB Comphy-0: USB3_HOST0 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 5 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link up MMC: sdhci@d0000: 0 Loading Environment from SPIFlash... SF: Detected w25q32dw with page size 256 By tes, erase size 4 KiB, total 4 MiB OK Model: Globalscale Marvell ESPRESSOBin Board Net: eth0: neta@30000 [PRIME] My own kernels boot but I'm still having issues with the latest armbian SD card images (same issue with 2017 and 2018 u-boots). I'm not game to touch atf - someone with Marvell's wtp tools set up can do that Edited October 20, 2020 by voltagex atf info 0 Quote Link to comment Share on other sites More sharing options...
Pali Posted October 3, 2021 Share Posted October 3, 2021 Mainline U-Boot should really work fine. Just build ARM trusted firmware and U-Boot according to the latest guide: https://trustedfirmware-a.readthedocs.io/en/latest/plat/marvell/armada/build.html (search for example how to build production release of Marvell firmware image) 0 Quote Link to comment Share on other sites More sharing options...
Excalibur Posted October 15, 2021 Share Posted October 15, 2021 I believe Armbian already produce mainline U-Boot for this board so you don't need to compile yourself. The package is named `linux-u-boot-espressobin-edge` so you need to extract it yourself. That is what I used to boot vanilla Debian with grub-efi. However, ATF BL1 BL2 BL31 are listed as version 1.5 instead of 2.4. U-Boot was fine and distro boot works so I didn't worry about those. 0 Quote Link to comment Share on other sites More sharing options...
Pali Posted October 15, 2021 Share Posted October 15, 2021 6 hours ago, Excalibur said: I believe Armbian already produce mainline No, it does not. I have already reported lines which needs to be adjusted for mainline version, but they ignored it. So build mainline version manually and avoid usage of old version which is in Armbian. There are lot of fixes in mainline firmware version. 0 Quote Link to comment Share on other sites More sharing options...
lanefu Posted October 15, 2021 Share Posted October 15, 2021 (edited) 7 minutes ago, Pali said: No, it does not. I have already reported lines which needs to be adjusted for mainline version, but they ignored it. never got a PR https://www.armbian.com/newsflash/armbian-needs-your-help/ Edited October 15, 2021 by lanefu added armbian needs help post 0 Quote Link to comment Share on other sites More sharing options...
