[SOLVED] Correct way of adding files to image
bozden
Go to solution Solved by bozden,
I have several files I want to embed into the compiled image, such as logos, desktop backgrounds, some public keys, scripts etc.
I can put them in correct place (e.g. /usr/local/bin) or put it in a directory at root (e.g. /MyAppSetup) and run a script to handle/move them.
In the past I was using a private git repo on my server to clone these, but if I'm compiling, I'd like to get rid of this extra layer.
I could not find a way to do that. Could someone please advise?
OK, learning...
I just recognized customize-image.sh is run in chroot, so direct access to host OS is not possible, maybe there is a variable for host binding which I couldn't find.
On the other hand lib.config is run on host. Although it seems to be used for setting variables, it is source'd, so I can run anything there. So, this might work:
cp "${SRC}""${MY_PRODUCT_DIR}" "${SDCARD}""${MY_SETUP_DIR}"
And in customize-image.sh, I can move files around and do whatever I like with them.
Can somebody please confirm? It takes too long to test...
  • Solution
2 hours ago, Werner said:
Maybe this help:
Thank you Werner, that helps.
I had a misconception with the namin. "Userpatch" mixed with kernel pathing, "overlay" with overlayfs.
After examining the code I found correct keywords for search and found this:
I also recognized from the code that only customize-image.sh is copied to destination and my other files (which I call from it) do not.
Now the post you shared comes into play...
Thank you again.
  • bozden changed the title to [SOLVED] Correct way of adding files to image
