[Solved in later thread] 16X2 lcd I2C
rsegoly
I am currently using 16x2 LCD with arduino, so I guess, it should be almost the same. find the 2 wire I2C pins on OPi, I guess you could adapt your RPi program for the OPi one pins (if not the same ones, maybe it is a compatible header?)
I tried using same procedure i do for raspberry
sudo nano /etc/modprobe.d/raspi-blacklist.conf - Adding (needed on Orangepi?)
blacklist spi-bcm2708
#blacklist i2c-bcm2708
sudo nano /etc/modules
snd-bcm2835
i2c-dev
sudo apt-get install i2c-tools
sudo apt-get install python-smbus
sudo adduser pi i2c (no such group created on Orange)
Reboot
Edit /boot/config.txt and add the text
dtparam=i2c1=on
dtparam=i2c_arm=on
LCD PI
wget https://bitbucket.org/MattHawkinsUK/rpispy-misc/raw/master/python/lcd_i2c.py
 And run the script
Failed
I can see the iec device on 0x27
But running python script gets this result
Traceback (most recent call last):
  File "lcd_i2c.py", line 135, in <module>
    lcd_byte(0x01, LCD_CMD)
  File "lcd_i2c.py", line 83, in lcd_byte
    bus.write_byte(I2C_ADDR, bits_high)
IOError: [Errno 70] Communication error on send
