Orange Pi PC Plus loads and it faill without monitor !!
Stroke_papy
Hello
I have an allwinner H2 & H3 (PC +) when it does not boot on my LAN. If I want to try to use the LAN port. In / etc / network / interfaces the eth0 interface is not defined. I tried to change the iso but on Windows the iso is not valid. On Linux Linux the files are not -w and try to change but not possible !!!
If I want to try to use the UART port and PuTTY it doesn't go with in the prompt.
U-Boot 2020.04-armbian (Sep 02 2020 - 10:21:09 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC Plus
DRAM:  1 GiB
MMC:   Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000'
mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1
Loading Environment from FAT... Unable to use mmc 1:1... In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1b400: USB OHCI 1.0
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1c400: USB OHCI 1.0
Bus usb@1c1d000: USB EHCI 1.00
Bus usb@1c1d400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
scanning bus usb@1c1b400 for devices... 1 USB Device(s) found
scanning bus usb@1c1c000 for devices... 1 USB Device(s) found
scanning bus usb@1c1c400 for devices... 1 USB Device(s) found
scanning bus usb@1c1d000 for devices... 1 USB Device(s) found
scanning bus usb@1c1d400 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
3967 bytes read in 1 ms (3.8 MiB/s)
## Executing script at 43100000
U-boot loaded from eMMC or secondary SD
Boot script loaded from mmc
202 bytes read in 1 ms (197.3 KiB/s)
11493477 bytes read in 547 ms (20 MiB/s)
7788240 bytes read in 371 ms (20 MiB/s)
Found mainline kernel configuration
32586 bytes read in 4 ms (7.8 MiB/s)
4185 bytes read in 4 ms (1021.5 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 45000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    11493413 Bytes = 11 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
EHCI failed to shut down host controller.
   Loading Ramdisk to 49509000, end 49fff025 ... OK
   Loading Device Tree to 49498000, end 49508fff ... OK
Starting kernel ...
I cannot use a monitor How to do
Thank you
Hello I tried to change the file
4 -rw-rw-r-- 1 root root 153 Nov 17 14:47 armbianEnv.txt
at
verbosity = 7
bootlogo = false
console = both
disp_mode = 1920x1080p60
overlay_prefix = sun8i-h3
rootdev = UUID = 48a407c4-ca6e-4a21-ac94-71a9eac17295
rootfstype = ext4
now
    Loading Ramdisk to 49509000, end 49fffeba ...
after nothing
Is it serious doctor ???
Thank you
