OpenVPN (CyberGhostVPN) with Docker on Helios64
dancgn
I'm a noob...
And paid for cyberghostvpn Account. Now i want to run cgvpn on docker. Now i'm running a virtuell Ubuntu on my WindowsPC. But there's a server with can do it.
But how? I tryed to config some openvpn images, but nothing works.
How can i add my ca.crt, client.crt, client.key and openvpn.ovpn and run it?!?
Thanks in advance and please: Not to complicated.
Greetins
Daniel
Do CG have their own client or do they provide native OpenVPN config files?
I know from LXC that OpenVPN does not work OOB. Some adjustments are needed to allow the container proper access to the TUN device. Maybe Docker needs something similar.
Try a more generic search for docker openvpn client
This does not answer the question.
8 minutes ago, Werner said:
OpenVPN config
Try to get such files from them to use native OpenVPN client
Those files usually look something like this:
client
dev tun
proto udp
; Cert
remote-cert-tls server
cipher AES-256-CBC
;Host
resolv-retry infinite
;auth
auth-user-pass filename
auth-nocache
keepalive 10 30
auth SHA384
remote some.server.com 1194
remote-random
persist-key
persist-remote-ip
nobind
sndbuf 0
rcvbuf 0
verb 2
key-direction 1
As this is is not an issue specific to Helios64 I move this to p2p.
I have no idea how or what docker specific is to do. This worked fine for a cli-based installation:
If VPN provider provides .ovpn files, get them, and put them in /etc/openvpn.
1. Create a file (eg. auth.txt) in /etc/openvpn, 1st line containing your username (with an ENTER), 2nd line containig your password (without ENTER).
2. Choose one server's .ovpn and copy it to config.conf in /etc/openvpn.
3. Edit config.conf, find auth-user-pass. Append " auth.txt", and save the modified config.conf.
4. edit /etc/default/openvpn. Change "#AUTOSTART=all" to "AUTOSTART=config"
After this, enable and restart openvpn:
5. systemctl enable openvpn@config.service
6. systemctl daemon-reload
That's all, you might wanna use a "curl ipinfo.io" to verify your new VPN-IP.
Last time I setted up openvpn this way, I recieved such an error message at login after reboot:
"Unable to read database "/var/lib/vnstat/tun0"    No such file or directory   Merge "eth0+tun0" failed"
VPN worked, even without vnstat. But you can simply correct by:
vnstat --create -i tun0
and a reboot.
