Nyx_ Posted November 28, 2020 Share Posted November 28, 2020 Armbianmonitor: http://ix.io/2FPS Hello. Good day. I'm trying to use the SPI on a OragenPI One Plus (Allwinner H6), and, although I have enable it via the /boot/armbianEnv.txt configuration, communication is not working. Here's the armbianEnv.txt armbian@orangepioneplus:~$ cat /boot/armbianEnv.txt verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-h6 rootdev=UUID=19c1886e-0b74-45b8-b9f5-5fbd4bdeb5c2 rootfstype=ext4 overlays=spi-spidev param_spidev_spi_bus=0 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u And here's the SPI device listed under /dev armbian@orangepioneplus:~$ ls -la /dev/sp* crw------- 1 root root 153, 0 nov 28 15:06 /dev/spidev0.0 To test it, I compiled the spidev_test.c (https://github.com/rm-hull/spidev-test) and I jumped the MISO and MOSI pins on the board. This is the response I'm getting when running the spidev_test: armbian@orangepioneplus:~/spidev-test$ sudo ./spidev_test -v spi mode: 0x0 bits per word: 8 max speed: 500000 Hz (500 KHz) TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D | ......@....�..................�. RX | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................................ I tested it with both a Downloaded image from Armbian website as well as one that I built. Both behave the same way. To make sure this isn't a Hardware issue, I did the same test the a image from the OrangePi website. It worked fine. I'm running kernel 5.9.11. Searching on dmesg from SPI doesn't bring much. Here's it in any case: armbian@orangepioneplus:~/spidev-test$ dmesg | grep spi [ 2.693934] spidev spi0.0: probing from DT Any ideas where I can look next to solve the problem? I appreciate any suggestion/advice. Thank you. 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted November 30, 2020 Share Posted November 30, 2020 On 11/28/2020 at 3:14 PM, Nyx_ said: Any ideas where I can look next to solve the problem? I appreciate any suggestion/advice. After hours of investigation, and after having figured out that SPI for H6 wasn't working since 5.7.x, I've found why : missing SPI pins in DT ... https://github.com/armbian/build/commit/e3ade9e9f4292c6b257ad10f676edc4055106d2a 3 Quote Link to comment Share on other sites More sharing options...
Nyx_ Posted December 1, 2020 Author Share Posted December 1, 2020 19 hours ago, martinayotte said: After hours of investigation, and after having figured out that SPI for H6 wasn't working since 5.7.x, I've found why : missing SPI pins in DT ... https://github.com/armbian/build/commit/e3ade9e9f4292c6b257ad10f676edc4055106d2a Wow Martin! Thanks for the investigation and solution. I'll build a new version incorporating those changes and It will probably work. I'll reply the results here. Thank you very much. 2 Quote Link to comment Share on other sites More sharing options...
Nyx_ Posted December 8, 2020 Author Share Posted December 8, 2020 Yep. Just confirming that it's working, building from sources. armbian@orangepioneplus:~/spidev-test$ sudo ./spidev_test -v [sudo] password for armbian: spi mode: 0x0 bits per word: 8 max speed: 500000 Hz (500 KHz) TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D | ......@....�..................�. RX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D | ......@....�..................�. 0 Quote Link to comment Share on other sites More sharing options...
bbtoxic Posted July 16, 2021 Share Posted July 16, 2021 I see the same behavior on OrangePi 3 and I'm wondering if there might be a similar fix needed for this board. @martinayotte maybe? /boot/armbianEnv.txt verbosity=1 console=both overlay_prefix=sun50i-h6 overlays=spi-spidev1 param_spidev_spi_bus=1 rootdev=UUID=b9dd15a3-53c5-44e1-96ed-816ea6eb4967 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Working with this kernel: uname -a Linux magicsky 5.4.88-sunxi64 #21.02.3 SMP Mon Mar 8 08:07:33 UTC 2021 aarch64 GNU/Linux But not with latest buster 5.10. 0 Quote Link to comment Share on other sites More sharing options...
Felix Posted March 6, 2022 Share Posted March 6, 2022 Hi is this only affecting Orange Pi One Plus? I have a SPI working image (Kernel 5.7.15)for Orange Pi Lite 2 (H6) but when I change the board to Orange Pi One Plus through armbianEnv.txt, the SPI /dev/spi0.0 is there but not communicating. I’m confident it is not hardware related. Thanks. 0 Quote Link to comment Share on other sites More sharing options...
