Victor B. Posted November 30, 2020 Share Posted November 30, 2020 Hello, I am quite new to this topic, and I have found it to be quite complex. I primarily work with tiny MCUs and RTOSes, but I am enjoying the Linux space so far. In essence I would like to use the Mali GPU that is embedded within the RK3399 of the Helios64 for hardware transcoding. This isn't a novel idea, as shown by these sources: https://forum.armbian.com/topic/9272-development-rk3399-media-script/ https://emby.media/community/index.php?/topic/66675-36078-transcoding-rockpro64/ I am using Jellying, and in so FFMPEG to decode/encode the data streams. It seems that V4L2 is supported for hardware ecoding/decoding in the FFMPEG package, but in my experience doesn't appropriately work with the Mesa Panfrost drivers (https://wiki.debian.org/PanfrostLima) and the ARM drivers fail to compile with the kernel headers provided by the armbian-config script. I like the idea of having hardware accelerated transcoding, and I'm not even interested in 4K content, but my helios64 fails to transcode h265 (HEVC) to h264 at a playable rate. Secondly I like to have watch-togethers with my friends and I have to use my power-hungry PC for this. Of course I can introduce new hardware to do this like an arm64 laptop, but I like the all-in-one solution, and I simply can't be the only one that feels this way. Has anyone had success with hardware acceleration? Any ROE or ongoing efforts? Thanks, Victor 3 Quote Link to comment Share on other sites More sharing options...
barnumbirr Posted November 30, 2020 Share Posted November 30, 2020 I'd be delighted if the Helios64 gets hardware encoding/decoding as it would greatly increase perfomance when running Plex (or any media streaming service). I'll be following this thread closely and will be available for any testing or debugging. 0 Quote Link to comment Share on other sites More sharing options...
Victor B. Posted December 17, 2020 Author Share Posted December 17, 2020 A small update if you're willing to use a legacy kernel: I have not tested it yet... 1 Quote Link to comment Share on other sites More sharing options...
realmiwi Posted January 8, 2021 Share Posted January 8, 2021 (edited) Hi, I am also very interested in a solution. I use emby and would like to use the hardware encoding/decoding. I'll do some research myself as soon as I have a little more time. If I find a good solution I'll post it here. At the moment I'm using the current 5.9 kernel and a downgrade is out of the question (at least for now). Edited January 8, 2021 by realmiwi 1 Quote Link to comment Share on other sites More sharing options...
mlem Posted August 22, 2021 Share Posted August 22, 2021 Hi, I too would very much like be interested by it! I bought a USB-C-to-HDMI cable, plugged a monitor, and everything worked well. I thought that using this + and USB DAC for audio, I could directly turn my Helios64 NAS into a media center. Unfortunately I tried tried the RK3399 legacy multimedia framework (I just did sudo apt install media-buster-legacy-rk3399 --install-recommends ; I thought no harm could happen by just installing a package) and now my NAS won't boot (U-boot stops after "starting kernel"). I don't remember what kernel I installed, possibly this was not the legacy kernel. Thus, I would happily use some advice on how to unbrick my system -- and also upvote this vote, it would be terrific if the feature was installed in the default images or if there was an easy way to install them! Bests 0 Quote Link to comment Share on other sites More sharing options...
chall88 Posted February 25, 2023 Share Posted February 25, 2023 I found this post when looking for the video decoder hardware in the RK3399 The mali is a gpu, it does 3d rendering. So unless you are using something like openGL, the mali isn't going to do anything. It does not do the encode/decode of codec. There is another part in the SOC called a vpu Video Proccessing Unit -that does that. I know it's difficult to seperate them in the mind because most gpu cards have a encode/decode chip on them and we refer to the entire piece as a gpu but gpus and vpus are seperate 0 Quote Link to comment Share on other sites More sharing options...
