UART on gpio pins Orange Pi Lite
lupus666
Hi,
I need to use uart (for a gps receiver) and i2c (for some sensors) for my project via the gpio pins. Fortunately i2c is enabled in the images by default. I hope it is also enabled if I recompile armbian for the orangepi lite by default?
Afaik I have to enable UART in the following file: https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepilite.fex .
Unfurtunately I do not understand which pins on the gpio header correspond to the ports defined in this file.
For example:
uart_tx = port:PG06<2><1><default><default> uart_rx = port:PG07<2><1><default><default>
Can I use UART on any pins on the gpio header?
I would like to use UART on the same pins as in https://www.element14.com/community/servlet/JiveServlet/previewBody/73950-102-10-339300/pi3_gpio.png
How do I do that?
The UART available on pin 8 and 10 on the Pi header is the UART3, while the UART2 is located on pin 11 and 13.
So, in the FEX, for the UART3, you simply need to enable it (uart_used = 1) and remove the corresponding pins (PA13/PA14) from the GPIO list.
For the UART2, the pins to remove from GPIO list are PA00/PA01/PA02/PA03.
For the reference - this image is from schematics for on of H3 Orange Pi boards.
Edit: It is stated in the article.
Edit 2: BTW, It doesn't reference port/pin numbers for UART, I2C and SPI interfaces, so you still need to check original schematics to disable appropriate GPIOs.
Thank you for your replies. I have now tried to enable UART2 and UART3 and remove the corresponding pins from the GPIO list.
Unfortunately the Orange Pi does not boot with the new image and the screen is just black. The green led is also off.
Here are the changes I have made in the orangepilite.fex:
[uart2]
uart_used = 1
uart_port = 2
uart_type = 2
uart_tx = port:PA00<2><1><default><default>
uart_rx = port:PA01<2><1><default><default>
;uart_rts = port:PA02<2><1><default><default>
;uart_cts = port:PA03<2><1><default><default>
[uart3]
uart_used = 1
uart_port = 3
uart_type = 2
uart_tx = port:PA13<3><1><default><default>
uart_rx = port:PA14<3><1><default><default>
;uart_rts = port:PA15<3><1><default><default>
;uart_cts = port:PA16<3><1><default><default>
and
[gpio_para]
gpio_used = 1
gpio_num = 16
gpio_pin_1       = port:PA06<1><default><default><0>
gpio_pin_2       = port:PD14<1><default><default><0>
gpio_pin_3       = port:PA03<1><default><default><0>
gpio_pin_4       = port:PC04<1><default><default><0>
gpio_pin_5       = port:PC07<1><default><default><0>
gpio_pin_6      = port:PA02<1><default><default><0>
gpio_pin_7      = port:PA21<1><default><default><0>
gpio_pin_8      = port:PA07<1><default><default><0>
gpio_pin_9      = port:PA08<1><default><default><0>
gpio_pin_10      = port:PG08<1><default><default><0>
gpio_pin_11      = port:PA09<1><default><default><0>
gpio_pin_12      = port:PA10<1><default><default><0>
gpio_pin_13      = port:PG09<1><default><default><0>
gpio_pin_14      = port:PG06<1><default><default><0>
gpio_pin_15      = port:PG07<1><default><default><0>
Here are the fex file excerpts before I modified them:
[uart2]
uart_used = 0
uart_port = 2
uart_type = 4
[uart3]
uart_used = 0
uart_port = 3
uart_type = 4
and
[gpio_para]
gpio_used = 1
gpio_num = 19
gpio_pin_2       = port:PA13<1><default><default><0>
gpio_pin_3       = port:PA14<1><default><default><0>
gpio_pin_4       = port:PA01<1><default><default><0>
gpio_pin_5       = port:PD14<1><default><default><0>
gpio_pin_6       = port:PA00<1><default><default><0>
gpio_pin_7       = port:PA03<1><default><default><0>
gpio_pin_8       = port:PC04<1><default><default><0>
gpio_pin_9       = port:PC07<1><default><default><0>
gpio_pin_10      = port:PA02<1><default><default><0>
gpio_pin_11      = port:PA21<1><default><default><0>
gpio_pin_12      = port:PA07<1><default><default><0>
gpio_pin_13      = port:PA08<1><default><default><0>
gpio_pin_14      = port:PG08<1><default><default><0>
gpio_pin_15      = port:PA09<1><default><default><0>
gpio_pin_16      = port:PA10<1><default><default><0>
gpio_pin_17      = port:PG09<1><default><default><0>
gpio_pin_18      = port:PG06<1><default><default><0>
gpio_pin_19      = port:PG07<1><default><default><0>
What have I done wrong?
I don't see why editing the FEX with only the above changes would prevent from booting properly.
Maybe the whole image is badly written or the SDCard defective.
Try to redo the whole image, make sure it is booting, and then redo the FEX changes.
Hello,
Is UART I2C communication available via WiringPI or how do you manage to actually communicate with a device via I2C protocol using an OPI board and C language?
I want to read data from an I2C sensor using C script. Did someone managed to do this?
Can you please tell me what can I try?
Thanks.
What do you mean exactly ?
UART and I2C as nothing in common, except if you mean that you are using an I2C-to-UART bridge chip such SC16IS752, which Linux kernel is able to manage with proper kernel custom build configs and overlays.
This means that WiringPi is not used for this case.
i have orange pi lite when i go to /boot/boot0_OPI.fex what i must be do?
