Implement Device Tree Editor
Origin:
https://armbian.atlassian.net/projects/AR/issues/AR-235
Description:
Add an option to armbian-config to allow editing the device tree
Destination:
https://github.com/armbian/config
Skills required:
Bash
Testers needed. More especially, people with samsung, nexell or even marvell are expected.
The main issue for now is the way the dtb is named and located in the boot folder. I tried to infer it using the comptible property of the device tree, but I don't own all supported hardware ;).
I already tested sucessfully on several kernels (aml 4.20, rk and aw on 5.8, 5.9).
I'll merge it inside so that the people can start testing only by changing to nightly builds or if they build from sources. And one tip - when creating a DTB, redirect those warnings away from screen. Just catch if conversion returns 1 and pop out an error in config and then show content ...
Thanks!
Your welcome! It's a pleasure to contribute to armbian.
I also tried your proposition with the reading of the device-tree folder with this command:
dtc -I fs -O dts /sys/firmware/devicetree/base -o custom.dts
But on my edge-v (kernel 5.9), pine64h-b and opi1 with kernel 5.8, it generates a segmentation fault, whereas on my gt1 ultimate running armbianTV with kernel 4.20 it works.
That's odd. I would expect the other way around. Huh. No idea why this is happening. Keep digging in, try more recent dtc package or build from sources?
Compiling from https://github.com/dgibson/dtc, I'm able to generate a dts file, but using the one installed from apt I got the following output on my pine64h-b:
$ dtc -I fs /sys/firmware/devicetree/base -O dts -o custom.dts
custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@480000000: node has a unit name, but no reg property
custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1704000000: node has a unit name, but no reg property
custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@720000000: node has a unit name, but no reg property
custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1080000000: node has a unit name, but no reg property
custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@888000000: node has a unit name, but no reg property
custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@816000000: node has a unit name, but no reg property
custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1800000000: node has a unit name, but no reg property
custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1608000000: node has a unit name, but no reg property
custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1320000000: node has a unit name, but no reg property
custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1488000000: node has a unit name, but no reg property
custom.dts: Warning (unit_address_vs_reg): /memory: node has a reg or ranges property, but no unit name
custom.dts: Warning (clocks_property): /wifi_pwrseq:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/phy@5100400:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/phy@5100400:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/gpu@1800000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/gpu@1800000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/mmc@4022000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/mmc@4022000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 8 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 10 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/clock@7010000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/clock@7010000:clocks: cell 1 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/clock@7010000:clocks: cell 3 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/clock@7010000:clocks: cell 5 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/pinctrl@300b000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/pinctrl@300b000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/pinctrl@300b000:clocks: cell 3 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/pwm@300a000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/pwm@300a000:clocks: cell 1 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/bus@1000000/mixer@100000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/bus@1000000/mixer@100000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/bus@1000000/clock@0:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/bus@1000000/clock@0:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/i2c@5002800:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/rtc@7000000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/phy@5210000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/lcd-controller@6515000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/lcd-controller@6515000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/spdif@5093000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/spdif@5093000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/usb@5311400:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/usb@5311400:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/mmc@4021000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/mmc@4021000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/usb@5101400:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/usb@5101400:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/clock@3001000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/clock@3001000:clocks: cell 1 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/clock@3001000:clocks: cell 3 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/video-codec@1c0e000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/video-codec@1c0e000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/video-codec@1c0e000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/thermal-sensor@5070400:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/i2c@7081400:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/watchdog@7020400:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/iommu@30f0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/i2c@5002400:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/spi@5011000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/spi@5011000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/serial@5000800:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/usb@5311000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/usb@5311000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/usb@5311000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/i2c@5002c00:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/i2c@5002c00/mfd@10/phy:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/serial@7080000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/usb@5101000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/usb@5101000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/usb@5101000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/tcon-top@6510000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/tcon-top@6510000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/hdmi-phy@6010000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/hdmi-phy@6010000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/i2c@5002000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/crypto@1904000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/crypto@1904000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/crypto@1904000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/mmc@4020000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/mmc@4020000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/mailbox@3003000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/serial@5000400:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/dma-controller@3002000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/dma-controller@3002000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/ethernet@5020000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/serial@5000c00:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/spi@5010000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/spi@5010000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/pinctrl@7022000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/pinctrl@7022000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/pinctrl@7022000:clocks: cell 3 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/ir@7040000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/ir@7040000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/watchdog@30090a0:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/i2s@5091000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/i2s@5091000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/dwc3@5200000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/dwc3@5200000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/dwc3@5200000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/usb@5100000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /soc/serial@5000000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /cpus/cpu@1:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /cpus/cpu@2:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /cpus/cpu@0:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /cpus/cpu@3:clocks: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu-thermal/cooling-maps/cpu_very_hot_limit_cpu:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu-thermal/cooling-maps/cpu_warm_limit_cpu:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu-thermal/cooling-maps/cpu_hot_limit_cpu:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu-thermal/cooling-maps/cpu_hot_pre_limit_cpu:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu-thermal/cooling-maps/cpu_very_hot_pre_limit_cpu:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /soc/spdif@5093000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /soc/spi@5011000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /soc/spi@5011000:dmas: cell 2 is not a phandle reference
custom.dts: Warning (dmas_property): /soc/spi@5010000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /soc/spi@5010000:dmas: cell 2 is not a phandle reference
custom.dts: Warning (dmas_property): /soc/i2s@5091000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /soc/i2s@5091000:dmas: cell 2 is not a phandle reference
custom.dts: Warning (iommus_property): /soc/bus@1000000/mixer@100000:iommus: cell 0 is not a phandle reference
custom.dts: Warning (iommus_property): /soc/video-codec@1c0e000:iommus: cell 0 is not a phandle reference
custom.dts: Warning (mboxes_property): /scpi:mboxes: cell 0 is not a phandle reference
custom.dts: Warning (mboxes_property): /scpi:mboxes: cell 2 is not a phandle reference
custom.dts: Warning (phys_property): /soc/hdmi@6000000:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /soc/usb@5311400:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /soc/usb@5311000:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /soc/dwc3@5200000:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /soc/usb@5100000:phys: cell 0 is not a phandle reference
custom.dts: Warning (pwms_property): /ac200_clk:pwms: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/phy@5100400:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/phy@5100400:resets: cell 2 is not a phandle reference
custom.dts: Warning (resets_property): /soc/gpu@1800000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/mmc@4022000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/hdmi@6000000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/hdmi@6000000:resets: cell 2 is not a phandle reference
custom.dts: Warning (resets_property): /soc/pwm@300a000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/bus@1000000/mixer@100000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/bus@1000000/clock@0:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/i2c@5002800:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/phy@5210000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/lcd-controller@6515000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/spdif@5093000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/usb@5311400:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/mmc@4021000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/usb@5101400:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/video-codec@1c0e000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/thermal-sensor@5070400:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/i2c@7081400:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/iommu@30f0000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/i2c@5002400:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/spi@5011000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/serial@5000800:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/usb@5311000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/usb@5311000:resets: cell 2 is not a phandle reference
custom.dts: Warning (resets_property): /soc/i2c@5002c00:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/serial@7080000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/usb@5101000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/usb@5101000:resets: cell 2 is not a phandle reference
custom.dts: Warning (resets_property): /soc/tcon-top@6510000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/hdmi-phy@6010000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/i2c@5002000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/crypto@1904000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/mmc@4020000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/mailbox@3003000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/serial@5000400:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/dma-controller@3002000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/ethernet@5020000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/serial@5000c00:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/spi@5010000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/ir@7040000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/i2s@5091000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/dwc3@5200000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/usb@5100000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /soc/serial@5000000:resets: cell 0 is not a phandle reference
custom.dts: Warning (sound_dai_property): /hdmi-sound/simple-audio-card,cpu:sound-dai: cell 0 is not a phandle reference
custom.dts: Warning (sound_dai_property): /hdmi-sound/simple-audio-card,codec:sound-dai: cell 0 is not a phandle reference
custom.dts: Warning (thermal_sensors_property): /thermal-zones/cpu-thermal:thermal-sensors: cell 0 is not a phandle reference
custom.dts: Warning (thermal_sensors_property): /thermal-zones/gpu-thermal:thermal-sensors: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /wifi_pwrseq:reset-gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /soc/mmc@4020000:cd-gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /leds/heartbeat:gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /leds/status:gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /leds/link:gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /vbus:gpio: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /gmac-3v3:gpio: cell 0 is not a phandle reference
custom.dts: Warning (graph_child_address): /soc/tcon-top@6510000/ports/port@0: graph node has single child node 'endpoint@0', #address-cells/#size-cells are not necessary
custom.dts: Warning (graph_child_address): /soc/tcon-top@6510000/ports/port@4: graph node has single child node 'endpoint@0', #address-cells/#size-cells are not necessary
[1]    6806 segmentation fault  dtc -I fs /sys/firmware/devicetree/base -O dts -o custom.dts
Warnings are fine but it's worth researching why ... while segfaulting is clearly not good. Try decompiling a few other DT by hand to narrow down where segfault is happening. Perhaps we will learn something.
Sorry, I don't know how to decompile by hand.
With a small script, I tested the packaged dtc with all the dtbs from the boot folders of my edge-v (allwinner, amlogic and rockchip) and got no segfaults. With this board, I have much more warnings when decompiling from fs:
Spoiler
custom.dts: Warning (unit_address_vs_reg): /usb@fe900000: node has a unit name, but no reg property
custom.dts: Warning (unit_address_vs_reg): /usb@fe800000: node has a unit name, but no reg property
custom.dts: Warning (avoid_unnecessary_addr_size): /mipi@ff960000: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
custom.dts: Warning (avoid_unnecessary_addr_size): /mipi@ff968000: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
custom.dts: Warning (clocks_property): /i2c@ff150000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff150000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /pwm@ff420020:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /phy@ff7c0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /phy@ff7c0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /pwm@ff420010:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff660480:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff660480:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff1d0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff1d0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /i2s@ff880000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2s@ff880000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /pwm@ff420000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /pinctrl/gpio4@ff790000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /pinctrl/gpio2@ff780000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /pinctrl/gpio0@ff720000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /pinctrl/gpio1@ff730000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /pinctrl/gpio3@ff788000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_tcpc0@8:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_tcpc0@8:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_sdioaudio@28:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_edp@25:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_tcpc1@9:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_tcpc1@9:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_emmc@23:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_gmac@22:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_gmac@22:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_gpu@35:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_iep@34:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_iep@34:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vcodec@31:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vcodec@31:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_sd@27:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_sd@27:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_rga@33:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_rga@33:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vdu@32:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vdu@32:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_usb3@24:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_isp1@20:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_isp1@20:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_vo@16/pd_vopb@17:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_vo@16/pd_vopb@17:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_vo@16/pd_vopl@18:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_vo@16/pd_vopl@18:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_isp0@19:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_isp0@19:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_hdcp@21:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_hdcp@21:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_hdcp@21:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /gpu@ff9a0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff3e0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff3e0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /pcie@f8000000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /pcie@f8000000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /pcie@f8000000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /pcie@f8000000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /rktimer@ff850000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /rktimer@ff850000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /serial@ff1a0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /serial@ff1a0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe3a0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe3a0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe3a0000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /saradc@ff100000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /saradc@ff100000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe3e0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe3e0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe3e0000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff120000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff120000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /mmc@fe320000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /mmc@fe320000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /mmc@fe320000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /mmc@fe320000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /syscon@ff770000/mipi-dphy-rx0:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /syscon@ff770000/mipi-dphy-rx0:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /syscon@ff770000/mipi-dphy-rx0:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /syscon@ff770000/pcie-phy:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /syscon@ff770000/usb2-phy@e460:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /syscon@ff770000/usb2-phy@e450:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /syscon@ff770000/phy@f780:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /efuse@ff690000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff160000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff160000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /dp@fec00000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /dp@fec00000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /dp@fec00000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /dp@fec00000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /rng@ff8b8000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /rng@ff8b8000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff670800:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff670800:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff1e0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff1e0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /rga@ff680000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /rga@ff680000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /rga@ff680000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /i2s@ff890000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2s@ff890000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /video-codec@ff650000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /video-codec@ff650000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff914000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff914000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff200000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff200000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff903f00:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff903f00:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /serial@ff1b0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /serial@ff1b0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /watchdog@ff848000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff130000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff130000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /tsadc@ff260000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /tsadc@ff260000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 8 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 10 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe900000/usb@fe900000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe900000/usb@fe900000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe900000/usb@fe900000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /serial@ff180000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /serial@ff180000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /serial@ff180000/bluetooth:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe380000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe380000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe380000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 8 is not a phandle reference
custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 10 is not a phandle reference
custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 12 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff350000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff350000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff1f0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff1f0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /mipi@ff960000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /mipi@ff960000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /mipi@ff960000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /mipi@ff960000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff8f3f00:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff8f3f00:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /video-codec@ff660000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /video-codec@ff660000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /video-codec@ff660000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /video-codec@ff660000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /sdio-pwrseq:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff924000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff924000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /bus/dma-controller@ff6e0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /bus/dma-controller@ff6d0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff3c0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff3c0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /hdmi@ff940000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /hdmi@ff940000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /hdmi@ff940000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /hdmi@ff940000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /hdmi@ff940000:clocks: cell 8 is not a phandle reference
custom.dts: Warning (clocks_property): /phy@ff800000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /phy@ff800000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 8 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 10 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe800000/usb@fe800000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe800000/usb@fe800000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe800000/usb@fe800000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe3c0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe3c0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /usb@fe3c0000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /i2s@ff8a0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2s@ff8a0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /edp@ff970000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /edp@ff970000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /edp@ff970000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /sdhci@fe330000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /sdhci@fe330000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff140000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff140000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /vop@ff900000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /vop@ff900000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /vop@ff900000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /serial@ff190000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /serial@ff190000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff650800:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /iommu@ff650800:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff1c0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /spi@ff1c0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /mipi@ff968000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /mipi@ff968000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /mipi@ff968000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /mipi@ff968000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /cpus/cpu@101:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /cpus/cpu@100:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff3d0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff3d0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /vop@ff8f0000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /vop@ff8f0000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /vop@ff8f0000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /serial@ff370000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /serial@ff370000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /spdif@ff870000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /spdif@ff870000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff110000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /i2c@ff110000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /mmc@fe310000:clocks: cell 0 is not a phandle reference
custom.dts: Warning (clocks_property): /mmc@fe310000:clocks: cell 2 is not a phandle reference
custom.dts: Warning (clocks_property): /mmc@fe310000:clocks: cell 4 is not a phandle reference
custom.dts: Warning (clocks_property): /mmc@fe310000:clocks: cell 6 is not a phandle reference
custom.dts: Warning (clocks_property): /pwm@ff420030:clocks: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/gpu/cooling-maps/map2:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/gpu/cooling-maps/map0:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/gpu/cooling-maps/map1:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map2:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map0:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map0:cooling-device: cell 3 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map3:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 0 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 3 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 6 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 9 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 12 is not a phandle reference
custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 15 is not a phandle reference
custom.dts: Warning (dmas_property): /spi@ff1d0000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /spi@ff1d0000:dmas: cell 2 is not a phandle reference
custom.dts: Warning (dmas_property): /i2s@ff880000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /i2s@ff880000:dmas: cell 2 is not a phandle reference
custom.dts: Warning (dmas_property): /spi@ff1e0000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /spi@ff1e0000:dmas: cell 2 is not a phandle reference
custom.dts: Warning (dmas_property): /i2s@ff890000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /i2s@ff890000:dmas: cell 2 is not a phandle reference
custom.dts: Warning (dmas_property): /spi@ff200000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /spi@ff200000:dmas: cell 2 is not a phandle reference
custom.dts: Warning (dmas_property): /spi@ff1f0000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /spi@ff1f0000:dmas: cell 2 is not a phandle reference
custom.dts: Warning (dmas_property): /i2s@ff8a0000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /i2s@ff8a0000:dmas: cell 2 is not a phandle reference
custom.dts: Warning (dmas_property): /spi@ff1c0000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (dmas_property): /spi@ff1c0000:dmas: cell 2 is not a phandle reference
custom.dts: Warning (dmas_property): /spdif@ff870000:dmas: cell 0 is not a phandle reference
custom.dts: Warning (io_channels_property): /adc-keys:io-channels: cell 0 is not a phandle reference
custom.dts: Warning (iommus_property): /video-codec@ff650000:iommus: cell 0 is not a phandle reference
custom.dts: Warning (iommus_property): /video-codec@ff660000:iommus: cell 0 is not a phandle reference
custom.dts: Warning (iommus_property): /vop@ff900000:iommus: cell 0 is not a phandle reference
custom.dts: Warning (iommus_property): /vop@ff8f0000:iommus: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /pcie@f8000000:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /pcie@f8000000:phys: cell 2 is not a phandle reference
custom.dts: Warning (phys_property): /pcie@f8000000:phys: cell 4 is not a phandle reference
custom.dts: Warning (phys_property): /pcie@f8000000:phys: cell 6 is not a phandle reference
custom.dts: Warning (phys_property): /usb@fe3a0000:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /usb@fe3e0000:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /dp@fec00000:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /dp@fec00000:phys: cell 1 is not a phandle reference
custom.dts: Warning (phys_property): /usb@fe900000/usb@fe900000:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /usb@fe900000/usb@fe900000:phys: cell 1 is not a phandle reference
custom.dts: Warning (phys_property): /usb@fe380000:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /usb@fe800000/usb@fe800000:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /usb@fe800000/usb@fe800000:phys: cell 1 is not a phandle reference
custom.dts: Warning (phys_property): /usb@fe3c0000:phys: cell 0 is not a phandle reference
custom.dts: Warning (phys_property): /sdhci@fe330000:phys: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /phy@ff7c0000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /iommu@ff660480:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /i2s@ff880000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /gpu@ff9a0000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /mmc@fe320000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /syscon@ff770000/mipi-dphy-rx0:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /dp@fec00000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /rga@ff680000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /i2s@ff890000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /video-codec@ff650000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /iommu@ff914000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /spi@ff200000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /iommu@ff903f00:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /usb@fe900000/usb@fe900000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /ethernet@fe300000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /mipi@ff960000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /iommu@ff8f3f00:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /video-codec@ff660000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /iommu@ff924000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /hdmi@ff940000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /phy@ff800000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /usb@fe800000/usb@fe800000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /i2s@ff8a0000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /edp@ff970000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /sdhci@fe330000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /vop@ff900000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /iommu@ff650800:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /mipi@ff968000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /vop@ff8f0000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /spdif@ff870000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (power_domains_property): /mmc@fe310000:power-domains: cell 0 is not a phandle reference
custom.dts: Warning (pwms_property): /vdd-log:pwms: cell 0 is not a phandle reference
custom.dts: Warning (pwms_property): /pwm-fan:pwms: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /phy@ff7c0000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /phy@ff7c0000:resets: cell 2 is not a phandle reference
custom.dts: Warning (resets_property): /phy@ff7c0000:resets: cell 4 is not a phandle reference
custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 2 is not a phandle reference
custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 4 is not a phandle reference
custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 6 is not a phandle reference
custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 8 is not a phandle reference
custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 10 is not a phandle reference
custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 12 is not a phandle reference
custom.dts: Warning (resets_property): /saradc@ff100000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /mmc@fe320000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /syscon@ff770000/pcie-phy:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /dp@fec00000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /dp@fec00000:resets: cell 2 is not a phandle reference
custom.dts: Warning (resets_property): /dp@fec00000:resets: cell 4 is not a phandle reference
custom.dts: Warning (resets_property): /dp@fec00000:resets: cell 6 is not a phandle reference
custom.dts: Warning (resets_property): /rga@ff680000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /rga@ff680000:resets: cell 2 is not a phandle reference
custom.dts: Warning (resets_property): /rga@ff680000:resets: cell 4 is not a phandle reference
custom.dts: Warning (resets_property): /tsadc@ff260000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /usb@fe900000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /ethernet@fe300000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /mipi@ff960000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /phy@ff800000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /phy@ff800000:resets: cell 2 is not a phandle reference
custom.dts: Warning (resets_property): /phy@ff800000:resets: cell 4 is not a phandle reference
custom.dts: Warning (resets_property): /usb@fe800000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /edp@ff970000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /vop@ff900000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /vop@ff900000:resets: cell 2 is not a phandle reference
custom.dts: Warning (resets_property): /vop@ff900000:resets: cell 4 is not a phandle reference
custom.dts: Warning (resets_property): /mipi@ff968000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /vop@ff8f0000:resets: cell 0 is not a phandle reference
custom.dts: Warning (resets_property): /vop@ff8f0000:resets: cell 2 is not a phandle reference
custom.dts: Warning (resets_property): /vop@ff8f0000:resets: cell 4 is not a phandle reference
custom.dts: Warning (resets_property): /mmc@fe310000:resets: cell 0 is not a phandle reference
custom.dts: Warning (thermal_sensors_property): /thermal-zones/gpu:thermal-sensors: cell 0 is not a phandle reference
custom.dts: Warning (thermal_sensors_property): /thermal-zones/cpu:thermal-sensors: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /pcie@f8000000:ep-gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /mmc@fe320000:cd-gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /vcc5v0-host-regulator:gpio: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /leds/led-1:gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /leds/led-0:gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /gpio-keys/power:gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /serial@ff180000/bluetooth:device-wakeup-gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /serial@ff180000/bluetooth:shutdown-gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /serial@ff180000/bluetooth:host-wakeup-gpios: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /ethernet@fe300000:snps,reset-gpio: cell 0 is not a phandle reference
custom.dts: Warning (gpios_property): /sdio-pwrseq:reset-gpios: cell 0 is not a phandle reference
custom.dts: Warning (graph_child_address): /mipi@ff960000/ports: graph node has single child node 'port@0', #address-cells/#size-cells are not necessary
custom.dts: Warning (graph_child_address): /edp@ff970000/ports: graph node has single child node 'port@0', #address-cells/#size-cells are not necessary
custom.dts: Warning (graph_child_address): /mipi@ff968000/ports: graph node has single child node 'port@0', #address-cells/#size-cells are not necessary
[1]    4065 segmentation fault  dtc -I fs /sys/firmware/devicetree/base -O dts -o custom.dts
I mean with dtc command ... like you did.
Well, I would propose to finish with the tool functionality, so it can be used where it doesn't fail ... just properly report error if segfault is happened.
Hi @Igor @jeanrhum
Just seen this thread, I also tried to decompile DT on a H3 OPiPC running Armbian (21.02)
Got exactly that behavior first a bunch of warnings and then segfault, on Debian builds desktop or console.
On Ubuntu Focal it was giving the warnings too but at the end it decompiled successfully and showing the dts.
Just letting you know if you still going on with this project.
Christos
Hi @jeanrhum
For my case I wanted to examine the running DT so I executed
dtc -I fs -O dts /proc/device-tree
which was segfault in Debian.
The plain decompile of a specific dtb works though eg
dtc -I dtb -O dts /boot/dtb/sun8i-h3-orangepi-pc.dtb
My kernel in both Debian and Ubuntu is the same 'current', 5.10.8
Christos
  • Werner locked this topic
